I’ve followed the advise in the documentation to run a scan and look at the ouput. It reports those 6 objects that I mentioned above:
14:49:08.474 [INFO ] [l.discovery.DSMRMeterDiscoveryService] - Unrecognized cosem object ‘EMETER_INSTANT_POWER_PRODUCTION_L3’ found in the data: Cosem Object(type:EMETER_INSTANT_POWER_PRODUCTION_L3, cosemValues:{=0.268 kW})
14:49:08.482 [INFO ] [l.discovery.DSMRMeterDiscoveryService] - Unrecognized cosem object ‘EMETER_INSTANT_POWER_DELIVERY_L3’ found in the data: Cosem Object(type:EMETER_INSTANT_POWER_DELIVERY_L3, cosemValues:{=0.000 kW})
14:49:08.480 [INFO ] [openhab.event.ItemStateEvent ] - Item ‘MainElectricityMeter_InstantVoltageL3’ updated to 235.1
14:49:08.491 [INFO ] [l.discovery.DSMRMeterDiscoveryService] - Unrecognized cosem object ‘EMETER_INSTANT_POWER_DELIVERY_L1’ found in the data: Cosem Object(type:EMETER_INSTANT_POWER_DELIVERY_L1, cosemValues:{=0.013 kW})
14:49:08.499 [INFO ] [l.discovery.DSMRMeterDiscoveryService] - Unrecognized cosem object ‘EMETER_INSTANT_POWER_DELIVERY_L2’ found in the data: Cosem Object(type:EMETER_INSTANT_POWER_DELIVERY_L2, cosemValues:{=0.109 kW})
14:49:08.498 [INFO ] [openhab.event.ItemStateEvent ] - Item ‘MainElectricityMeter_InstantCurrentL1’ updated to 0.19
14:49:08.507 [INFO ] [l.discovery.DSMRMeterDiscoveryService] - Unrecognized cosem object ‘EMETER_INSTANT_POWER_PRODUCTION_L1’ found in the data: Cosem Object(type:EMETER_INSTANT_POWER_PRODUCTION_L1, cosemValues:{=0.000 kW})
14:49:08.516 [INFO ] [l.discovery.DSMRMeterDiscoveryService] - Unrecognized cosem object ‘EMETER_INSTANT_POWER_PRODUCTION_L2’ found in the data: Cosem Object(type:EMETER_INSTANT_POWER_PRODUCTION_L2, cosemValues:{=0.000 kW})
It also asked to provide the full information dump:
/FLU5\xxxxxxxxx_A
0-0:96.1.4(50215)
0-0:96.1.1(xxxxxxxx)
0-0:1.0.0(210227144933W)
1-0:1.8.1(001247.747kWh)
1-0:1.8.2(002330.879kWh)
1-0:2.8.1(002159.427kWh)
1-0:2.8.2(000812.563kWh)
0-0:96.14.0(0002)
1-0:1.7.0(00.000kW)
1-0:2.7.0(00.149kW)
1-0:21.7.0(00.013kW)
1-0:41.7.0(00.108kW)
1-0:61.7.0(00.000kW)
1-0:22.7.0(00.000kW)
1-0:42.7.0(00.000kW)
1-0:62.7.0(00.271kW)
1-0:32.7.0(234.5V)
1-0:52.7.0(234.0V)
1-0:72.7.0(235.1V)
1-0:31.7.0(000.19A)
1-0:51.7.0(000.80A)
1-0:71.7.0(001.39A)
0-0:96.3.10(1)
0-0:17.0.0(999.9kW)
1-0:31.4.0(999A)
0-0:96.13.0()
0-1:24.1.0(003)
0-1:96.1.1(xxxxxxxx)
0-1:24.4.0(1)
0-1:24.2.3(210227144600W)(00996.617*m3)
!9C1E
/FLU5\xxxxxxxx_A
I did cost some effort though, the dump in the trace does not coincide with the actual start and end of the raw data.
I’ve also removed and added the Things again and now I get an extra field emeter_equipment_identifier…
The inactive channels still do not update and the ignored fields are absent.
