I’ve setup the DWD Unwetter Binding.
It’s working very well. I set the update intervall to 20 minutes.
But the Binding stops updating after a few hours. (sometimes it works up to 30 hours, sometimes only 12 hours.)
Then the linked Items never are updated again.
After restarting the binding manually it works again.
Someone an idea what’s going wrong?
It looks like the issue is resolved with version 2.5.2 of the binding.
The system is up now since 5 days and the update of the warnings is still working.
Before normally it was broken after 2-3 days.
Updated to 2.5.3 but doesn’t get updates. After binding and reboot no results. In my region actually there is a warning with icy conditions. DWD Weather APP gives me a warning and i think that Openhab doesn’t update. LastUpdated will be still no defined at the moment. Binding seems working and thing is online. Any ideas?
A contact via Facebook found an issue with XML responding. On the and of URL there is a number 27. No valid data is the result of it. If the number 27 in URL is not in use, a valid response will be the result. Can
you check this, please?
OK i’m not familiar with your code. At the end, we all think that we have the right ID for our region. Nothing happens no warning no update. I setup all via Paper UI.
I also updated to 2.5.3.
But it still not updating the warnings.
Activated debugging for logging but logs only show regular updating of the channels.
I also did the setup of the dwd binding by paper ui.
Is there a config file for dwd which I can check whether all settings are set correctly? My feeling is that the items are not linked correctly to the channels when using paper ui for setup.
Could solve it.
The binding only works with cell ids for cities (Stadt or Gemeinde). It doesn’t work for region (Kreis).
It would be great this information could be added to the setup page in paper ui.
@Wikibear This could be also the solution for you.
