I need some help because I’ve some trouble getting my system working. I’ve just migrated from Domoticz to openHAB to get better support for my devices.
During the migration I’ve had a lot of trouble getting Deconz working (CONBEE II). Deconz is running on the same device as openHAB.
All light and plug are working with the HUE binding (no issues here).
The problem is with the Dresden Elektronik deCONZ Binding.
Added the binding (using addons tab)
Go to configuration/things
Add thing --> Dresden Elektronik deCONZ Binding
Nothing found
Add manualy --> deCONZ A running deCONZ software instance
Fill host adress (same as used for openHAB (192…)
continue
deCONZ is added to things but keeps status “initializing”
Please could somesome help me with this (I’ve been busy for hours without succes)?
I’m sorry, i’ve overlooked that you are using the HUE binding for you lights.
But what is the problem? In your opening post you don’t mention any sensors. If you haven’t got any, you don’t need the binding.
I’ve solved the issue by reinstalling everything. I formatted my card and did a full reinstal. I’ve done the same as before but now with succes.
Think it was somekind of glitch
