I would like to compare the temperature values to a certain threshold inside a rule of this kind :
rule "Temp threshold check"
Item onewiretemp1Value changed
if(onewiretemp1Value > -20){
AlarmPush.sendCommand(ON)
else {
AlarmPush.sendCommand(OFF)
rule "Send push notification when alarm is ON"
Item AlarmPush changed from OFF to ON
sendBroadcastNotification("Warning!")
Because the .items were created using a String, I get an error while using if(onewiretemp1Value > -20){ … because I can’t compare a String to a threshold numeric value.
If I change my items from String to Number, the items are not updated anymore (persist also stop working of course). The items stick to NULL.
What could I do to correctly use my rule or change my items to number?
As a workaround, I would suggest to use proxy items:
String strOnewireTemp1 {channel="exec:command:onewiretemp1:output"}
String strOnewireTemp2 {channel="exec:command:onewiretemp2:output"}
Number onewiretemp1Value "Freezer Fridge Temp [%.1f °C]" <temperature>
Number onewiretemp2Value "Freezer Temp [%.1f °C]"<temperature>
And of course a rule to update the items:
rule "update temp"
Item strOnewireTemp1 changed or
Item strOnewireTemp2 changed
if(Double::parseDouble(strOnewireTemp1.state) != (onewiretemp1Value.state as Number))
onewiretemp1Value.postUpdate(Double::parseDouble(strOnewireTemp1.state))
if(Double::parseDouble(strOnewireTemp2.state) != (onewiretemp2Value.state as Number))
onewiretemp2Value.postUpdate(Double::parseDouble(strOnewireTemp2.state))
if((onewiretemp1Value as Number) > -20.0) //force float by typing 20.0
else if((onewiretemp1Value as Number) < -20.0) //a little hysteresis
Please be aware that you always have to use .state to get the state of an item. If you want the state treated as a number, you have to use type casting.
Of course, you could omit the proxy item, but you can take advance from an item of type number, e.g. you can set changing colors for label and/or value in dependence of the value.
Thank you for your answer. We are on a good track…
I updated my items with your code.
Still have this error in the log : Rule ‘Update temp’: An error occurred during the script execution: Could not invoke method: java.lang.Double.parseDouble(java.lang.String) on instance: null
Actually, in Designer, I get a type mistmatch :
Cannot convert from State to String on strOnewireTemp1.state and strOnewireTemp2.state
Cannot cast from NumberItem to Number on onewiretemp1Value
rule "Update temp"
Can you take a look?
Thank you very much for your help, very appreciated!
That’s strange… (well… the second type mismatch from designer is a copy&paste error, my bad…
Let’s try this:
rule "Update temp1"
if(strOnewireTemp1.state.toString!="" && strOnewireTemp1.state.toString!="NULL")
onewiretemp1Value.postUpdate(Double::parseDouble(strOnewireTemp1.state.toString))
if((onewiretemp1Value.state as Number) > -20.0) //force float by typing 20.0
else if((onewiretemp1Value.state as Number) < -20.0) //a little hysteresis
rule "Update temp2"
if(strOnewireTemp2.state.toString!="" && strOnewireTemp2.state.toString!="NULL")
onewiretemp2Value.postUpdate(Double::parseDouble(strOnewireTemp2.state.toString))
I now ended up in two rules.
If there are strings that occur to strOnewireTempX (where X is 1 or 2) that are not numerical, you have to add them to the if-clause (maybe you can ensure that the exec will always return a valid number (and -999 for error or so, then you have to exclude this value through the if-clause).
