Hi
I’m currently writing the sitemap for my house. We have a large number of heating zones and so for the heating portion I’m trying to minimise the space the display uses so that it will be manageable on a mobile phone screen.
For each zone I have a current temperature line and a setpoint line
Setpoint item=Bedroom_Target label=“Bedroom [%.1f °C]” minValue=14 maxValue=27 step=0.5 icon=“heating”
Text item=Bedroom_Temp label=“Bedroom[%.1f °C]” icon=“temperature”<
I would also like to display whether or not the heating is active in a zone or not. There is an item
String Bedroom_State “Bedroom State”(Bedroom) {channel = “neohub:neostat:myhubname:Bedroom:thermostatOutputState”}<
which I could display but that would take another line of display. Is there a way of setting the icon for the Bedroom_Temp line according to the value of the Bedroom_State item ?
Tim
The simplest way I could come up with, is by using the visbility=
Item attribute in your sitemap. In essence, you’d duplicate a line so you can assign another icon depending on whether the heating is on or off, as in:
Default item=Bedroom_Target icon="heating_off" visibility=[Bedroom_State==OFF]
Default item=Bedroom_Target icon="heating_on" visibility=[Bedroom_State==ON]
This of course assumes that Bedroom_State
is always set to either OFF
or ON
, which may not always be true (e.g. at startup or when the binding loses contact to the things it controls).
Also, to make it work, you will have to create icons (heating_off
and heating_off
in /etc/openhab2/icons/classic/
with extension SVG and/or PNG) as I couldn’t yet find a way to use a dynamic icon’s static counterpart (with defined state) for a static item on a sitemap…
You could even go one step further and define colors depending on the temperature in the room, e.g. as in:
// Change the value color of the outside temperature depending on value:
Default item=Wx_OWM_Current_Temperature
valuecolor=[
>=30="red", >=25="orange", >=15="green", 0="silver", <0="purple", <15="blue"
Note that using valuecolor
works as follows:
- the rules are read and evaluated left-to-right
- the first expression which evaluates to
True
will define the color
For this reason, the condition <15="blue"
has been placed at the end to correctly manage the 0°C case and the (Celsius) freezing case. Otherwise the following conditions would never be evaluated: 0="silver", <0="purple"
Thank-you for the detailed reply, I will try this out
This worked an absolute charm using stock icons. So a flame icon if heating and blank if not
Text item=Bedroom_Temp label=“Bedroom[%.1f °C]” icon=“fire” visibility=[Bedroom_State==“Heating”]
Text item=Bedroom_Temp label=“Bedroom[%.1f °C]” visibility=[Bedroom_State==“Off”]<
