Easee Binding - Communication Error: Forbidden
I’m looking for help with the Easee Binding on openHAB 5.0.2.
Since November 11. the Easee Site Bridge Thing returns an error message:
Thing ‘easee:site:047bdbf71d’ changed from UNKNOWN: “Waiting for web api login” to OFFLINE (COMMUNICATION_ERROR): Forbidden
It did work before without any issue. Connections are now being refused, even though I haven’t changed anything.
Does it still work for you? Any help and hint to fix this is very appreciated.
Thank you!
Just based on the error message I would guess that maybe they reset your password or something like that. The first thing to try is to go through the initial setup and configuration steps again.
This happend to me too, and I posted a question i Easee binding thread this morning. So myabe better to keep conversations there.
Thanks for your advice.
I deleted the Easee Things, deinstalled the Binding, rebooted the system, installed the Easee Binding again and created the Bridge Thing with no luck. Same errors as before: forbidden.
