Iāve been tinkering with the DSC binding without much success but I know it will be awesome once I figure it out!
Iām getting errors (DSC Alarm bridge handler not available) when Openhab2 starts and I donāt have a clue how to resolve them. I can see zone open and close events in the log so at least Iām getting data from the alarm panel.
Any suggestions?
Does āMyBridgeNameā from the items and sitemap files need to be replaced with the string of characters from the the Envisalink Thing in the PaperUI ? I tried that string (60c45902) and the ip address of the EVL(192_168_1_6) but still got the same errors.
In /var/log/openhab2/events.log I noticed this line:
2017-02-06 16:50:40.737 [hingStatusInfoChangedEvent] - ādscalarm:partition:60c45902:partition1ā changed from UNINITIALIZED to UNINITIALIZED (HANDLER_MISSING_ERROR)
Does it matter that [hingStatusInfoChangedEvent] has Thing spelled without the āTā
Yes in the items file the āMyBridgeNameā needs to be set to the name of the bridge as shown in the PaperUI. In this case it looks like you would use 60c45902. In the Sitemap file you only need to use the items name. Also, make sure no other device is connecting to your Envisalink. Hope this helps.
Thanks for the help Russell.
As far as I know the openhab server(192.168.1.3) is the only thing connecting to the envisalink 4(192.168.1.6). The only way I know to check this is via EVL4 generated webpage on the ānetworkā tab. At the bottom it lists one Client, the Openhab server at 192.168.1.3
Iāve made the file changes you suggested and drastically reduced the contents of my Items file and deleted my DSC sitemap for simplicity.
In PaperUI Iāve removed all items except:
Envisalink (dscalarm:envisalink:60c45902)
Panel (dscalarm:panel:60c45902:panel)
Keypad (dscalarm:keypad:60c45902:keypad)
Zone 9 (dscalarm:zone:60c45902:zone9)
I feel like Iām missing something fundamentalā¦maybe I missed something in the install?
Hereās the dscalarm.items and logsā¦
pi@OpenHAB:~ $ java -version
java version "1.8.0_121"
Java(TM) SE Runtime Environment (build 1.8.0_121-b13)
Java HotSpot(TM) Client VM (build 25.121-b13, mixed mode)
pi@OpenHAB:~ $
pi@OpenHAB:~ $ cat /etc/openhab2/items/dscalarm.items
/* DSC Alarm Config */
/* DSC Alarm Items */
Switch BRIDGE_CONNECTION {channel="dscalarm:envisalink:60c45902:bridge_reset"}
/* DSC Alarm Zones Items */
Contact ZONE9_STATUS "Laundry Room Door (Zone 9)" <door> (DSCAlarmZones, Laundry, DSCAlarmDoorWindow) {channel="dscalarm:zone:60c45902:zone9:zone_status"}
pi@OpenHAB:~ $ cat /var/log/openhab2/openhab.log
2017-02-07 09:05:36.196 [INFO ] [el.core.internal.ModelRepositoryImpl] - Loading model 'dscalarm.items'
2017-02-07 09:05:45.459 [INFO ] [.dashboard.internal.DashboardService] - Started dashboard at /start
2017-02-07 09:05:46.349 [INFO ] [basic.internal.servlet.WebAppServlet] - Started Basic UI at /basicui/app
2017-02-07 09:05:46.554 [INFO ] [arthome.ui.paper.internal.PaperUIApp] - Started Paper UI at /paperui
2017-02-07 09:05:46.989 [INFO ] [panel.internal.HABPanelDashboardTile] - Started HABPanel at /habpanel
2017-02-07 09:05:48.226 [WARN ] [rm.handler.DSCAlarmBaseBridgeHandler] - No bridge commands defined.
2017-02-07 09:05:48.261 [ERROR] [rm.handler.DSCAlarmBaseBridgeHandler] - Not Connected to the DSC Alarm!
2017-02-07 09:05:48.357 [WARN ] [ng.dscalarm.handler.ZoneThingHandler] - DSC Alarm bridge handler not available. Cannot handle command without bridge.
2017-02-07 09:05:48.359 [WARN ] [ng.dscalarm.handler.ZoneThingHandler] - DSC Alarm bridge handler not available. Cannot handle command without bridge.
2017-02-07 09:05:48.362 [WARN ] [g.dscalarm.handler.PanelThingHandler] - DSC Alarm bridge handler not available. Cannot handle command without bridge.
2017-02-07 09:05:48.371 [WARN ] [ng.dscalarm.handler.ZoneThingHandler] - DSC Alarm bridge handler not available. Cannot handle command without bridge.
2017-02-07 09:05:48.373 [WARN ] [ng.dscalarm.handler.ZoneThingHandler] - DSC Alarm bridge handler not available. Cannot handle command without bridge.
2017-02-07 09:05:48.373 [WARN ] [g.dscalarm.handler.PanelThingHandler] - DSC Alarm bridge handler not available. Cannot handle command without bridge.
2017-02-07 09:05:48.375 [WARN ] [ng.dscalarm.handler.ZoneThingHandler] - DSC Alarm bridge handler not available. Cannot handle command without bridge.
2017-02-07 09:05:48.377 [WARN ] [ng.dscalarm.handler.ZoneThingHandler] - DSC Alarm bridge handler not available. Cannot handle command without bridge.
2017-02-07 09:05:48.379 [WARN ] [ng.dscalarm.handler.ZoneThingHandler] - DSC Alarm bridge handler not available. Cannot handle command without bridge.
2017-02-07 09:05:48.382 [WARN ] [g.dscalarm.handler.PanelThingHandler] - DSC Alarm bridge handler not available. Cannot handle command without bridge.
2017-02-07 09:05:48.385 [WARN ] [g.dscalarm.handler.PanelThingHandler] - DSC Alarm bridge handler not available. Cannot handle command without bridge.
2017-02-07 09:05:48.387 [WARN ] [g.dscalarm.handler.PanelThingHandler] - DSC Alarm bridge handler not available. Cannot handle command without bridge.
2017-02-07 09:05:48.398 [WARN ] [g.dscalarm.handler.PanelThingHandler] - DSC Alarm bridge handler not available. Cannot handle command without bridge.
2017-02-07 09:05:48.402 [WARN ] [g.dscalarm.handler.PanelThingHandler] - DSC Alarm bridge handler not available. Cannot handle command without bridge.
2017-02-07 09:05:48.407 [WARN ] [g.dscalarm.handler.PanelThingHandler] - DSC Alarm bridge handler not available. Cannot handle command without bridge.
2017-02-07 09:05:48.412 [WARN ] [g.dscalarm.handler.PanelThingHandler] - DSC Alarm bridge handler not available. Cannot handle command without bridge.
2017-02-07 09:05:48.417 [WARN ] [g.dscalarm.handler.PanelThingHandler] - DSC Alarm bridge handler not available. Cannot handle command without bridge.
2017-02-07 09:05:48.425 [WARN ] [g.dscalarm.handler.PanelThingHandler] - DSC Alarm bridge handler not available. Cannot handle command without bridge.
pi@OpenHAB:~ $
pi@OpenHAB:~ $ cat /var/log/openhab2/events.log
2017-02-07 09:05:42.050 [ItemChannelLinkAddedEvent ] - Link 'BRIDGE_CONNECTION-dscalarm:envisalink:60c45902:bridge_reset' has been added.
2017-02-07 09:05:42.059 [ItemChannelLinkAddedEvent ] - Link 'ZONE9_STATUS-dscalarm:zone:60c45902:zone9:zone_status' has been added.
2017-02-07 09:05:42.751 [ItemChannelLinkAddedEvent ] - Link 'dscalarm_zone_60c45902_zone9_zone_bypass_mode-dscalarm:zone:60c45902:zone9:zone_bypass_mode' has been added.
2017-02-07 09:05:42.759 [ItemChannelLinkAddedEvent ] - Link 'dscalarm_panel_60c45902_panel_panel_message-dscalarm:panel:60c45902:panel:panel_message' has been added.
2017-02-07 09:05:42.765 [ItemChannelLinkAddedEvent ] - Link 'dscalarm_panel_60c45902_panel_panel_zone_low_battery-dscalarm:panel:60c45902:panel:panel_zone_low_battery' has been added.
2017-02-07 09:05:42.771 [ItemChannelLinkAddedEvent ] - Link 'dscalarm_panel_60c45902_panel_panel_fire_key_alarm-dscalarm:panel:60c45902:panel:panel_fire_key_alarm' has been added.
2017-02-07 09:05:42.774 [ItemChannelLinkAddedEvent ] - Link 'dscalarm_keypad_60c45902_keypad_keypad_fire_led-dscalarm:keypad:60c45902:keypad:keypad_fire_led' has been added.
2017-02-07 09:05:42.789 [ItemChannelLinkAddedEvent ] - Link 'dscalarm_panel_60c45902_panel_panel_trouble_led-dscalarm:panel:60c45902:panel:panel_trouble_led' has been added.
2017-02-07 09:05:42.793 [ItemChannelLinkAddedEvent ] - Link 'dscalarm_panel_60c45902_panel_panel_telephone_trouble-dscalarm:panel:60c45902:panel:panel_telephone_trouble' has been added.
2017-02-07 09:05:42.796 [ItemChannelLinkAddedEvent ] - Link 'dscalarm_zone_60c45902_zone9_zone_in_alarm-dscalarm:zone:60c45902:zone9:zone_in_alarm' has been added.
2017-02-07 09:05:42.799 [ItemChannelLinkAddedEvent ] - Link 'dscalarm_panel_60c45902_panel_panel_time_broadcast-dscalarm:panel:60c45902:panel:panel_time_broadcast' has been added.
2017-02-07 09:05:42.802 [ItemChannelLinkAddedEvent ] - Link 'dscalarm_keypad_60c45902_keypad_keypad_trouble_led-dscalarm:keypad:60c45902:keypad:keypad_trouble_led' has been added.
2017-02-07 09:05:42.805 [ItemChannelLinkAddedEvent ] - Link 'dscalarm_panel_60c45902_panel_panel_system_error-dscalarm:panel:60c45902:panel:panel_system_error' has been added.
2017-02-07 09:05:42.819 [ItemChannelLinkAddedEvent ] - Link 'dscalarm_zone_60c45902_zone9_zone_fault-dscalarm:zone:60c45902:zone9:zone_fault' has been added.
2017-02-07 09:05:42.823 [ItemChannelLinkAddedEvent ] - Link 'dscalarm_panel_60c45902_panel_panel_zone_fault-dscalarm:panel:60c45902:panel:panel_zone_fault' has been added.
2017-02-07 09:05:42.828 [ItemChannelLinkAddedEvent ] - Link 'dscalarm_keypad_60c45902_keypad_keypad_program_led-dscalarm:keypad:60c45902:keypad:keypad_program_led' has been added.
2017-02-07 09:05:42.831 [ItemChannelLinkAddedEvent ] - Link 'dscalarm_envisalink_60c45902_bridge_reset-dscalarm:envisalink:60c45902:bridge_reset' has been added.
2017-02-07 09:05:42.835 [ItemChannelLinkAddedEvent ] - Link 'dscalarm_keypad_60c45902_keypad_keypad_lcd_update-dscalarm:keypad:60c45902:keypad:keypad_lcd_update' has been added.
2017-02-07 09:05:42.838 [ItemChannelLinkAddedEvent ] - Link 'dscalarm_panel_60c45902_panel_panel_ftc_trouble-dscalarm:panel:60c45902:panel:panel_ftc_trouble' has been added.
2017-02-07 09:05:42.841 [ItemChannelLinkAddedEvent ] - Link 'dscalarm_panel_60c45902_panel_panel_zone_tamper-dscalarm:panel:60c45902:panel:panel_zone_tamper' has been added.
2017-02-07 09:05:42.848 [ItemChannelLinkAddedEvent ] - Link 'dscalarm_panel_60c45902_panel_panel_aux_input_alarm-dscalarm:panel:60c45902:panel:panel_aux_input_alarm' has been added.
2017-02-07 09:05:42.854 [ItemChannelLinkAddedEvent ] - Link 'dscalarm_zone_60c45902_zone9_zone_status-dscalarm:zone:60c45902:zone9:zone_status' has been added.
2017-02-07 09:05:42.861 [ItemChannelLinkAddedEvent ] - Link 'dscalarm_keypad_60c45902_keypad_keypad_backlight_led-dscalarm:keypad:60c45902:keypad:keypad_backlight_led' has been added.
2017-02-07 09:05:42.867 [ItemChannelLinkAddedEvent ] - Link 'dscalarm_panel_60c45902_panel_panel_service_required-dscalarm:panel:60c45902:panel:panel_service_required' has been added.
2017-02-07 09:05:42.874 [ItemChannelLinkAddedEvent ] - Link 'dscalarm_zone_60c45902_zone9_zone_tamper-dscalarm:zone:60c45902:zone9:zone_tamper' has been added.
2017-02-07 09:05:42.881 [ItemChannelLinkAddedEvent ] - Link 'dscalarm_keypad_60c45902_keypad_keypad_lcd_cursor-dscalarm:keypad:60c45902:keypad:keypad_lcd_cursor' has been added.
2017-02-07 09:05:42.887 [ItemChannelLinkAddedEvent ] - Link 'dscalarm_panel_60c45902_panel_panel_time-dscalarm:panel:60c45902:panel:panel_time' has been added.
2017-02-07 09:05:42.893 [ItemChannelLinkAddedEvent ] - Link 'dscalarm_keypad_60c45902_keypad_keypad_ac_led-dscalarm:keypad:60c45902:keypad:keypad_ac_led' has been added.
2017-02-07 09:05:42.898 [ItemChannelLinkAddedEvent ] - Link 'dscalarm_panel_60c45902_panel_panel_panic_key_alarm-dscalarm:panel:60c45902:panel:panel_panic_key_alarm' has been added.
2017-02-07 09:05:42.905 [ItemChannelLinkAddedEvent ] - Link 'dscalarm_panel_60c45902_panel_panel_ac_trouble-dscalarm:panel:60c45902:panel:panel_ac_trouble' has been added.
2017-02-07 09:05:42.911 [ItemChannelLinkAddedEvent ] - Link 'dscalarm_panel_60c45902_panel_panel_time_loss-dscalarm:panel:60c45902:panel:panel_time_loss' has been added.
2017-02-07 09:05:42.918 [ItemChannelLinkAddedEvent ] - Link 'dscalarm_keypad_60c45902_keypad_keypad_armed_led-dscalarm:keypad:60c45902:keypad:keypad_armed_led' has been added.
2017-02-07 09:05:42.924 [ItemChannelLinkAddedEvent ] - Link 'dscalarm_zone_60c45902_zone9_zone_message-dscalarm:zone:60c45902:zone9:zone_message' has been added.
2017-02-07 09:05:42.931 [ItemChannelLinkAddedEvent ] - Link 'dscalarm_zone_60c45902_zone9_zone_tripped-dscalarm:zone:60c45902:zone9:zone_tripped' has been added.
2017-02-07 09:05:42.937 [ItemChannelLinkAddedEvent ] - Link 'dscalarm_panel_60c45902_panel_panel_trouble_message-dscalarm:panel:60c45902:panel:panel_trouble_message' has been added.
2017-02-07 09:05:42.943 [ItemChannelLinkAddedEvent ] - Link 'dscalarm_panel_60c45902_panel_panel_time_stamp-dscalarm:panel:60c45902:panel:panel_time_stamp' has been added.
2017-02-07 09:05:42.950 [ItemChannelLinkAddedEvent ] - Link 'dscalarm_panel_60c45902_panel_panel_command-dscalarm:panel:60c45902:panel:panel_command' has been added.
2017-02-07 09:05:42.954 [ItemChannelLinkAddedEvent ] - Link 'dscalarm_panel_60c45902_panel_panel_aux_key_alarm-dscalarm:panel:60c45902:panel:panel_aux_key_alarm' has been added.
2017-02-07 09:05:42.957 [ItemChannelLinkAddedEvent ] - Link 'dscalarm_keypad_60c45902_keypad_keypad_memory_led-dscalarm:keypad:60c45902:keypad:keypad_memory_led' has been added.
2017-02-07 09:05:42.961 [ItemChannelLinkAddedEvent ] - Link 'dscalarm_keypad_60c45902_keypad_keypad_ready_led-dscalarm:keypad:60c45902:keypad:keypad_ready_led' has been added.
2017-02-07 09:05:42.965 [ItemChannelLinkAddedEvent ] - Link 'dscalarm_keypad_60c45902_keypad_keypad_bypass_led-dscalarm:keypad:60c45902:keypad:keypad_bypass_led' has been added.
2017-02-07 09:05:43.327 [ThingAddedEvent ] - Thing 'dscalarm:panel:60c45902:panel' has been added.
2017-02-07 09:05:43.331 [ThingAddedEvent ] - Thing 'dscalarm:envisalink:60c45902' has been added.
2017-02-07 09:05:43.355 [ThingAddedEvent ] - Thing 'dscalarm:zone:60c45902:zone9' has been added.
2017-02-07 09:05:43.396 [ThingAddedEvent ] - Thing 'dscalarm:keypad:60c45902:keypad' has been added.
2017-02-07 09:05:46.698 [hingStatusInfoChangedEvent] - 'dscalarm:panel:60c45902:panel' changed from UNINITIALIZED to UNINITIALIZED (HANDLER_MISSING_ERROR)
2017-02-07 09:05:46.811 [hingStatusInfoChangedEvent] - 'dscalarm:zone:60c45902:zone9' changed from UNINITIALIZED to UNINITIALIZED (HANDLER_MISSING_ERROR)
2017-02-07 09:05:46.815 [hingStatusInfoChangedEvent] - 'dscalarm:keypad:60c45902:keypad' changed from UNINITIALIZED to UNINITIALIZED (HANDLER_MISSING_ERROR)
2017-02-07 09:05:47.236 [hingStatusInfoChangedEvent] - 'dscalarm:envisalink:60c45902' changed from UNINITIALIZED to INITIALIZING
2017-02-07 09:05:48.221 [hingStatusInfoChangedEvent] - 'dscalarm:envisalink:60c45902' changed from INITIALIZING to OFFLINE
2017-02-07 09:05:48.346 [hingStatusInfoChangedEvent] - 'dscalarm:zone:60c45902:zone9' changed from UNINITIALIZED (HANDLER_MISSING_ERROR) to INITIALIZING
2017-02-07 09:05:48.350 [hingStatusInfoChangedEvent] - 'dscalarm:panel:60c45902:panel' changed from UNINITIALIZED (HANDLER_MISSING_ERROR) to INITIALIZING
2017-02-07 09:05:48.352 [hingStatusInfoChangedEvent] - 'dscalarm:zone:60c45902:zone9' changed from INITIALIZING to OFFLINE
2017-02-07 09:05:48.357 [hingStatusInfoChangedEvent] - 'dscalarm:panel:60c45902:panel' changed from INITIALIZING to OFFLINE
2017-02-07 09:05:48.391 [hingStatusInfoChangedEvent] - 'dscalarm:keypad:60c45902:keypad' changed from UNINITIALIZED (HANDLER_MISSING_ERROR) to INITIALIZING
2017-02-07 09:05:48.419 [hingStatusInfoChangedEvent] - 'dscalarm:envisalink:60c45902' changed from OFFLINE to ONLINE
2017-02-07 09:05:48.431 [hingStatusInfoChangedEvent] - 'dscalarm:zone:60c45902:zone9' changed from OFFLINE to ONLINE
2017-02-07 09:05:48.438 [hingStatusInfoChangedEvent] - 'dscalarm:keypad:60c45902:keypad' changed from INITIALIZING to OFFLINE
2017-02-07 09:05:48.440 [hingStatusInfoChangedEvent] - 'dscalarm:panel:60c45902:panel' changed from OFFLINE to ONLINE
2017-02-07 09:05:48.452 [hingStatusInfoChangedEvent] - 'dscalarm:keypad:60c45902:keypad' changed from OFFLINE to ONLINE
2017-02-07 09:05:48.513 [ItemStateChangedEvent ] - dscalarm_keypad_60c45902_keypad_keypad_ready_led changed from NULL to 0
2017-02-07 09:05:48.517 [ItemStateChangedEvent ] - dscalarm_keypad_60c45902_keypad_keypad_armed_led changed from NULL to 0
2017-02-07 09:05:48.522 [ItemStateChangedEvent ] - dscalarm_keypad_60c45902_keypad_keypad_memory_led changed from NULL to 0
2017-02-07 09:05:48.529 [ItemStateChangedEvent ] - dscalarm_panel_60c45902_panel_panel_trouble_message changed from NULL to
2017-02-07 09:05:48.536 [ItemStateChangedEvent ] - dscalarm_keypad_60c45902_keypad_keypad_fire_led changed from NULL to 0
2017-02-07 09:05:48.542 [ItemStateChangedEvent ] - dscalarm_panel_60c45902_panel_panel_telephone_trouble changed from NULL to OFF
2017-02-07 09:05:48.551 [ItemStateChangedEvent ] - dscalarm_panel_60c45902_panel_panel_ftc_trouble changed from NULL to OFF
2017-02-07 09:05:48.556 [ItemStateChangedEvent ] - dscalarm_panel_60c45902_panel_panel_zone_fault changed from NULL to OFF
2017-02-07 09:05:48.562 [ItemStateChangedEvent ] - dscalarm_panel_60c45902_panel_panel_zone_tamper changed from NULL to OFF
2017-02-07 09:05:48.567 [ItemStateChangedEvent ] - dscalarm_panel_60c45902_panel_panel_time_loss changed from NULL to OFF
2017-02-07 09:05:48.571 [ItemStateChangedEvent ] - ZONE9_STATUS changed from NULL to CLOSED
2017-02-07 09:05:48.575 [ItemStateChangedEvent ] - dscalarm_panel_60c45902_panel_panel_message changed from NULL to
2017-02-07 09:05:48.577 [ItemStateChangedEvent ] - dscalarm_keypad_60c45902_keypad_keypad_ac_led changed from NULL to 0
2017-02-07 09:05:48.580 [ItemStateChangedEvent ] - dscalarm_keypad_60c45902_keypad_keypad_lcd_update changed from NULL to
2017-02-07 09:05:48.582 [ItemStateChangedEvent ] - dscalarm_panel_60c45902_panel_panel_command changed from NULL to 0
2017-02-07 09:05:48.587 [ItemStateChangedEvent ] - dscalarm_keypad_60c45902_keypad_keypad_lcd_cursor changed from NULL to
2017-02-07 09:05:48.589 [ItemStateChangedEvent ] - dscalarm_panel_60c45902_panel_panel_system_error changed from NULL to
2017-02-07 09:05:48.591 [ItemStateChangedEvent ] - dscalarm_zone_60c45902_zone9_zone_status changed from NULL to CLOSED
2017-02-07 09:05:48.594 [ItemStateChangedEvent ] - dscalarm_keypad_60c45902_keypad_keypad_bypass_led changed from NULL to 0
2017-02-07 09:05:48.594 [ItemStateChangedEvent ] - dscalarm_zone_60c45902_zone9_zone_message changed from NULL to
2017-02-07 09:05:48.598 [ItemStateChangedEvent ] - dscalarm_keypad_60c45902_keypad_keypad_trouble_led changed from NULL to 0
2017-02-07 09:05:48.602 [ItemStateChangedEvent ] - dscalarm_panel_60c45902_panel_panel_trouble_led changed from NULL to OFF
2017-02-07 09:05:48.602 [ItemStateChangedEvent ] - dscalarm_zone_60c45902_zone9_zone_bypass_mode changed from NULL to OFF
2017-02-07 09:05:48.606 [ItemStateChangedEvent ] - dscalarm_zone_60c45902_zone9_zone_in_alarm changed from NULL to OFF
2017-02-07 09:05:48.606 [ItemStateChangedEvent ] - dscalarm_keypad_60c45902_keypad_keypad_program_led changed from NULL to 0
2017-02-07 09:05:48.610 [ItemStateChangedEvent ] - dscalarm_zone_60c45902_zone9_zone_tamper changed from NULL to OFF
2017-02-07 09:05:48.612 [ItemStateChangedEvent ] - dscalarm_panel_60c45902_panel_panel_service_required changed from NULL to OFF
2017-02-07 09:05:48.616 [ItemStateChangedEvent ] - dscalarm_zone_60c45902_zone9_zone_fault changed from NULL to OFF
2017-02-07 09:05:48.616 [ItemStateChangedEvent ] - dscalarm_panel_60c45902_panel_panel_ac_trouble changed from NULL to OFF
2017-02-07 09:05:48.621 [ItemStateChangedEvent ] - dscalarm_keypad_60c45902_keypad_keypad_backlight_led changed from NULL to 0
2017-02-07 09:05:48.624 [ItemStateChangedEvent ] - dscalarm_panel_60c45902_panel_panel_zone_low_battery changed from NULL to OFF
2017-02-07 09:05:48.628 [ItemStateChangedEvent ] - dscalarm_zone_60c45902_zone9_zone_tripped changed from NULL to OFF
2017-02-07 09:05:48.631 [ItemStateChangedEvent ] - BRIDGE_CONNECTION changed from NULL to ON
2017-02-07 09:05:48.639 [ItemStateChangedEvent ] - dscalarm_panel_60c45902_panel_panel_time changed from NULL to 2000-01-01T00:00:00.000-0600
2017-02-07 09:05:48.644 [ItemStateChangedEvent ] - dscalarm_envisalink_60c45902_bridge_reset changed from NULL to ON
2017-02-07 09:05:48.648 [ItemStateChangedEvent ] - dscalarm_panel_60c45902_panel_panel_time_broadcast changed from NULL to OFF
2017-02-07 09:05:48.653 [ItemStateChangedEvent ] - dscalarm_panel_60c45902_panel_panel_fire_key_alarm changed from NULL to OFF
2017-02-07 09:05:48.657 [ItemStateChangedEvent ] - dscalarm_panel_60c45902_panel_panel_time_stamp changed from NULL to OFF
2017-02-07 09:05:48.659 [ItemStateChangedEvent ] - dscalarm_panel_60c45902_panel_panel_aux_key_alarm changed from NULL to OFF
2017-02-07 09:05:48.664 [ItemStateChangedEvent ] - dscalarm_panel_60c45902_panel_panel_panic_key_alarm changed from NULL to OFF
2017-02-07 09:05:48.664 [ItemStateChangedEvent ] - dscalarm_panel_60c45902_panel_panel_aux_input_alarm changed from NULL to OFF
2017-02-07 09:05:53.548 [ItemStateChangedEvent ] - dscalarm_panel_60c45902_panel_panel_message changed from to 500: A command has been received successfully.
2017-02-07 09:05:55.739 [ItemStateChangedEvent ] - dscalarm_panel_60c45902_panel_panel_message changed from 500: A command has been received successfully. to 841: The trouble LED on a keypad is OFF.
2017-02-07 09:05:55.944 [ItemStateChangedEvent ] - dscalarm_keypad_60c45902_keypad_keypad_ready_led changed from 0 to 1
2017-02-07 09:05:55.965 [ItemStateChangedEvent ] - dscalarm_keypad_60c45902_keypad_keypad_backlight_led changed from 0 to 1
2017-02-07 09:06:53.450 [ItemStateChangedEvent ] - dscalarm_panel_60c45902_panel_panel_message changed from 841: The trouble LED on a keypad is OFF. to 500: A command has been received successfully.
pi@OpenHAB:~ $
Looking through the log it appears that you are connecting. I see your āThingā status changed to ONLINE:
2017-02-07 09:05:48.419 [hingStatusInfoChangedEvent] - ādscalarm:envisalink:60c45902ā changed from OFFLINE to ONLINE
2017-02-07 09:05:48.431 [hingStatusInfoChangedEvent] - ādscalarm:zone:60c45902:zone9ā changed from OFFLINE to ONLINE
2017-02-07 09:05:48.438 [hingStatusInfoChangedEvent] - ādscalarm:keypad:60c45902:keypadā changed from INITIALIZING to OFFLINE
2017-02-07 09:05:48.440 [hingStatusInfoChangedEvent] - ādscalarm:panel:60c45902:panelā changed from OFFLINE to ONLINE
2017-02-07 09:05:48.452 [hingStatusInfoChangedEvent] - ādscalarm:keypad:60c45902:keypadā changed from OFFLINE to ONLINE
Yes, I think that is the case. I have seen similar messages on my system. The Things canāt go ONLINE until the bridge is connected and ONLINE itself.
OK, Iāll close my eyes and pretend those errors donāt exist.
Iāve got another question about the example dscalarm.sitemap file shown on the DSC Binding info page. Is that file suppose to actually work, after appropriate modification to match your individual zones? Iām seeing lots of references to nonexistant icon files and some syntax complaints in Designer.
Thanks for the help Russell. Iām hoping your binding can be the core of my automation project.
That sitemap should basically work. There are references to icons that I downloaded or modified to suit my taste, and probably should be taken out of the sample. But overall the sitemap should work once you rename the items to match your own.
oh, and the last question for nowā¦ I saw one of your posts almost a year ago, I believe, talking about actions not being available / supportable on OH2. Iām mostly wanting to publish dsc events to mqtt but some sendDSCAlarmCommand functionality would be helpfull. Is that something thatās in the works of OH2 or do I need to go back to the 1.X addon version ?
The action is not available at this time for version 2.0. I do have some ideas on how to implement similar functionality but havenāt delved into it yet.
Just to note in order to run the 1.x version action you also have to run the 1.x binding.
