There are icons ‘battery’ and ‘batterylevel’.
These should change dynamically based on the status:
I put the icons in the standard list widget “oh-list-item”. Regardless of whether I set the value 20 or 80, the icon does not change dynamically.
item config:
Number SmartLock_batteryCharge "Battery Status" <batterylevel> (gGarageSmartLockBattery) ["Control", "Level"]
log:
2022-07-11 17:08:33.653 [INFO ] [openhab.event.ItemCommandEvent ] - Item ‘SmartLock_batteryCharge’ received command 20
result:
expected result icon:
Isn’t that possible in the “oh-list-item”? At least it works for other icons like ‘lock’ or ‘door’.
