I have a DSC PC1864 alarm with Envisalink and rules like below to signal ArmMode changes
rule "Alarm modes"
Item DSCPartitionArmMode received update
if (DSCPartitionArmMode.state == 0) {
sendPushoverMessage(pushoverBuilder("Alarm OFF"))
else if (DSCPartitionArmMode.state == 1) {
sendPushoverMessage(pushoverBuilder("Alarm Armed AWAY"))
else if (DSCPartitionArmMode.state == 2) {
sendPushoverMessage(pushoverBuilder("Alarm Armed STAY"))
It is normally working fine but I have noticed two scenarios when the ArmMode is triggering every 4 min:
- If a wireless sensor has low battery and the panel shows a warning
- If an alarm didn’t get confirmed (trying 3 times) it also trigger a warning in the panel
I think I could keep the pevious state and compare if it is a real ArmMode change or not.
Getting logs like:
2019-10-23 23:01:42.223 [INFO ] [e.smarthome.model.script.alarm.rules] - DSCPartitionArmMode.state = 1
2019-10-23 23:01:42.246 [INFO ] [e.smarthome.model.script.alarm.rules] - Partition Armed AWAY
2019-10-23 23:05:52.256 [INFO ] [e.smarthome.model.script.alarm.rules] - DSCPartitionArmMode.state = 1
2019-10-23 23:05:52.282 [INFO ] [e.smarthome.model.script.alarm.rules] - Partition Armed AWAY
2019-10-23 23:10:02.278 [INFO ] [e.smarthome.model.script.alarm.rules] - DSCPartitionArmMode.state = 1
2019-10-23 23:10:02.301 [INFO ] [e.smarthome.model.script.alarm.rules] - Partition Armed AWAY
2019-10-23 23:14:12.307 [INFO ] [e.smarthome.model.script.alarm.rules] - DSCPartitionArmMode.state = 1
2019-10-23 23:14:12.331 [INFO ] [e.smarthome.model.script.alarm.rules] - Partition Armed AWAY
2019-10-23 23:18:22.332 [INFO ] [e.smarthome.model.script.alarm.rules] - DSCPartitionArmMode.state = 1
2019-10-23 23:18:22.360 [INFO ] [e.smarthome.model.script.alarm.rules] - Partition Armed AWAY
2019-10-23 23:22:32.366 [INFO ] [e.smarthome.model.script.alarm.rules] - DSCPartitionArmMode.state = 1
2019-10-23 23:22:32.392 [INFO ] [e.smarthome.model.script.alarm.rules] - Partition Armed AWAY
2019-10-23 23:26:42.396 [INFO ] [e.smarthome.model.script.alarm.rules] - DSCPartitionArmMode.state = 1
Is it a bug or am I doing things wrong?
