zwave.log:
25-Feb-2018 13:31:55.341 [DEBUG] [rg.openhab.binding.zwave.handler.ZWaveThingHandler] - NODE 3: Updating channel state zwave:device:5a0ca91c:node3:sensor_luminance to 1368 [DecimalType]
25-Feb-2018 13:31:55.363 [DEBUG] [tocol.serialmessage.ApplicationCommandMessageClass] - NODE 4: Transaction not completed: node address inconsistent. lastSent=4, incoming=255
25-Feb-2018 13:33:25.278 [TRACE] [wave.handler.ZWaveSerialHandler$ZWaveReceiveThread] - Received SOF
25-Feb-2018 13:33:25.282 [DEBUG] [wave.handler.ZWaveSerialHandler$ZWaveReceiveThread] - Receive Message = 01 10 00 04 00 03 0A 56 01 31 05 03 0A 04 4D 52 3C AF
25-Feb-2018 13:33:25.285 [TRACE] [nhab.binding.zwave.internal.protocol.SerialMessage] - NODE 255: Creating new SerialMessage from buffer = 01 10 00 04 00 03 0A 56 01 31 05 03 0A 04 4D 52 3C AF
25-Feb-2018 13:33:25.286 [TRACE] [nhab.binding.zwave.internal.protocol.SerialMessage] - Calculated checksum = 0xAF
25-Feb-2018 13:33:25.287 [TRACE] [nhab.binding.zwave.internal.protocol.SerialMessage] - NODE 255: Checksum matched
25-Feb-2018 13:33:25.290 [TRACE] [nhab.binding.zwave.internal.protocol.SerialMessage] - NODE 255: Message payload = 00 03 0A 56 01 31 05 03 0A 04 4D 52 3C
25-Feb-2018 13:33:25.291 [TRACE] [wave.handler.ZWaveSerialHandler$ZWaveReceiveThread] - Message is valid, sending ACK
25-Feb-2018 13:33:25.316 [TRACE] [wave.handler.ZWaveSerialHandler$ZWaveReceiveThread] - Response SENT
25-Feb-2018 13:33:25.318 [DEBUG] [ab.binding.zwave.internal.protocol.ZWaveController] - Receive queue TAKE: Length=0
25-Feb-2018 13:33:25.319 [TRACE] [nhab.binding.zwave.internal.protocol.SerialMessage] - Calculated checksum = 0xAF
25-Feb-2018 13:33:25.322 [DEBUG] [nhab.binding.zwave.internal.protocol.SerialMessage] - Assembled message buffer = 01 10 00 04 00 03 0A 56 01 31 05 03 0A 04 4D 52 3C AF
25-Feb-2018 13:33:25.324 [DEBUG] [ab.binding.zwave.internal.protocol.ZWaveController] - Process Message = 01 10 00 04 00 03 0A 56 01 31 05 03 0A 04 4D 52 3C AF
25-Feb-2018 13:33:25.333 [DEBUG] [ab.binding.zwave.internal.protocol.ZWaveController] - Message: class=ApplicationCommandHandler[0x04], type=Request[0x00], priority=High, dest=255, callback=0, payload=00 03 0A 56 01 31 05 03 0A 04 4D 52 3C
25-Feb-2018 13:33:25.335 [TRACE] [ab.binding.zwave.internal.protocol.ZWaveController] - Incoming Message type = REQUEST
25-Feb-2018 13:33:25.336 [TRACE] [tocol.serialmessage.ApplicationCommandMessageClass] - Handle Message Application Command Request
25-Feb-2018 13:33:25.337 [DEBUG] [tocol.serialmessage.ApplicationCommandMessageClass] - NODE 3: Application Command Request (ALIVE:DETAILS)
25-Feb-2018 13:33:25.338 [DEBUG] [tocol.serialmessage.ApplicationCommandMessageClass] - NODE 3: Incoming command class CRC_16_ENCAP
25-Feb-2018 13:33:25.339 [TRACE] [tocol.serialmessage.ApplicationCommandMessageClass] - NODE 3: Found Command Class CRC_16_ENCAP, passing to handleApplicationCommandRequest
25-Feb-2018 13:33:25.340 [DEBUG] [l.commandclass.ZWaveCRC16EncapsulationCommandClass] - NODE 3: Received CRC 16 Encapsulation Request
25-Feb-2018 13:33:25.340 [TRACE] [l.commandclass.ZWaveCRC16EncapsulationCommandClass] - Process CRC16 Encapsulation
25-Feb-2018 13:33:25.341 [DEBUG] [l.commandclass.ZWaveCRC16EncapsulationCommandClass] - NODE 3: Calling handleApplicationCommandRequest.
25-Feb-2018 13:33:25.342 [DEBUG] [col.commandclass.ZWaveMultiLevelSensorCommandClass] - NODE 3: Received COMMAND_CLASS_SENSOR_MULTILEVEL command V8
25-Feb-2018 13:33:25.343 [DEBUG] [col.commandclass.ZWaveMultiLevelSensorCommandClass] - NODE 3: Sensor Multi Level REPORT received
25-Feb-2018 13:33:25.344 [DEBUG] [col.commandclass.ZWaveMultiLevelSensorCommandClass] - NODE 3: Sensor Type = Luminance(3), Scale = 1
25-Feb-2018 13:33:25.345 [DEBUG] [col.commandclass.ZWaveMultiLevelSensorCommandClass] - NODE 3: Sensor Value = 1101
25-Feb-2018 13:33:25.347 [DEBUG] [ab.binding.zwave.internal.protocol.ZWaveController] - Notifying event listeners: ZWaveMultiLevelSensorValueEvent
25-Feb-2018 13:33:25.348 [DEBUG] [rg.openhab.binding.zwave.handler.ZWaveThingHandler] - NODE 3: Got an event from Z-Wave network: ZWaveMultiLevelSensorValueEvent
25-Feb-2018 13:33:25.349 [DEBUG] [rg.openhab.binding.zwave.handler.ZWaveThingHandler] - NODE 3: Got a value event from Z-Wave network, endpoint = 0, command class = SENSOR_MULTILEVEL, value = 1101
25-Feb-2018 13:33:25.350 [DEBUG] [rg.openhab.binding.zwave.handler.ZWaveThingHandler] - NODE 3: Updating channel state zwave:device:5a0ca91c:node3:sensor_luminance to 1101 [DecimalType]
25-Feb-2018 13:33:25.353 [DEBUG] [tocol.serialmessage.ApplicationCommandMessageClass] - NODE 4: Transaction not completed: node address inconsistent. lastSent=4, incoming=255
25-Feb-2018 13:34:33.510 [TRACE] [wave.handler.ZWaveSerialHandler$ZWaveReceiveThread] - Received SOF
25-Feb-2018 13:34:33.516 [DEBUG] [wave.handler.ZWaveSerialHandler$ZWaveReceiveThread] - Receive Message = 01 08 00 04 00 04 02 84 07 76
25-Feb-2018 13:34:33.520 [TRACE] [nhab.binding.zwave.internal.protocol.SerialMessage] - NODE 255: Creating new SerialMessage from buffer = 01 08 00 04 00 04 02 84 07 76
25-Feb-2018 13:34:33.523 [TRACE] [nhab.binding.zwave.internal.protocol.SerialMessage] - Calculated checksum = 0x76
25-Feb-2018 13:34:33.525 [TRACE] [nhab.binding.zwave.internal.protocol.SerialMessage] - NODE 255: Checksum matched
25-Feb-2018 13:34:33.528 [TRACE] [nhab.binding.zwave.internal.protocol.SerialMessage] - NODE 255: Message payload = 00 04 02 84 07
25-Feb-2018 13:34:33.531 [TRACE] [wave.handler.ZWaveSerialHandler$ZWaveReceiveThread] - Message is valid, sending ACK
25-Feb-2018 13:34:33.556 [TRACE] [wave.handler.ZWaveSerialHandler$ZWaveReceiveThread] - Response SENT
25-Feb-2018 13:34:33.559 [DEBUG] [ab.binding.zwave.internal.protocol.ZWaveController] - Receive queue TAKE: Length=0
25-Feb-2018 13:34:33.561 [TRACE] [nhab.binding.zwave.internal.protocol.SerialMessage] - Calculated checksum = 0x76
25-Feb-2018 13:34:33.564 [DEBUG] [nhab.binding.zwave.internal.protocol.SerialMessage] - Assembled message buffer = 01 08 00 04 00 04 02 84 07 76
25-Feb-2018 13:34:33.567 [DEBUG] [ab.binding.zwave.internal.protocol.ZWaveController] - Process Message = 01 08 00 04 00 04 02 84 07 76
25-Feb-2018 13:34:33.570 [DEBUG] [ab.binding.zwave.internal.protocol.ZWaveController] - Message: class=ApplicationCommandHandler[0x04], type=Request[0x00], priority=High, dest=255, callback=0, payload=00 04 02 84 07
25-Feb-2018 13:34:33.572 [TRACE] [ab.binding.zwave.internal.protocol.ZWaveController] - Incoming Message type = REQUEST
25-Feb-2018 13:34:33.573 [TRACE] [tocol.serialmessage.ApplicationCommandMessageClass] - Handle Message Application Command Request
25-Feb-2018 13:34:33.575 [DEBUG] [tocol.serialmessage.ApplicationCommandMessageClass] - NODE 4: Application Command Request (ALIVE:DONE)
25-Feb-2018 13:34:33.576 [DEBUG] [protocol.initialization.ZWaveNodeInitStageAdvancer] - NODE 4: Starting initialisation from DONE
25-Feb-2018 13:34:33.578 [DEBUG] [ab.binding.zwave.internal.protocol.ZWaveController] - Event Listener org.openhab.binding.zwave.internal.protocol.initialization.ZWaveNodeInitStageAdvancer@a2a603 already registered
25-Feb-2018 13:34:33.579 [DEBUG] [tocol.serialmessage.ApplicationCommandMessageClass] - NODE 4: Incoming command class WAKE_UP
25-Feb-2018 13:34:33.581 [TRACE] [tocol.serialmessage.ApplicationCommandMessageClass] - NODE 4: Found Command Class WAKE_UP, passing to handleApplicationCommandRequest
25-Feb-2018 13:34:33.582 [DEBUG] [rnal.protocol.commandclass.ZWaveWakeUpCommandClass] - NODE 4: Received Wake Up Request
25-Feb-2018 13:34:33.584 [DEBUG] [rnal.protocol.commandclass.ZWaveWakeUpCommandClass] - NODE 4: Received WAKE_UP_NOTIFICATION
25-Feb-2018 13:34:33.585 [DEBUG] [rnal.protocol.commandclass.ZWaveWakeUpCommandClass] - NODE 4: Is awake with 0 messages in the wake-up queue.
25-Feb-2018 13:34:33.587 [DEBUG] [ab.binding.zwave.internal.protocol.ZWaveController] - Notifying event listeners: ZWaveWakeUpEvent
25-Feb-2018 13:34:33.590 [DEBUG] [rg.openhab.binding.zwave.handler.ZWaveThingHandler] - NODE 4: Got an event from Z-Wave network: ZWaveWakeUpEvent
25-Feb-2018 13:34:33.622 [DEBUG] [ernal.protocol.serialmessage.ZWaveCommandProcessor] - Checking transaction complete: Sent Message: class=SendData[0x13], type=Request[0x00], priority=Immediate, dest=4, callback=147, payload=04 02 84 08
25-Feb-2018 13:34:33.623 [DEBUG] [ernal.protocol.serialmessage.ZWaveCommandProcessor] - Checking transaction complete: Recv Message: class=ApplicationCommandHandler[0x04], type=Request[0x00], priority=High, dest=255, callback=0, payload=00 04 02 84 07
25-Feb-2018 13:34:33.624 [DEBUG] [ernal.protocol.serialmessage.ZWaveCommandProcessor] - Checking transaction complete: class=ApplicationCommandHandler, callback id=147, expected=SendData, cancelled=true MISMATCH
25-Feb-2018 13:34:34.622 [DEBUG] [rnal.protocol.commandclass.ZWaveWakeUpCommandClass] - NODE 4: No more messages, go back to sleep
25-Feb-2018 13:34:34.623 [DEBUG] [rnal.protocol.commandclass.ZWaveWakeUpCommandClass] - NODE 4: Creating new message for application command WAKE_UP_NO_MORE_INFORMATION
25-Feb-2018 13:34:34.625 [TRACE] [nhab.binding.zwave.internal.protocol.SerialMessage] - NODE 4: Creating empty message of class = SendData (0x13), type = Request (0x00)
25-Feb-2018 13:34:34.626 [TRACE] [ab.binding.zwave.internal.protocol.ZWaveController] - Callback ID = 148
25-Feb-2018 13:34:34.628 [DEBUG] [ab.binding.zwave.internal.protocol.ZWaveController] - Message queued. Queue length = 1. Queue={}
25-Feb-2018 13:34:34.628 [DEBUG] [.internal.protocol.ZWaveController$ZWaveSendThread] - Took message from queue for sending. Queue length = 0
25-Feb-2018 13:34:34.629 [TRACE] [nhab.binding.zwave.internal.protocol.SerialMessage] - Calculated checksum = 0xDE
25-Feb-2018 13:34:34.632 [DEBUG] [nhab.binding.zwave.internal.protocol.SerialMessage] - Assembled message buffer = 01 09 00 13 04 02 84 08 25 94 DE
25-Feb-2018 13:34:34.635 [DEBUG] [g.openhab.binding.zwave.handler.ZWaveSerialHandler] - NODE 4: Sending REQUEST Message = 01 09 00 13 04 02 84 08 25 94 DE
25-Feb-2018 13:34:34.640 [TRACE] [wave.handler.ZWaveSerialHandler$ZWaveReceiveThread] - Received ACK
25-Feb-2018 13:34:34.642 [TRACE] [wave.handler.ZWaveSerialHandler$ZWaveReceiveThread] - Received SOF
25-Feb-2018 13:34:34.648 [DEBUG] [wave.handler.ZWaveSerialHandler$ZWaveReceiveThread] - Receive Message = 01 04 01 13 01 E8
25-Feb-2018 13:34:34.663 [TRACE] [nhab.binding.zwave.internal.protocol.SerialMessage] - NODE 255: Creating new SerialMessage from buffer = 01 04 01 13 01 E8
25-Feb-2018 13:34:34.666 [TRACE] [g.openhab.binding.zwave.handler.ZWaveSerialHandler] - Message SENT
25-Feb-2018 13:34:34.667 [TRACE] [nhab.binding.zwave.internal.protocol.SerialMessage] - Calculated checksum = 0xE8
25-Feb-2018 13:34:34.668 [TRACE] [nhab.binding.zwave.internal.protocol.SerialMessage] - NODE 255: Checksum matched
25-Feb-2018 13:34:34.670 [TRACE] [nhab.binding.zwave.internal.protocol.SerialMessage] - NODE 255: Message payload = 01
25-Feb-2018 13:34:34.672 [TRACE] [wave.handler.ZWaveSerialHandler$ZWaveReceiveThread] - Message is valid, sending ACK
25-Feb-2018 13:34:34.696 [TRACE] [wave.handler.ZWaveSerialHandler$ZWaveReceiveThread] - Response SENT
25-Feb-2018 13:34:34.698 [TRACE] [wave.handler.ZWaveSerialHandler$ZWaveReceiveThread] - Received SOF
25-Feb-2018 13:34:34.698 [DEBUG] [ab.binding.zwave.internal.protocol.ZWaveController] - Receive queue TAKE: Length=0
25-Feb-2018 13:34:34.700 [TRACE] [nhab.binding.zwave.internal.protocol.SerialMessage] - Calculated checksum = 0xE8
25-Feb-2018 13:34:34.703 [DEBUG] [nhab.binding.zwave.internal.protocol.SerialMessage] - Assembled message buffer = 01 04 01 13 01 E8
25-Feb-2018 13:34:34.703 [DEBUG] [wave.handler.ZWaveSerialHandler$ZWaveReceiveThread] - Receive Message = 01 07 00 13 94 00 00 02 7D
25-Feb-2018 13:34:34.705 [DEBUG] [ab.binding.zwave.internal.protocol.ZWaveController] - Process Message = 01 04 01 13 01 E8
25-Feb-2018 13:34:34.706 [TRACE] [nhab.binding.zwave.internal.protocol.SerialMessage] - NODE 255: Creating new SerialMessage from buffer = 01 07 00 13 94 00 00 02 7D
25-Feb-2018 13:34:34.707 [TRACE] [nhab.binding.zwave.internal.protocol.SerialMessage] - Calculated checksum = 0x7D
25-Feb-2018 13:34:34.708 [DEBUG] [ab.binding.zwave.internal.protocol.ZWaveController] - Message: class=SendData[0x13], type=Response[0x01], priority=High, dest=255, callback=0, payload=01
25-Feb-2018 13:34:34.709 [TRACE] [ab.binding.zwave.internal.protocol.ZWaveController] - Incoming Message type = RESPONSE
25-Feb-2018 13:34:34.709 [TRACE] [nhab.binding.zwave.internal.protocol.SerialMessage] - NODE 255: Checksum matched
25-Feb-2018 13:34:34.711 [TRACE] [ternal.protocol.serialmessage.SendDataMessageClass] - Handle Message Send Data Response
25-Feb-2018 13:34:34.711 [TRACE] [nhab.binding.zwave.internal.protocol.SerialMessage] - NODE 255: Message payload = 94 00 00 02
25-Feb-2018 13:34:34.712 [DEBUG] [ternal.protocol.serialmessage.SendDataMessageClass] - NODE 4: Sent Data successfully placed on stack.
25-Feb-2018 13:34:34.713 [TRACE] [wave.handler.ZWaveSerialHandler$ZWaveReceiveThread] - Message is valid, sending ACK
25-Feb-2018 13:34:34.714 [TRACE] [nhab.binding.zwave.internal.protocol.SerialMessage] - Ack Pending cleared
25-Feb-2018 13:34:34.736 [TRACE] [wave.handler.ZWaveSerialHandler$ZWaveReceiveThread] - Response SENT
25-Feb-2018 13:34:34.740 [DEBUG] [ab.binding.zwave.internal.protocol.ZWaveController] - Receive queue TAKE: Length=0
25-Feb-2018 13:34:34.742 [TRACE] [nhab.binding.zwave.internal.protocol.SerialMessage] - Calculated checksum = 0x73
25-Feb-2018 13:34:34.744 [DEBUG] [nhab.binding.zwave.internal.protocol.SerialMessage] - Assembled message buffer = 01 09 00 13 94 00 00 02 00 00 73
25-Feb-2018 13:34:34.747 [DEBUG] [ab.binding.zwave.internal.protocol.ZWaveController] - Process Message = 01 09 00 13 94 00 00 02 00 00 73
25-Feb-2018 13:34:34.750 [DEBUG] [ab.binding.zwave.internal.protocol.ZWaveController] - Message: class=SendData[0x13], type=Request[0x00], priority=High, dest=255, callback=0, payload=94 00 00 02
25-Feb-2018 13:34:34.751 [TRACE] [ab.binding.zwave.internal.protocol.ZWaveController] - Incoming Message type = REQUEST
25-Feb-2018 13:34:34.752 [TRACE] [ternal.protocol.serialmessage.SendDataMessageClass] - Handle Message Send Data Request
25-Feb-2018 13:34:34.754 [DEBUG] [ternal.protocol.serialmessage.SendDataMessageClass] - NODE 4: SendData Request. CallBack ID = 148, Status = Transmission complete and ACK received(0)
25-Feb-2018 13:34:34.756 [DEBUG] [protocol.initialization.ZWaveNodeInitStageAdvancer] - NODE 4: Starting initialisation from DONE
25-Feb-2018 13:34:34.758 [DEBUG] [ab.binding.zwave.internal.protocol.ZWaveController] - Event Listener org.openhab.binding.zwave.internal.protocol.initialization.ZWaveNodeInitStageAdvancer@a2a603 already registered
25-Feb-2018 13:34:34.760 [DEBUG] [ernal.protocol.serialmessage.ZWaveCommandProcessor] - Checking transaction complete: Sent Message: class=SendData[0x13], type=Request[0x00], priority=Immediate, dest=4, callback=148, payload=04 02 84 08
25-Feb-2018 13:34:34.763 [DEBUG] [ernal.protocol.serialmessage.ZWaveCommandProcessor] - Checking transaction complete: Recv Message: class=SendData[0x13], type=Request[0x00], priority=High, dest=255, callback=0, payload=94 00 00 02
25-Feb-2018 13:34:34.764 [DEBUG] [ernal.protocol.serialmessage.ZWaveCommandProcessor] - Checking transaction complete: class=SendData, callback id=148, expected=SendData, cancelled=false transaction complete!
25-Feb-2018 13:34:34.766 [DEBUG] [ab.binding.zwave.internal.protocol.ZWaveController] - Notifying event listeners: ZWaveTransactionCompletedEvent
25-Feb-2018 13:34:34.768 [DEBUG] [rnal.protocol.commandclass.ZWaveWakeUpCommandClass] - NODE 4: Went to sleep
25-Feb-2018 13:34:34.769 [DEBUG] [rnal.protocol.commandclass.ZWaveWakeUpCommandClass] - NODE 4: Is sleeping
25-Feb-2018 13:34:34.770 [DEBUG] [rg.openhab.binding.zwave.handler.ZWaveThingHandler] - NODE 4: Got an event from Z-Wave network: ZWaveTransactionCompletedEvent
25-Feb-2018 13:34:34.772 [DEBUG] [.internal.protocol.ZWaveController$ZWaveSendThread] - NODE 4: Response processed after 104ms/2229ms.
25-Feb-2018 13:34:34.773 [TRACE] [.internal.protocol.ZWaveController$ZWaveSendThread] - Acquired. Transaction completed permit count -> 0
25-Feb-2018 13:34:34.774 [TRACE] [ab.binding.zwave.internal.protocol.ZWaveController] - Released. Transaction completed permit count -> 0
25-Feb-2018 13:35:01.658 [TRACE] [wave.handler.ZWaveSerialHandler$ZWaveReceiveThread] - Received SOF
25-Feb-2018 13:35:01.666 [DEBUG] [wave.handler.ZWaveSerialHandler$ZWaveReceiveThread] - Receive Message = 01 10 00 04 00 03 0A 56 01 31 05 03 0A 02 F0 8E EC 18
25-Feb-2018 13:35:01.673 [TRACE] [nhab.binding.zwave.internal.protocol.SerialMessage] - NODE 255: Creating new SerialMessage from buffer = 01 10 00 04 00 03 0A 56 01 31 05 03 0A 02 F0 8E EC 18
25-Feb-2018 13:35:01.676 [TRACE] [nhab.binding.zwave.internal.protocol.SerialMessage] - Calculated checksum = 0x18
25-Feb-2018 13:35:01.679 [TRACE] [nhab.binding.zwave.internal.protocol.SerialMessage] - NODE 255: Checksum matched
25-Feb-2018 13:35:01.684 [TRACE] [nhab.binding.zwave.internal.protocol.SerialMessage] - NODE 255: Message payload = 00 03 0A 56 01 31 05 03 0A 02 F0 8E EC
25-Feb-2018 13:35:01.687 [TRACE] [wave.handler.ZWaveSerialHandler$ZWaveReceiveThread] - Message is valid, sending ACK
25-Feb-2018 13:35:01.716 [TRACE] [wave.handler.ZWaveSerialHandler$ZWaveReceiveThread] - Response SENT
25-Feb-2018 13:35:01.720 [DEBUG] [ab.binding.zwave.internal.protocol.ZWaveController] - Receive queue TAKE: Length=0
25-Feb-2018 13:35:01.722 [TRACE] [nhab.binding.zwave.internal.protocol.SerialMessage] - Calculated checksum = 0x18
25-Feb-2018 13:35:01.727 [DEBUG] [nhab.binding.zwave.internal.protocol.SerialMessage] - Assembled message buffer = 01 10 00 04 00 03 0A 56 01 31 05 03 0A 02 F0 8E EC 18
25-Feb-2018 13:35:01.732 [DEBUG] [ab.binding.zwave.internal.protocol.ZWaveController] - Process Message = 01 10 00 04 00 03 0A 56 01 31 05 03 0A 02 F0 8E EC 18
25-Feb-2018 13:35:01.738 [DEBUG] [ab.binding.zwave.internal.protocol.ZWaveController] - Message: class=ApplicationCommandHandler[0x04], type=Request[0x00], priority=High, dest=255, callback=0, payload=00 03 0A 56 01 31 05 03 0A 02 F0 8E EC
25-Feb-2018 13:35:01.740 [TRACE] [ab.binding.zwave.internal.protocol.ZWaveController] - Incoming Message type = REQUEST
25-Feb-2018 13:35:01.742 [TRACE] [tocol.serialmessage.ApplicationCommandMessageClass] - Handle Message Application Command Request
25-Feb-2018 13:35:01.744 [DEBUG] [tocol.serialmessage.ApplicationCommandMessageClass] - NODE 3: Application Command Request (ALIVE:DETAILS)
25-Feb-2018 13:35:01.747 [DEBUG] [tocol.serialmessage.ApplicationCommandMessageClass] - NODE 3: Incoming command class CRC_16_ENCAP
25-Feb-2018 13:35:01.749 [TRACE] [tocol.serialmessage.ApplicationCommandMessageClass] - NODE 3: Found Command Class CRC_16_ENCAP, passing to handleApplicationCommandRequest
25-Feb-2018 13:35:01.751 [DEBUG] [l.commandclass.ZWaveCRC16EncapsulationCommandClass] - NODE 3: Received CRC 16 Encapsulation Request
25-Feb-2018 13:35:01.753 [TRACE] [l.commandclass.ZWaveCRC16EncapsulationCommandClass] - Process CRC16 Encapsulation
25-Feb-2018 13:35:01.755 [DEBUG] [l.commandclass.ZWaveCRC16EncapsulationCommandClass] - NODE 3: Calling handleApplicationCommandRequest.
25-Feb-2018 13:35:01.758 [DEBUG] [col.commandclass.ZWaveMultiLevelSensorCommandClass] - NODE 3: Received COMMAND_CLASS_SENSOR_MULTILEVEL command V8
25-Feb-2018 13:35:01.760 [DEBUG] [col.commandclass.ZWaveMultiLevelSensorCommandClass] - NODE 3: Sensor Multi Level REPORT received
25-Feb-2018 13:35:01.762 [DEBUG] [col.commandclass.ZWaveMultiLevelSensorCommandClass] - NODE 3: Sensor Type = Luminance(3), Scale = 1
25-Feb-2018 13:35:01.765 [DEBUG] [col.commandclass.ZWaveMultiLevelSensorCommandClass] - NODE 3: Sensor Value = 752
25-Feb-2018 13:35:01.767 [DEBUG] [ab.binding.zwave.internal.protocol.ZWaveController] - Notifying event listeners: ZWaveMultiLevelSensorValueEvent
25-Feb-2018 13:35:01.769 [DEBUG] [rg.openhab.binding.zwave.handler.ZWaveThingHandler] - NODE 3: Got an event from Z-Wave network: ZWaveMultiLevelSensorValueEvent
25-Feb-2018 13:35:01.772 [DEBUG] [rg.openhab.binding.zwave.handler.ZWaveThingHandler] - NODE 3: Got a value event from Z-Wave network, endpoint = 0, command class = SENSOR_MULTILEVEL, value = 752
25-Feb-2018 13:35:01.775 [DEBUG] [rg.openhab.binding.zwave.handler.ZWaveThingHandler] - NODE 3: Updating channel state zwave:device:5a0ca91c:node3:sensor_luminance to 752 [DecimalType]
25-Feb-2018 13:35:01.781 [DEBUG] [tocol.serialmessage.ApplicationCommandMessageClass] - NODE 4: Transaction not completed: node address inconsistent. lastSent=4, incoming=255
25-Feb-2018 13:35:16.509 [TRACE] [wave.handler.ZWaveSerialHandler$ZWaveReceiveThread] - Received SOF
25-Feb-2018 13:35:16.516 [DEBUG] [wave.handler.ZWaveSerialHandler$ZWaveReceiveThread] - Receive Message = 01 09 00 04 00 04 03 20 01 00 D4
25-Feb-2018 13:35:16.521 [TRACE] [nhab.binding.zwave.internal.protocol.SerialMessage] - NODE 255: Creating new SerialMessage from buffer = 01 09 00 04 00 04 03 20 01 00 D4
25-Feb-2018 13:35:16.523 [TRACE] [nhab.binding.zwave.internal.protocol.SerialMessage] - Calculated checksum = 0xD4
25-Feb-2018 13:35:16.538 [TRACE] [nhab.binding.zwave.internal.protocol.SerialMessage] - NODE 255: Checksum matched
25-Feb-2018 13:35:16.541 [TRACE] [nhab.binding.zwave.internal.protocol.SerialMessage] - NODE 255: Message payload = 00 04 03 20 01 00
25-Feb-2018 13:35:16.543 [TRACE] [wave.handler.ZWaveSerialHandler$ZWaveReceiveThread] - Message is valid, sending ACK
25-Feb-2018 13:35:16.566 [TRACE] [wave.handler.ZWaveSerialHandler$ZWaveReceiveThread] - Response SENT
25-Feb-2018 13:35:16.569 [DEBUG] [ab.binding.zwave.internal.protocol.ZWaveController] - Receive queue TAKE: Length=0
25-Feb-2018 13:35:16.571 [TRACE] [nhab.binding.zwave.internal.protocol.SerialMessage] - Calculated checksum = 0xD4
25-Feb-2018 13:35:16.576 [DEBUG] [nhab.binding.zwave.internal.protocol.SerialMessage] - Assembled message buffer = 01 09 00 04 00 04 03 20 01 00 D4
25-Feb-2018 13:35:16.582 [DEBUG] [ab.binding.zwave.internal.protocol.ZWaveController] - Process Message = 01 09 00 04 00 04 03 20 01 00 D4
25-Feb-2018 13:35:16.587 [DEBUG] [ab.binding.zwave.internal.protocol.ZWaveController] - Message: class=ApplicationCommandHandler[0x04], type=Request[0x00], priority=High, dest=255, callback=0, payload=00 04 03 20 01 00
25-Feb-2018 13:35:16.590 [TRACE] [ab.binding.zwave.internal.protocol.ZWaveController] - Incoming Message type = REQUEST
25-Feb-2018 13:35:16.593 [TRACE] [tocol.serialmessage.ApplicationCommandMessageClass] - Handle Message Application Command Request
25-Feb-2018 13:35:16.595 [DEBUG] [tocol.serialmessage.ApplicationCommandMessageClass] - NODE 4: Application Command Request (ALIVE:DONE)
25-Feb-2018 13:35:16.598 [DEBUG] [protocol.initialization.ZWaveNodeInitStageAdvancer] - NODE 4: Starting initialisation from DONE
25-Feb-2018 13:35:16.600 [DEBUG] [ab.binding.zwave.internal.protocol.ZWaveController] - Event Listener org.openhab.binding.zwave.internal.protocol.initialization.ZWaveNodeInitStageAdvancer@a2a603 already registered
25-Feb-2018 13:35:16.602 [DEBUG] [tocol.serialmessage.ApplicationCommandMessageClass] - NODE 4: Incoming command class BASIC
25-Feb-2018 13:35:16.604 [TRACE] [tocol.serialmessage.ApplicationCommandMessageClass] - NODE 4: Found Command Class BASIC, passing to handleApplicationCommandRequest
25-Feb-2018 13:35:16.605 [DEBUG] [ernal.protocol.commandclass.ZWaveBasicCommandClass] - NODE 4: Received Basic Request
25-Feb-2018 13:35:16.606 [DEBUG] [ernal.protocol.commandclass.ZWaveBasicCommandClass] - NODE 4: Basic Set sent to the controller will be processed as Basic Report
25-Feb-2018 13:35:16.608 [DEBUG] [ernal.protocol.commandclass.ZWaveBasicCommandClass] - NODE 4: Basic report, value = 0x00
25-Feb-2018 13:35:16.609 [DEBUG] [ab.binding.zwave.internal.protocol.ZWaveController] - Notifying event listeners: ZWaveCommandClassValueEvent
25-Feb-2018 13:35:16.611 [DEBUG] [rg.openhab.binding.zwave.handler.ZWaveThingHandler] - NODE 4: Got an event from Z-Wave network: ZWaveCommandClassValueEvent
25-Feb-2018 13:35:16.612 [DEBUG] [rg.openhab.binding.zwave.handler.ZWaveThingHandler] - NODE 4: Got a value event from Z-Wave network, endpoint = 0, command class = BASIC, value = 0
25-Feb-2018 13:35:16.614 [DEBUG] [rg.openhab.binding.zwave.handler.ZWaveThingHandler] - NODE 4: Updating channel state zwave:device:5a0ca91c:node4:sensor_binary to OFF [OnOffType]
25-Feb-2018 13:35:16.619 [DEBUG] [ernal.protocol.serialmessage.ZWaveCommandProcessor] - Checking transaction complete: Sent Message: class=SendData[0x13], type=Request[0x00], priority=Immediate, dest=4, callback=148, payload=04 02 84 08
25-Feb-2018 13:35:16.622 [DEBUG] [ernal.protocol.serialmessage.ZWaveCommandProcessor] - Checking transaction complete: Recv Message: class=ApplicationCommandHandler[0x04], type=Request[0x00], priority=High, dest=255, callback=0, payload=00 04 03 20 01 00
25-Feb-2018 13:35:16.624 [DEBUG] [ernal.protocol.serialmessage.ZWaveCommandProcessor] - Checking transaction complete: class=ApplicationCommandHandler, callback id=148, expected=SendData, cancelled=false MISMATCH
25-Feb-2018 13:35:56.698 [TRACE] [wave.handler.ZWaveSerialHandler$ZWaveReceiveThread] - Received SOF
25-Feb-2018 13:35:56.704 [DEBUG] [wave.handler.ZWaveSerialHandler$ZWaveReceiveThread] - Receive Message = 01 09 00 04 00 04 03 20 01 FF 2B
25-Feb-2018 13:35:56.708 [TRACE] [nhab.binding.zwave.internal.protocol.SerialMessage] - NODE 255: Creating new SerialMessage from buffer = 01 09 00 04 00 04 03 20 01 FF 2B
25-Feb-2018 13:35:56.711 [TRACE] [nhab.binding.zwave.internal.protocol.SerialMessage] - Calculated checksum = 0x2B
25-Feb-2018 13:35:56.712 [TRACE] [nhab.binding.zwave.internal.protocol.SerialMessage] - NODE 255: Checksum matched
25-Feb-2018 13:35:56.715 [TRACE] [nhab.binding.zwave.internal.protocol.SerialMessage] - NODE 255: Message payload = 00 04 03 20 01 FF
25-Feb-2018 13:35:56.717 [TRACE] [wave.handler.ZWaveSerialHandler$ZWaveReceiveThread] - Message is valid, sending ACK
25-Feb-2018 13:35:56.746 [TRACE] [wave.handler.ZWaveSerialHandler$ZWaveReceiveThread] - Response SENT
25-Feb-2018 13:35:56.749 [DEBUG] [ab.binding.zwave.internal.protocol.ZWaveController] - Receive queue TAKE: Length=0
25-Feb-2018 13:35:56.751 [TRACE] [nhab.binding.zwave.internal.protocol.SerialMessage] - Calculated checksum = 0x2B
25-Feb-2018 13:35:56.756 [DEBUG] [nhab.binding.zwave.internal.protocol.SerialMessage] - Assembled message buffer = 01 09 00 04 00 04 03 20 01 FF 2B
25-Feb-2018 13:35:56.760 [DEBUG] [ab.binding.zwave.internal.protocol.ZWaveController] - Process Message = 01 09 00 04 00 04 03 20 01 FF 2B
25-Feb-2018 13:35:56.764 [DEBUG] [ab.binding.zwave.internal.protocol.ZWaveController] - Message: class=ApplicationCommandHandler[0x04], type=Request[0x00], priority=High, dest=255, callback=0, payload=00 04 03 20 01 FF
25-Feb-2018 13:35:56.765 [TRACE] [ab.binding.zwave.internal.protocol.ZWaveController] - Incoming Message type = REQUEST
25-Feb-2018 13:35:56.767 [TRACE] [tocol.serialmessage.ApplicationCommandMessageClass] - Handle Message Application Command Request
25-Feb-2018 13:35:56.769 [DEBUG] [tocol.serialmessage.ApplicationCommandMessageClass] - NODE 4: Application Command Request (ALIVE:DONE)
25-Feb-2018 13:35:56.770 [DEBUG] [protocol.initialization.ZWaveNodeInitStageAdvancer] - NODE 4: Starting initialisation from DONE
25-Feb-2018 13:35:56.772 [DEBUG] [ab.binding.zwave.internal.protocol.ZWaveController] - Event Listener org.openhab.binding.zwave.internal.protocol.initialization.ZWaveNodeInitStageAdvancer@a2a603 already registered
25-Feb-2018 13:35:56.774 [DEBUG] [tocol.serialmessage.ApplicationCommandMessageClass] - NODE 4: Incoming command class BASIC
25-Feb-2018 13:35:56.776 [TRACE] [tocol.serialmessage.ApplicationCommandMessageClass] - NODE 4: Found Command Class BASIC, passing to handleApplicationCommandRequest
25-Feb-2018 13:35:56.777 [DEBUG] [ernal.protocol.commandclass.ZWaveBasicCommandClass] - NODE 4: Received Basic Request
25-Feb-2018 13:35:56.779 [DEBUG] [ernal.protocol.commandclass.ZWaveBasicCommandClass] - NODE 4: Basic Set sent to the controller will be processed as Basic Report
25-Feb-2018 13:35:56.780 [DEBUG] [ernal.protocol.commandclass.ZWaveBasicCommandClass] - NODE 4: Basic report, value = 0xFF
25-Feb-2018 13:35:56.782 [DEBUG] [ab.binding.zwave.internal.protocol.ZWaveController] - Notifying event listeners: ZWaveCommandClassValueEvent
25-Feb-2018 13:35:56.783 [DEBUG] [rg.openhab.binding.zwave.handler.ZWaveThingHandler] - NODE 4: Got an event from Z-Wave network: ZWaveCommandClassValueEvent
25-Feb-2018 13:35:56.785 [DEBUG] [rg.openhab.binding.zwave.handler.ZWaveThingHandler] - NODE 4: Got a value event from Z-Wave network, endpoint = 0, command class = BASIC, value = 255
25-Feb-2018 13:35:56.788 [DEBUG] [rg.openhab.binding.zwave.handler.ZWaveThingHandler] - NODE 4: Updating channel state zwave:device:5a0ca91c:node4:sensor_binary to ON [OnOffType]
25-Feb-2018 13:35:56.794 [DEBUG] [ernal.protocol.serialmessage.ZWaveCommandProcessor] - Checking transaction complete: Sent Message: class=SendData[0x13], type=Request[0x00], priority=Immediate, dest=4, callback=148, payload=04 02 84 08
25-Feb-2018 13:35:56.803 [DEBUG] [ernal.protocol.serialmessage.ZWaveCommandProcessor] - Checking transaction complete: Recv Message: class=ApplicationCommandHandler[0x04], type=Request[0x00], priority=High, dest=255, callback=0, payload=00 04 03 20 01 FF
25-Feb-2018 13:35:56.805 [DEBUG] [ernal.protocol.serialmessage.ZWaveCommandProcessor] - Checking transaction complete: class=ApplicationCommandHandler, callback id=148, expected=SendData, cancelled=false MISMATCH
