i have ds18B20 conected to arduino with modbus rtu library and temperature is displayed on openhab2 but only integer, i wont to display one number after comma, my configuration:
modbus.cfg:
#LightSensor && Temperature
modbus:serial.slave2.connection=/dev/ttyUSB0:19200:8:none:1:rtu
modbus:serial.slave2.type=holding
modbus:serial.slave2.id=1
modbus:serial.slave2.start=1
modbus:serial.slave2.length=2
item:
Number Temperature "Temperature [%.1f °C]" { modbus="slave2:1" }
sitemap:
Text item=Temperature icon="temperature"
arduino sketch is well because when i print temperature on the serial i see for example 21.75
void CheckTemp()
{ sensors.setResolution(12);
sensors.requestTemperatures();
if (millis() - lastTempRequest >= delayInMillis)
for (int i=0; i<SENSORS_NUM; i++) {
float temperature = sensors.getTempCByIndex(i);
if (lastTemperature[i] != temperature && temperature != -127.00 && temperature != 85.00) {
lastTemperature[i]=temperature;
lastTempRequest = millis();
in openhab2 i see for example 21.0 and alweys after coma is 0
