Having some issues with different ZW132 - Dual Nano switches. I have two of these switches however one is by Aeotec and one is by the originating manufacturer Fantem. The problem and difference between these two switches is as follows:
FT132-B - original Fantem product purchased to operate our ensuite fan, it switches fan off after 10 minutes using a rule. A rule detects when the switch is turned on / off and works perfectly by ensuring the fan continues to operate after having a shower.
ZW132-B - Aeotec product purchased recently to operate our separate main bathroom fan in similar fashion, as the Fantem product can no longer be sourced. The rule was copied and modified to work accordingly however there seems to be a problem with the binding for this as it isn’t picking up change in status from the switches directly, although the settings are identical in the configuration. The switch can be controlled from the controller so it seems like its one-way transmission.
When placing OpenHab2 into debug mode, and the switch is manually triggered, I am getting a whole lot of lines appear in the debug file which would indicate that it knows something is happening. However I don’t have enough knowledge to decipher this but one would assume that it is communicating based on this.
There is a difference I have noticed when adding these devices into my items file, that the channel name is slightly different:
FT132-B - working and reporting from switch "switch_binaryX"
Switch EnsuiteFan “Ensuite Fan” (gEnsuite) [ “Switchable” ] { channel=“zwave:device:512:node11:switch_binary1” }
ZW132-B - not reporting / updating from switch "basic_switch_binaryX"
Switch BathroomLight “Bathroom Light” (gBathroom) [ “Switchable” ] { channel=“zwave:device:512:node15:basic_switch_binary1” }
Switch BathroomFan “Bathroom Fan” (gBathroom) [ “Switchable” ] { channel=“zwave:device:512:node15:basic_switch_binary2” }
i.e. difference is ZW is now using the prefix “basic” - not sure if this is having an impact on identifying individual switch.
If I change my items file to represent the dual switch itself (so both switches on the device) by using “switch_binary” without any numbers, and turn both switches manually ON, the changes get picked up by OH and rule gets processed etc. However the problem seems to be identifying individual switches on this device.
As an additional test, when I try to unlink the channel from the ZW132 device by clicking on the blue checkbox in PaperUI, I get an error 404 on either Switch 1 or Switch 2 and it doesn’t unlink. When I do the same for the FT132 device it unlinks and the blue circle becomes unchecked.
The difference between these devices is the FT132 is on v1.1 firmware, and the newer device ZW132 is on v2.2. In theory the older is working so it appears.
Let me know if you require any further information
