I’ve setup a simple connection to my DSC1832 system via EnvisaLink3 and the dscalarm-1.8.0 binding, but I can’t seem to get any status messages from the panel. I’ve limited my configuration to show panel and partition status along with a couple of switchs. OpenHAB’s connection to the Envisalink shows up on its interface after I start OpenHAB.
Here’s where the problems appear to start:
16:34:20.027 [WARN ] [.o.u.w.i.render.SwitchRenderer:70 ] - Cannot determine item type of 'PANEL_CONNECTION'
org.openhab.core.items.ItemNotFoundException: Item 'PANEL_CONNECTION' could not be found in the item registry
at org.openhab.core.internal.items.ItemRegistryImpl.getItem(ItemRegistryImpl.java:80) ~[na:na]
at org.openhab.ui.internal.items.ItemUIRegistryImpl.getItem(ItemUIRegistryImpl.java:554) ~[na:na]
at org.openhab.ui.webapp.internal.render.SwitchRenderer.renderWidget(SwitchRenderer.java:57) ~[org.openhab.ui.webapp_1.8.0.jar:na]
16:34:20.192 [ERROR] [o.u.i.items.ItemUIRegistryImpl:438 ] - Cannot retrieve item PANEL_CONNECTION for widget org.openhab.model.sitemap.Switch
16:34:20.194 [ERROR] [o.u.i.items.ItemUIRegistryImpl:438 ] - Cannot retrieve item PANEL_CONNECTION for widget org.openhab.model.sitemap.Switch
16:34:20.196 [ERROR] [o.u.i.items.ItemUIRegistryImpl:438 ] - Cannot retrieve item PANEL_CONNECTION for widget org.openhab.model.sitemap.Switch
16:34:20.199 [ERROR] [o.u.i.items.ItemUIRegistryImpl:438 ] - Cannot retrieve item PANEL_MESSAGE for widget org.openhab.model.sitemap.Text
16:34:20.201 [ERROR] [o.u.i.items.ItemUIRegistryImpl:438 ] - Cannot retrieve item PANEL_MESSAGE for widget org.openhab.model.sitemap.Text
16:34:20.203 [ERROR] [o.u.i.items.ItemUIRegistryImpl:438 ] - Cannot retrieve item PANEL_TIME for widget org.openhab.model.sitemap.Text
16:34:20.206 [ERROR] [o.u.i.items.ItemUIRegistryImpl:438 ] - Cannot retrieve item PANEL_TIME for widget org.openhab.model.sitemap.Text
16:34:20.209 [ERROR] [o.u.i.items.ItemUIRegistryImpl:438 ] - Cannot retrieve item PANEL_TIME for widget org.openhab.model.sitemap.Text
16:34:20.216 [WARN ] [.o.u.w.i.render.SwitchRenderer:70 ] - Cannot determine item type of 'PANEL_TIME_STAMP'
org.openhab.core.items.ItemNotFoundException: Item 'PANEL_TIME_STAMP' could not be found in the item registry
