I am porting (finally) my working OH 1.9 setup to new platform. I cannot make the DSC panel zones bypass work with the new binding in OH 2.4
I am using binding
openhab> bundle:list|grep -i dsc
223 │ Active │ 80 │ 2.4.0.201805280907 │ DSCAlarm Binding
Item is defined as:
Switch ZONE3_BYPASS_MODE "Z3 Bypass Mode" (DSCAlarmZones) {channel="dscalarm:zone:envisalink:zone3:zone_bypass_mode"}
and toggling the switch has no effect on the panel. I checked with my old config, and it works just fine, nice “B” appears on the keypad when I toggle the setting with an iPhone.
I can Arm and Disarm the alarm, so the basic communication works. I can also see the status of the Bypass LED in OH, status of the zones, etc. Only bypass is completely ignored.
In the log:
2018-05-29 17:56:05.833 [DEBUG] [ng.dscalarm.internal.DSCAlarmMessage] - parseAPIMessage(): Message Received (500000) - Code: 500, Name: Command Acknowledge, Description: 500: A comman$
2018-05-29 17:56:05.833 [DEBUG] [rm.handler.DSCAlarmBaseBridgeHandler] - handleIncomingMessage(): Message received: 50000025 - Code: "500", Name: "Command Acknowledge", Description: "5$
2018-05-29 17:56:05.834 [DEBUG] [g.dscalarm.handler.PanelThingHandler] - updateChannel(): Panel Channel UID: dscalarm:panel:envisalink:panel:panel_message
2018-05-29 17:56:05.836 [DEBUG] [arm.handler.DSCAlarmBaseThingHandler] - setPanelMessage(): Panel Message Set to - 500: A command has been received successfully.
2018-05-29 17:56:05.837 [DEBUG] [rm.handler.DSCAlarmBaseBridgeHandler] - setBridgeConnection(): Setting Bridge to ONLINE
2018-05-29 17:56:05.837 [DEBUG] [rm.handler.DSCAlarmBaseBridgeHandler] - findThing(): Thing Found - org.eclipse.smarthome.core.thing.internal.ThingImpl@84e519a6, org.openhab.binding.ds$
2018-05-29 17:56:05.838 [DEBUG] [rm.handler.DSCAlarmBaseBridgeHandler] - handleIncomingMessage(): Thing Search - 'org.eclipse.smarthome.core.thing.internal.ThingImpl@84e519a6'
2018-05-29 17:56:05.838 [DEBUG] [g.dscalarm.handler.PanelThingHandler] - setTimeStampState(): Already Set:
2018-05-29 17:56:05.840 [DEBUG] [g.dscalarm.handler.PanelThingHandler] - dscAlarmEventRecieved(): Thing - dscalarm:panel:envisalink:panel Command - CommandAcknowledge
2018-05-29 17:56:06.010 [DEBUG] [ng.dscalarm.handler.ZoneThingHandler] - handleCommand(): Command Received - dscalarm:zone:envisalink:zone3:zone_bypass_mode ON.
2018-05-29 17:56:10.414 [DEBUG] [rm.handler.DSCAlarmBaseBridgeHandler] - DSC Alarm Polling Task - 'dscalarm:envisalink:envisalink' is ONLINE
2018-05-29 17:56:10.415 [DEBUG] [rm.handler.DSCAlarmBaseBridgeHandler] - Checking Things!
2018-05-29 17:56:10.415 [DEBUG] [rm.handler.DSCAlarmBaseBridgeHandler] - ***Checking 'dscalarm:panel:envisalink:panel' - Status: ONLINE, Initialized: true
2018-05-29 17:57:10.648 [DEBUG] [larm.handler.EnvisalinkBridgeHandler] - write(): Attempting to Send Message: 00090
2018-05-29 17:57:10.650 [DEBUG] [rm.handler.DSCAlarmBaseBridgeHandler] - sendCommand(): 'Poll' Command Sent - 00090
2018-05-29 17:57:10.896 [DEBUG] [larm.handler.EnvisalinkBridgeHandler] - read(): Message Received: 50000025
2018-05-29 17:57:10.897 [DEBUG] [ng.dscalarm.internal.DSCAlarmMessage] - parseAPIMessage(): Message Received (500000) - Code: 500, Name: Command Acknowledge, Description: 500: A comman$
2018-05-29 17:57:10.897 [DEBUG] [rm.handler.DSCAlarmBaseBridgeHandler] - handleIncomingMessage(): Message received: 50000025 - Code: "500", Name: "Command Acknowledge", Description: "5$
2018-05-29 17:57:10.899 [DEBUG] [g.dscalarm.handler.PanelThingHandler] - updateChannel(): Panel Channel UID: dscalarm:panel:envisalink:panel:panel_message
2018-05-29 17:57:10.901 [DEBUG] [arm.handler.DSCAlarmBaseThingHandler] - setPanelMessage(): Panel Message Set to - 500: A command has been received successfully.
2018-05-29 17:57:10.901 [DEBUG] [rm.handler.DSCAlarmBaseBridgeHandler] - setBridgeConnection(): Setting Bridge to ONLINE
2018-05-29 17:57:10.902 [DEBUG] [rm.handler.DSCAlarmBaseBridgeHandler] - findThing(): Thing Found - org.eclipse.smarthome.core.thing.internal.ThingImpl@84e519a6, org.openhab.binding.ds$
2018-05-29 17:57:10.902 [DEBUG] [rm.handler.DSCAlarmBaseBridgeHandler] - handleIncomingMessage(): Thing Search - 'org.eclipse.smarthome.core.thing.internal.ThingImpl@84e519a6'
2018-05-29 17:57:10.903 [DEBUG] [g.dscalarm.handler.PanelThingHandler] - setTimeStampState(): Already Set:
2018-05-29 17:57:10.904 [DEBUG] [g.dscalarm.handler.PanelThingHandler] - dscAlarmEventRecieved(): Thing - dscalarm:panel:envisalink:panel Command - CommandAcknowledge
2018-05-29 17:57:15.696 [DEBUG] [rm.handler.DSCAlarmBaseBridgeHandler] - DSC Alarm Polling Task - 'dscalarm:envisalink:envisalink' is ONLINE
2018-05-29 17:57:15.698 [DEBUG] [rm.handler.DSCAlarmBaseBridgeHandler] - Checking Things!
[root@openhab ~]# tail -f /var/log/openhab2/openhab.log | grep -i "DSC" | grep -v "***Checking"
2018-05-29 18:24:42.197 [DEBUG] [ng.dscalarm.handler.ZoneThingHandler] - handleCommand(): Command Received - dscalarm:zone:envisalink:zone3:zone_bypass_mode OFF.
2018-05-29 18:24:43.192 [DEBUG] [rm.handler.DSCAlarmBaseBridgeHandler] - DSC Alarm Polling Task - 'dscalarm:envisalink:envisalink' is ONLINE
2018-05-29 18:24:46.362 [DEBUG] [ng.dscalarm.handler.ZoneThingHandler] - handleCommand(): Command Received - dscalarm:zone:envisalink:zone3:zone_bypass_mode ON.
2018-05-29 18:24:48.210 [DEBUG] [rm.handler.DSCAlarmBaseBridgeHandler] - DSC Alarm Polling Task - 'dscalarm:envisalink:envisalink' is ONLINE
2018-05-29 18:24:53.219 [DEBUG] [rm.handler.DSCAlarmBaseBridgeHandler] - DSC Alarm Polling Task - 'dscalarm:envisalink:envisalink' is ONLINE
2018-05-29 18:24:58.230 [DEBUG] [rm.handler.DSCAlarmBaseBridgeHandler] - DSC Alarm Polling Task - 'dscalarm:envisalink:envisalink' is ONLINE
2018-05-29 18:25:03.239 [DEBUG] [rm.handler.DSCAlarmBaseBridgeHandler] - DSC Alarm Polling Task - 'dscalarm:envisalink:envisalink' is ONLINE
2018-05-29 18:25:07.010 [DEBUG] [ng.dscalarm.internal.DSCAlarmMessage] - parseAPIMessage(): Message Received (609003) - Code: 609, Name: Zone Open, Description: 609: General status of the zone - open., Data: 003
2018-05-29 18:25:07.011 [DEBUG] [rm.handler.DSCAlarmBaseBridgeHandler] - handleIncomingMessage(): Message received: 60900332 - Code: "609", Name: "Zone Open", Description: "609: General status of the zone - open.", Zone: 003, Data: 003
2018-05-29 18:25:07.012 [DEBUG] [g.dscalarm.handler.PanelThingHandler] - updateChannel(): Panel Channel UID: dscalarm:panel:envisalink:panel:panel_message
2018-05-29 18:25:07.013 [DEBUG] [arm.handler.DSCAlarmBaseThingHandler] - setPanelMessage(): Panel Message Set to - 609: General status of the zone - open.
2018-05-29 18:25:07.014 [DEBUG] [rm.handler.DSCAlarmBaseBridgeHandler] - findThing(): Thing Found - org.eclipse.smarthome.core.thing.internal.ThingImpl@8b79b151, org.openhab.binding.dscalarm.handler.ZoneThingHandler@79aaa02e, ZONE
2018-05-29 18:25:07.014 [DEBUG] [rm.handler.DSCAlarmBaseBridgeHandler] - handleIncomingMessage(): Thing Search - 'org.eclipse.smarthome.core.thing.internal.ThingImpl@8b79b151'
2018-05-29 18:25:07.014 [DEBUG] [ng.dscalarm.handler.ZoneThingHandler] - dscAlarmEventRecieved(): Thing - dscalarm:zone:envisalink:zone3 Command - ZoneOpen
2018-05-29 18:25:07.015 [DEBUG] [ng.dscalarm.handler.ZoneThingHandler] - updateChannel(): Zone Channel UID: dscalarm:zone:envisalink:zone3:zone_tripped
2018-05-29 18:25:07.015 [DEBUG] [ng.dscalarm.handler.ZoneThingHandler] - updateChannel(): Zone Channel UID: dscalarm:zone:envisalink:zone3:zone_status
2018-05-29 18:25:07.016 [DEBUG] [ng.dscalarm.internal.DSCAlarmMessage] - parseAPIMessage(): Message Received (51080) - Code: 510, Name: Keypad LED State - Partition 1 Only, Description: 510: A change of state in the Partition 1 keypad LEDs., Data: 80
2018-05-29 18:25:07.016 [DEBUG] [rm.handler.DSCAlarmBaseBridgeHandler] - handleIncomingMessage(): Message received: 51080FE - Code: "510", Name: "Keypad LED State - Partition 1 Only", Description: "510: A change of state in the Partition 1 keypad LEDs.", Data: 80
2018-05-29 18:25:07.016 [DEBUG] [g.dscalarm.handler.PanelThingHandler] - updateChannel(): Panel Channel UID: dscalarm:panel:envisalink:panel:panel_message
2018-05-29 18:25:07.016 [DEBUG] [arm.handler.DSCAlarmBaseThingHandler] - setPanelMessage(): Panel Message Set to - 510: A change of state in the Partition 1 keypad LEDs.
2018-05-29 18:25:07.017 [DEBUG] [rm.handler.DSCAlarmBaseBridgeHandler] - findThing(): Thing Found - org.eclipse.smarthome.core.thing.internal.ThingImpl@89335546, org.openhab.binding.dscalarm.handler.KeypadThingHandler@454b2172, KEYPAD
2018-05-29 18:25:07.017 [DEBUG] [rm.handler.DSCAlarmBaseBridgeHandler] - handleIncomingMessage(): Thing Search - 'org.eclipse.smarthome.core.thing.internal.ThingImpl@89335546'
2018-05-29 18:25:07.017 [DEBUG] [.dscalarm.handler.KeypadThingHandler] - dscAlarmEventRecieved(): Thing - dscalarm:keypad:envisalink:keypad Command - KeypadLEDState
2018-05-29 18:25:07.017 [DEBUG] [.dscalarm.handler.KeypadThingHandler] - updateChannel(): Keypad Channel UID: dscalarm:keypad:envisalink:keypad:keypad_ready_led
2018-05-29 18:25:07.017 [DEBUG] [.dscalarm.handler.KeypadThingHandler] - updateChannel(): Keypad Channel UID: dscalarm:keypad:envisalink:keypad:keypad_armed_led
2018-05-29 18:25:07.018 [DEBUG] [.dscalarm.handler.KeypadThingHandler] - updateChannel(): Keypad Channel UID: dscalarm:keypad:envisalink:keypad:keypad_memory_led
2018-05-29 18:25:07.018 [DEBUG] [.dscalarm.handler.KeypadThingHandler] - updateChannel(): Keypad Channel UID: dscalarm:keypad:envisalink:keypad:keypad_bypass_led
2018-05-29 18:25:07.018 [DEBUG] [.dscalarm.handler.KeypadThingHandler] - updateChannel(): Keypad Channel UID: dscalarm:keypad:envisalink:keypad:keypad_trouble_led
2018-05-29 18:25:07.018 [DEBUG] [.dscalarm.handler.KeypadThingHandler] - updateChannel(): Keypad Channel UID: dscalarm:keypad:envisalink:keypad:keypad_program_led
2018-05-29 18:25:07.018 [DEBUG] [.dscalarm.handler.KeypadThingHandler] - updateChannel(): Keypad Channel UID: dscalarm:keypad:envisalink:keypad:keypad_fire_led
2018-05-29 18:25:07.019 [DEBUG] [.dscalarm.handler.KeypadThingHandler] - updateChannel(): Keypad Channel UID: dscalarm:keypad:envisalink:keypad:keypad_backlight_led
2018-05-29 18:25:07.019 [DEBUG] [ng.dscalarm.internal.DSCAlarmMessage] - parseAPIMessage(): Message Received (6511) - Code: 651, Name: Partition Not Ready, Description: 651: Partition can not be armed., Data: 1
2018-05-29 18:25:07.019 [DEBUG] [rm.handler.DSCAlarmBaseBridgeHandler] - handleIncomingMessage(): Message received: 6511CD - Code: "651", Name: "Partition Not Ready", Description: "651: Partition can not be armed.", Partition: 1, Data: 1
2018-05-29 18:25:07.019 [DEBUG] [g.dscalarm.handler.PanelThingHandler] - updateChannel(): Panel Channel UID: dscalarm:panel:envisalink:panel:panel_message
2018-05-29 18:25:07.020 [DEBUG] [arm.handler.DSCAlarmBaseThingHandler] - setPanelMessage(): Panel Message Set to - 651: Partition can not be armed.
2018-05-29 18:25:07.020 [DEBUG] [rm.handler.DSCAlarmBaseBridgeHandler] - findThing(): Thing Found - org.eclipse.smarthome.core.thing.internal.ThingImpl@fb38c18f, org.openhab.binding.dscalarm.handler.PartitionThingHandler@606763dd, PARTITION
2018-05-29 18:25:07.020 [DEBUG] [rm.handler.DSCAlarmBaseBridgeHandler] - handleIncomingMessage(): Thing Search - 'org.eclipse.smarthome.core.thing.internal.ThingImpl@fb38c18f'
2018-05-29 18:25:07.020 [DEBUG] [calarm.handler.PartitionThingHandler] - dscAlarmEventRecieved(): Thing - dscalarm:partition:envisalink:partition1 Command - PartitionNotReady
2018-05-29 18:25:08.262 [DEBUG] [rm.handler.DSCAlarmBaseBridgeHandler] - DSC Alarm Polling Task - 'dscalarm:envisalink:envisalink' is ONLINE
2018-05-29 18:25:12.515 [DEBUG] [ng.dscalarm.internal.DSCAlarmMessage] - parseAPIMessage(): Message Received (51108) - Code: 511, Name: Keypad LED Flash State - Partition 1 Only, Description: 511: A change of state in the Partition 1 keypad LEDs as to whether to flash or not., Data: 08
2018-05-29 18:25:12.516 [DEBUG] [rm.handler.DSCAlarmBaseBridgeHandler] - handleIncomingMessage(): Message received: 51108FF - Code: "511", Name: "Keypad LED Flash State - Partition 1 Only", Description: "511: A change of state in the Partition 1 keypad LEDs as to whether to flash or not.", Data: 08
2018-05-29 18:25:12.516 [DEBUG] [g.dscalarm.handler.PanelThingHandler] - updateChannel(): Panel Channel UID: dscalarm:panel:envisalink:panel:panel_message
2018-05-29 18:25:12.518 [DEBUG] [arm.handler.DSCAlarmBaseThingHandler] - setPanelMessage(): Panel Message Set to - 511: A change of state in the Partition 1 keypad LEDs as to whether to flash or not.
2018-05-29 18:25:12.519 [DEBUG] [rm.handler.DSCAlarmBaseBridgeHandler] - findThing(): Thing Found - org.eclipse.smarthome.core.thing.internal.ThingImpl@89335546, org.openhab.binding.dscalarm.handler.KeypadThingHandler@454b2172, KEYPAD
2018-05-29 18:25:12.520 [DEBUG] [rm.handler.DSCAlarmBaseBridgeHandler] - handleIncomingMessage(): Thing Search - 'org.eclipse.smarthome.core.thing.internal.ThingImpl@89335546'
2018-05-29 18:25:12.520 [DEBUG] [.dscalarm.handler.KeypadThingHandler] - dscAlarmEventRecieved(): Thing - dscalarm:keypad:envisalink:keypad Command - KeypadLEDFlashState
2018-05-29 18:25:12.521 [DEBUG] [.dscalarm.handler.KeypadThingHandler] - updateChannel(): Keypad Channel UID: dscalarm:keypad:envisalink:keypad:keypad_bypass_led
2018-05-29 18:25:13.016 [DEBUG] [ng.dscalarm.internal.DSCAlarmMessage] - parseAPIMessage(): Message Received (610003) - Code: 610, Name: Zone Restored, Description: 610: General status of the zone - restored., Data: 003
2018-05-29 18:25:13.016 [DEBUG] [rm.handler.DSCAlarmBaseBridgeHandler] - handleIncomingMessage(): Message received: 6100032A - Code: "610", Name: "Zone Restored", Description: "610: General status of the zone - restored.", Zone: 003, Data: 003
2018-05-29 18:25:13.017 [DEBUG] [g.dscalarm.handler.PanelThingHandler] - updateChannel(): Panel Channel UID: dscalarm:panel:envisalink:panel:panel_message
2018-05-29 18:25:13.018 [DEBUG] [arm.handler.DSCAlarmBaseThingHandler] - setPanelMessage(): Panel Message Set to - 610: General status of the zone - restored.
2018-05-29 18:25:13.019 [DEBUG] [rm.handler.DSCAlarmBaseBridgeHandler] - findThing(): Thing Found - org.eclipse.smarthome.core.thing.internal.ThingImpl@8b79b151, org.openhab.binding.dscalarm.handler.ZoneThingHandler@79aaa02e, ZONE
2018-05-29 18:25:13.019 [DEBUG] [rm.handler.DSCAlarmBaseBridgeHandler] - handleIncomingMessage(): Thing Search - 'org.eclipse.smarthome.core.thing.internal.ThingImpl@8b79b151'
2018-05-29 18:25:13.019 [DEBUG] [ng.dscalarm.handler.ZoneThingHandler] - dscAlarmEventRecieved(): Thing - dscalarm:zone:envisalink:zone3 Command - ZoneRestored
2018-05-29 18:25:13.019 [DEBUG] [ng.dscalarm.handler.ZoneThingHandler] - updateChannel(): Zone Channel UID: dscalarm:zone:envisalink:zone3:zone_tripped
2018-05-29 18:25:13.020 [DEBUG] [ng.dscalarm.handler.ZoneThingHandler] - updateChannel(): Zone Channel UID: dscalarm:zone:envisalink:zone3:zone_status
2018-05-29 18:25:13.271 [DEBUG] [rm.handler.DSCAlarmBaseBridgeHandler] - DSC Alarm Polling Task - 'dscalarm:envisalink:envisalink' is ONLINE
2018-05-29 18:25:18.294 [DEBUG] [rm.handler.DSCAlarmBaseBridgeHandler] - DSC Alarm Polling Task - 'dscalarm:envisalink:envisalink' is ONLINE
2018-05-29 18:25:19.020 [DEBUG] [ng.dscalarm.internal.DSCAlarmMessage] - parseAPIMessage(): Message Received (609003) - Code: 609, Name: Zone Open, Description: 609: General status of the zone - open., Data: 003
2018-05-29 18:25:19.021 [DEBUG] [rm.handler.DSCAlarmBaseBridgeHandler] - handleIncomingMessage(): Message received: 60900332 - Code: "609", Name: "Zone Open", Description: "609: General status of the zone - open.", Zone: 003, Data: 003
2018-05-29 18:25:19.021 [DEBUG] [g.dscalarm.handler.PanelThingHandler] - updateChannel(): Panel Channel UID: dscalarm:panel:envisalink:panel:panel_message
2018-05-29 18:25:19.022 [DEBUG] [arm.handler.DSCAlarmBaseThingHandler] - setPanelMessage(): Panel Message Set to - 609: General status of the zone - open.
2018-05-29 18:25:19.022 [DEBUG] [rm.handler.DSCAlarmBaseBridgeHandler] - findThing(): Thing Found - org.eclipse.smarthome.core.thing.internal.ThingImpl@8b79b151, org.openhab.binding.dscalarm.handler.ZoneThingHandler@79aaa02e, ZONE
2018-05-29 18:25:19.022 [DEBUG] [rm.handler.DSCAlarmBaseBridgeHandler] - handleIncomingMessage(): Thing Search - 'org.eclipse.smarthome.core.thing.internal.ThingImpl@8b79b151'
2018-05-29 18:25:19.023 [DEBUG] [ng.dscalarm.handler.ZoneThingHandler] - dscAlarmEventRecieved(): Thing - dscalarm:zone:envisalink:zone3 Command - ZoneOpen
2018-05-29 18:25:19.023 [DEBUG] [ng.dscalarm.handler.ZoneThingHandler] - updateChannel(): Zone Channel UID: dscalarm:zone:envisalink:zone3:zone_tripped
2018-05-29 18:25:19.024 [DEBUG] [ng.dscalarm.handler.ZoneThingHandler] - updateChannel(): Zone Channel UID: dscalarm:zone:envisalink:zone3:zone_status
2018-05-29 18:25:23.311 [DEBUG] [rm.handler.DSCAlarmBaseBridgeHandler] - DSC Alarm Polling Task - 'dscalarm:envisalink:envisalink' is ONLINE
2018-05-29 18:25:25.027 [DEBUG] [ng.dscalarm.internal.DSCAlarmMessage] - parseAPIMessage(): Message Received (610003) - Code: 610, Name: Zone Restored, Description: 610: General status of the zone - restored., Data: 003
2018-05-29 18:25:25.027 [DEBUG] [rm.handler.DSCAlarmBaseBridgeHandler] - handleIncomingMessage(): Message received: 6100032A - Code: "610", Name: "Zone Restored", Description: "610: General status of the zone - restored.", Zone: 003, Data: 003
2018-05-29 18:25:25.028 [DEBUG] [g.dscalarm.handler.PanelThingHandler] - updateChannel(): Panel Channel UID: dscalarm:panel:envisalink:panel:panel_message
2018-05-29 18:25:25.029 [DEBUG] [arm.handler.DSCAlarmBaseThingHandler] - setPanelMessage(): Panel Message Set to - 610: General status of the zone - restored.
2018-05-29 18:25:25.031 [DEBUG] [rm.handler.DSCAlarmBaseBridgeHandler] - findThing(): Thing Found - org.eclipse.smarthome.core.thing.internal.ThingImpl@8b79b151, org.openhab.binding.dscalarm.handler.ZoneThingHandler@79aaa02e, ZONE
2018-05-29 18:25:25.031 [DEBUG] [rm.handler.DSCAlarmBaseBridgeHandler] - handleIncomingMessage(): Thing Search - 'org.eclipse.smarthome.core.thing.internal.ThingImpl@8b79b151'
2018-05-29 18:25:25.032 [DEBUG] [ng.dscalarm.handler.ZoneThingHandler] - dscAlarmEventRecieved(): Thing - dscalarm:zone:envisalink:zone3 Command - ZoneRestored
2018-05-29 18:25:25.032 [DEBUG] [ng.dscalarm.handler.ZoneThingHandler] - updateChannel(): Zone Channel UID: dscalarm:zone:envisalink:zone3:zone_tripped
2018-05-29 18:25:25.034 [DEBUG] [ng.dscalarm.handler.ZoneThingHandler] - updateChannel(): Zone Channel UID: dscalarm:zone:envisalink:zone3:zone_status
2018-05-29 18:25:28.321 [DEBUG] [rm.handler.DSCAlarmBaseBridgeHandler] - DSC Alarm Polling Task - 'dscalarm:envisalink:envisalink' is ONLINE
2018-05-29 18:25:28.323 [DEBUG] [rm.handler.DSCAlarmBaseBridgeHandler] - sendCommand(): 'Poll' Command Sent - 00090
2018-05-29 18:25:28.530 [DEBUG] [ng.dscalarm.internal.DSCAlarmMessage] - parseAPIMessage(): Message Received (500000) - Code: 500, Name: Command Acknowledge, Description: 500: A command has been received successfully., Data: 000
2018-05-29 18:25:28.531 [DEBUG] [rm.handler.DSCAlarmBaseBridgeHandler] - handleIncomingMessage(): Message received: 50000025 - Code: "500", Name: "Command Acknowledge", Description: "500: A command has been received successfully.", Data: 000
2018-05-29 18:25:28.532 [DEBUG] [g.dscalarm.handler.PanelThingHandler] - updateChannel(): Panel Channel UID: dscalarm:panel:envisalink:panel:panel_message
2018-05-29 18:25:28.559 [DEBUG] [arm.handler.DSCAlarmBaseThingHandler] - setPanelMessage(): Panel Message Set to - 500: A command has been received successfully.
2018-05-29 18:25:28.560 [DEBUG] [rm.handler.DSCAlarmBaseBridgeHandler] - setBridgeConnection(): Setting Bridge to ONLINE
2018-05-29 18:25:28.561 [DEBUG] [rm.handler.DSCAlarmBaseBridgeHandler] - findThing(): Thing Found - org.eclipse.smarthome.core.thing.internal.ThingImpl@84e519a6, org.openhab.binding.dscalarm.handler.PanelThingHandler@658324ce, PANEL
2018-05-29 18:25:28.562 [DEBUG] [rm.handler.DSCAlarmBaseBridgeHandler] - handleIncomingMessage(): Thing Search - 'org.eclipse.smarthome.core.thing.internal.ThingImpl@84e519a6'
2018-05-29 18:25:28.563 [DEBUG] [g.dscalarm.handler.PanelThingHandler] - setTimeStampState(): Already Set:
2018-05-29 18:25:28.563 [DEBUG] [g.dscalarm.handler.PanelThingHandler] - dscAlarmEventRecieved(): Thing - dscalarm:panel:envisalink:panel Command - CommandAcknowledge
2018-05-29 18:25:33.344 [DEBUG] [rm.handler.DSCAlarmBaseBridgeHandler] - DSC Alarm Polling Task - 'dscalarm:envisalink:envisalink' is ONLINE
2018-05-29 18:25:38.365 [DEBUG] [rm.handler.DSCAlarmBaseBridgeHandler] - DSC Alarm Polling Task - 'dscalarm:envisalink:envisalink' is ONLINE
2018-05-29 18:25:39.541 [DEBUG] [ng.dscalarm.internal.DSCAlarmMessage] - parseAPIMessage(): Message Received (51100) - Code: 511, Name: Keypad LED Flash State - Partition 1 Only, Description: 511: A change of state in the Partition 1 keypad LEDs as to whether to flash or not., Data: 00
2018-05-29 18:25:39.542 [DEBUG] [rm.handler.DSCAlarmBaseBridgeHandler] - handleIncomingMessage(): Message received: 51100F7 - Code: "511", Name: "Keypad LED Flash State - Partition 1 Only", Description: "511: A change of state in the Partition 1 keypad LEDs as to whether to flash or not.", Data: 00
2018-05-29 18:25:39.543 [DEBUG] [g.dscalarm.handler.PanelThingHandler] - updateChannel(): Panel Channel UID: dscalarm:panel:envisalink:panel:panel_message
2018-05-29 18:25:39.545 [DEBUG] [arm.handler.DSCAlarmBaseThingHandler] - setPanelMessage(): Panel Message Set to - 511: A change of state in the Partition 1 keypad LEDs as to whether to flash or not.
2018-05-29 18:25:39.545 [DEBUG] [rm.handler.DSCAlarmBaseBridgeHandler] - findThing(): Thing Found - org.eclipse.smarthome.core.thing.internal.ThingImpl@89335546, org.openhab.binding.dscalarm.handler.KeypadThingHandler@454b2172, KEYPAD
2018-05-29 18:25:39.545 [DEBUG] [rm.handler.DSCAlarmBaseBridgeHandler] - handleIncomingMessage(): Thing Search - 'org.eclipse.smarthome.core.thing.internal.ThingImpl@89335546'
2018-05-29 18:25:39.546 [DEBUG] [.dscalarm.handler.KeypadThingHandler] - dscAlarmEventRecieved(): Thing - dscalarm:keypad:envisalink:keypad Command - KeypadLEDFlashState
2018-05-29 18:25:40.041 [DEBUG] [ng.dscalarm.internal.DSCAlarmMessage] - parseAPIMessage(): Message Received (51089) - Code: 510, Name: Keypad LED State - Partition 1 Only, Description: 510: A change of state in the Partition 1 keypad LEDs., Data: 89
2018-05-29 18:25:40.042 [DEBUG] [rm.handler.DSCAlarmBaseBridgeHandler] - handleIncomingMessage(): Message received: 5108907 - Code: "510", Name: "Keypad LED State - Partition 1 Only", Description: "510: A change of state in the Partition 1 keypad LEDs.", Data: 89
2018-05-29 18:25:40.042 [DEBUG] [g.dscalarm.handler.PanelThingHandler] - updateChannel(): Panel Channel UID: dscalarm:panel:envisalink:panel:panel_message
2018-05-29 18:25:40.044 [DEBUG] [arm.handler.DSCAlarmBaseThingHandler] - setPanelMessage(): Panel Message Set to - 510: A change of state in the Partition 1 keypad LEDs.
2018-05-29 18:25:40.045 [DEBUG] [rm.handler.DSCAlarmBaseBridgeHandler] - findThing(): Thing Found - org.eclipse.smarthome.core.thing.internal.ThingImpl@89335546, org.openhab.binding.dscalarm.handler.KeypadThingHandler@454b2172, KEYPAD
2018-05-29 18:25:40.045 [DEBUG] [rm.handler.DSCAlarmBaseBridgeHandler] - handleIncomingMessage(): Thing Search - 'org.eclipse.smarthome.core.thing.internal.ThingImpl@89335546'
2018-05-29 18:25:40.045 [DEBUG] [.dscalarm.handler.KeypadThingHandler] - dscAlarmEventRecieved(): Thing - dscalarm:keypad:envisalink:keypad Command - KeypadLEDState
2018-05-29 18:25:40.046 [DEBUG] [.dscalarm.handler.KeypadThingHandler] - updateChannel(): Keypad Channel UID: dscalarm:keypad:envisalink:keypad:keypad_ready_led
2018-05-29 18:25:40.046 [DEBUG] [.dscalarm.handler.KeypadThingHandler] - updateChannel(): Keypad Channel UID: dscalarm:keypad:envisalink:keypad:keypad_armed_led
2018-05-29 18:25:40.047 [DEBUG] [.dscalarm.handler.KeypadThingHandler] - updateChannel(): Keypad Channel UID: dscalarm:keypad:envisalink:keypad:keypad_memory_led
2018-05-29 18:25:40.048 [DEBUG] [.dscalarm.handler.KeypadThingHandler] - updateChannel(): Keypad Channel UID: dscalarm:keypad:envisalink:keypad:keypad_bypass_led
2018-05-29 18:25:40.050 [DEBUG] [.dscalarm.handler.KeypadThingHandler] - updateChannel(): Keypad Channel UID: dscalarm:keypad:envisalink:keypad:keypad_trouble_led
2018-05-29 18:25:40.051 [DEBUG] [.dscalarm.handler.KeypadThingHandler] - updateChannel(): Keypad Channel UID: dscalarm:keypad:envisalink:keypad:keypad_program_led
2018-05-29 18:25:40.052 [DEBUG] [.dscalarm.handler.KeypadThingHandler] - updateChannel(): Keypad Channel UID: dscalarm:keypad:envisalink:keypad:keypad_fire_led
2018-05-29 18:25:40.053 [DEBUG] [.dscalarm.handler.KeypadThingHandler] - updateChannel(): Keypad Channel UID: dscalarm:keypad:envisalink:keypad:keypad_backlight_led
2018-05-29 18:25:40.055 [DEBUG] [ng.dscalarm.internal.DSCAlarmMessage] - parseAPIMessage(): Message Received (6501) - Code: 650, Name: Partition Ready, Description: 650: Partition can now be armed., Data: 1
2018-05-29 18:25:40.055 [DEBUG] [rm.handler.DSCAlarmBaseBridgeHandler] - handleIncomingMessage(): Message received: 6501CC - Code: "650", Name: "Partition Ready", Description: "650: Partition can now be armed.", Partition: 1, Data: 1
2018-05-29 18:25:40.056 [DEBUG] [g.dscalarm.handler.PanelThingHandler] - updateChannel(): Panel Channel UID: dscalarm:panel:envisalink:panel:panel_message
2018-05-29 18:25:40.057 [DEBUG] [arm.handler.DSCAlarmBaseThingHandler] - setPanelMessage(): Panel Message Set to - 650: Partition can now be armed.
2018-05-29 18:25:40.058 [DEBUG] [rm.handler.DSCAlarmBaseBridgeHandler] - findThing(): Thing Found - org.eclipse.smarthome.core.thing.internal.ThingImpl@fb38c18f, org.openhab.binding.dscalarm.handler.PartitionThingHandler@606763dd, PARTITION
2018-05-29 18:25:40.058 [DEBUG] [rm.handler.DSCAlarmBaseBridgeHandler] - handleIncomingMessage(): Thing Search - 'org.eclipse.smarthome.core.thing.internal.ThingImpl@fb38c18f'
2018-05-29 18:25:40.059 [DEBUG] [calarm.handler.PartitionThingHandler] - dscAlarmEventRecieved(): Thing - dscalarm:partition:envisalink:partition1 Command - PartitionReady
2018-05-29 18:25:43.387 [DEBUG] [rm.handler.DSCAlarmBaseBridgeHandler] - DSC Alarm Polling Task - 'dscalarm:envisalink:envisalink' is ONLINE
2018-05-29 18:25:48.404 [DEBUG] [rm.handler.DSCAlarmBaseBridgeHandler] - DSC Alarm Polling Task - 'dscalarm:envisalink:envisalink' is ONLINE
2018-05-29 18:25:53.421 [DEBUG] [rm.handler.DSCAlarmBaseBridgeHandler] - DSC Alarm Polling Task - 'dscalarm:envisalink:envisalink' is ONLINE
Any ideas? All help greatly apreciated…
