Animated Energy Widget for E3DC Solar Home Power Stations.
Screenshots
Resources
uid: E3DC_Portal
tags: []
props:
parameters:
- context: item
label: Stromnetz Verbrauch
required: true
type: TEXT
- context: item
label: Stromnetz Einspeisung
required: true
type: TEXT
- context: item
label: Haushalt Verbrauch
required: true
type: TEXT
- context: item
label: PV Leistung
required: true
type: TEXT
- context: item
label: Batterie Laden
required: true
type: TEXT
- context: item
label: Batterie Entladen
required: true
type: TEXT
- context: item
label: Batterie Ladezustand
required: true
type: TEXT
- context: item
label: Wallbox Ladestrom
required: false
type: TEXT
- context: item
label: externer Stromproduzent
required: false
type: TEXT
parameterGroups: []
timestamp: Mar 10, 2022, 10:08:22 AM
component: f7-card
style:
padding: 1%
justify-content: center
class:
- display-flex
- align-items-center
stylesheet: >
.arrowleft {
#position: absolute;
#top: 50%;
#left: 50%;
#transform: translate(50%,50%);
.arrowleft div {
display: block;
width: 0.4em;
height: 0.4em;
border-bottom: 0.15em solid var(--f7-text-color);
border-right: 0.15em solid var(--f7-text-color);
transform: rotate(135deg);
#margin: -25px;
animation: animate 2s infinite;
} .arrowleft div:nth-child(2){
animation-delay: -0.2s;
} .arrowleft div:nth-child(3){
animation-delay: -0.4s;
} @keyframes animate {
0%{
opacity: 0;
transform: rotate(135deg) translate(-0.7em,-0.7em);
50%{
opacity: 1;
100%{
opacity: 0;
transform: rotate(135deg) translate(0.7em,0.7em);
} .arrowright {
#top: 50%;
#left: 50%;
#transform: translate(-50%,-50%);
.arrowright div {
display: block;
width: 0.4em;
height: 0.4em;
transform: rotate(-45deg);
#margin: -25px;
animation: animate2 2s infinite;
} .arrowright div:nth-child(2) {
animation-delay: 0.2s;
} .arrowright div:nth-child(3) {
animation-delay: 0.4s;
} @keyframes animate2 {
0%{
opacity: 0;
transform: rotate(-45deg) translate(-0.7em,-0.7em);
50%{
opacity: 1;
100%{
opacity: 0;
transform: rotate(-45deg) translate(0.7em,0.7em);
slots:
default:
- component: f7-col
style:
align-items: center
display: flex
flex-direction: column
width: 20%
slots:
default:
- component: oh-icon
height: 40em
icon: e3dc_pv_sun
height: 40em
icon: e3dc_extern
style:
margin-top: 1em
visible: '=(Number.parseFloat(items[props.externerg].state.split(" ")[0]) >= 0) ? true : false'
- component: Label
style:
font-size: 1em
font-weight: bold
text-align: center
margin-top: 0.7em
text: =items[props.batterylevel].state
icon: e3dc_akku_0
height: 40em
visible: '=(Number.parseFloat(items[props.batterylevel].state.split(" ")[0]) < 2) ? true : false'
icon: e3dc_akku_25
height: 40em
visible: '=(Number.parseFloat(items[props.batterylevel].state.split(" ")[0]) >= 2 && Number.parseFloat(items[props.batterylevel].state.split(" ")[0]) < 25) ? true : false'
icon: e3dc_akku_50
height: 40em
visible: '=(Number.parseFloat(items[props.batterylevel].state.split(" ")[0]) >= 25 && Number.parseFloat(items[props.batterylevel].state.split(" ")[0]) < 50) ? true : false'
icon: e3dc_akku_75
height: 40em
visible: '=(Number.parseFloat(items[props.batterylevel].state.split(" ")[0]) >= 50 && Number.parseFloat(items[props.batterylevel].state.split(" ")[0]) < 75) ? true : false'
icon: e3dc_akku_90
height: 40em
visible: '=(Number.parseFloat(items[props.batterylevel].state.split(" ")[0]) >= 75 && Number.parseFloat(items[props.batterylevel].state.split(" ")[0]) < 99) ? true : false'
icon: e3dc_akku_100
height: 40em
visible: '=(Number.parseFloat(items[props.batterylevel].state.split(" ")[0]) >= 99) ? true : false'
- component: f7-col
style:
align-items: center
display: flex
width: 20%
slots:
default:
- component: f7-row
class: arrowright
visible: '=(Number.parseFloat(items[props.pv_leistung].state.split(" ")[0]) > 0) ? true : false'
slots:
default:
- component: Label
class: arrowright div
- component: Label
- component: Label
- component: f7-row
slots:
default:
- component: Label
style:
font-size: 1em
font-weight: bold
text-align: center
padding-bottom: 2.1em
text: =Math.abs(Number.parseFloat(items[props.pv_leistung].state.split(" ")[0])) + ' ᵂ'
- component: f7-row
class: arrowright
slots:
default:
- component: Label
- component: Label
- component: Label
- component: f7-row
slots:
default:
- component: Label
style:
font-size: 1em
font-weight: bold
text-align: center
text: =Math.abs(Number.parseFloat(items[props.externerg].state.split(" ")[0])) + ' ᵂ'
- component: f7-row
class: arrowright
visible: '=(Number.parseFloat(items[props.batterieentladen].state.split(" ")[0]) > 0) ? true : false'
slots:
default:
- component: Label
- component: Label
- component: Label
- component: f7-row
class: arrowleft
visible: '=(Number.parseFloat(items[props.batterieladen].state.split(" ")[0]) > 0) ? true : false'
slots:
default:
- component: Label
class: arrowleft div
- component: Label
- component: Label
- component: Label
style:
color: green
font-size: 1em
font-weight: bold
text-align: center
text: =Math.abs(Number.parseFloat(items[props.batterieladen].state.split(" ")[0])) + ' ᵂ'
- component: Label
style:
color: red
font-size: 1em
font-weight: bold
text-align: center
text: =Math.abs(Number.parseFloat(items[props.batterieentladen].state.split(" ")[0])) + ' ᵂ'
- component: f7-col
style:
align-items: center
display: flex
width: 20%
slots:
default:
- component: f7-block
style:
align-items: center
display: flex
slots: {}
height: 60em
width: 60em
icon: e3dc
- component: f7-col
style:
align-items: center
display: flex
width: 20%
slots:
default:
- component: f7-row
class: arrowright
visible: '=(Number.parseFloat(items[props.netzverbrauch].state.split(" ")[0]) > 0) ? true : false'
slots:
default:
- component: Label
- component: Label
- component: Label
- component: f7-row
class: arrowleft
visible: '=(Number.parseFloat(items[props.netzeinspeisung].state.split(" ")[0]) > 0) ? true : false'
slots:
default:
- component: Label
- component: Label
- component: Label
- component: Label
style:
color: red
font-size: 1em
font-weight: bold
text-align: center
text: =Math.abs(Number.parseFloat(items[props.netzeinspeisung].state.split(" ")[0])) + ' ᵂ'
visible: '=(Number.parseFloat(items[props.netzverbrauch].state.split(" ")[0]) == 0) ? true : false'
- component: Label
style:
color: green
font-size: 1em
font-weight: bold
text-align: center
text: =Math.abs(Number.parseFloat(items[props.netzverbrauch].state.split(" ")[0])) + ' ᵂ'
- component: f7-row
class: arrowright
visible: '=(Number.parseFloat(items[props.wallboxladestrom].state.split(" ")[0]) >= 0) ? true : false'
slots:
default:
- component: Label
- component: Label
- component: Label
- component: Label
style:
font-size: 1em
font-weight: bold
text-align: center
text: =Math.abs(Number.parseFloat(items[props.wallboxladestrom].state.split(" ")[0])) + ' ᵂ'
- component: f7-row
class: arrowright
visible: '=(Number.parseFloat(items[props.gesamtverbrauch].state.split(" ")[0]) > 0) ? true : false'
slots:
default:
- component: Label
- component: Label
- component: Label
- component: Label
style:
font-size: 1em
font-weight: bold
text-align: center
text: =Math.abs(Number.parseFloat(items[props.gesamtverbrauch].state.split(" ")[0])) + ' ᵂ'
- component: f7-col
style:
align-items: center
display: flex
width: 20%
slots:
default:
height: 40em
icon: e3dc_net
height: 40em
icon: e3dc_wallbox
style:
margin-top: 1em
color: orange
height: 40em
icon: e3dc_home
style:
margin-top: 1em
