Many bindings which communicate with an external web API keep the representation of the API as (possibly hand-written) DTOs in the main source tree. For example my pushbullet and sensebox bindings, but there are many more of them. On the other hand, there are usually schemata available for these APIs, often offered by the external service.
Is this acceptable for the development community? I know @Kai wants developers to be able to be able to start working immediately after cloning, but I having developers do work that is much easier done by the build system sounds strange to me. Also, this would reduce the lines of code to review, which would make @David_Graeff happier I guess
As all projects are now Maven projects (and m2e-enabled in Eclipse), I would reckon that the project can be configured in a way so that the project builders automatically do this generation step after importing the project in the workspace. I am not sure, if this is the case for different IDEs though (now that many are also looking into e.v. VS Code as an IDE). If yes, I don’t see a reason against it. But I hope we all agree that we should not end up with IDE setups, which show compilation errors on projects.
