@Phuong The error is a result of using an incompatible openhab Version. The binding was compiled against openhab 3.3.0 and for me it works fine with openhab 3.3.0. With openhab 3.2.0 I had the same errors. I guess that using 3.4.0 SNAPSHOT versions should also be ok but I did not try this.
@somy It is just a wrong description, the parameter should be interpreted as seconds. I thought that this is already fixed…
Thank you! I cannot find any trace in log so wasn’t sure how often it pulls. However I noticed I could set interval to 1, in which case does the plugin use the minimal 20 seconds interval or default 1 minute interval?
@AlexF Thanks for your reply.
Yes it’s correct that I’m running on OH 3.2
I also tried to install the 3.4.0 snapshot but got same error https://openhab.jfrog.io/artifactory/libs-pullrequest-local/org/openhab/addons/bundles/org.openhab.binding.easee/3.4.0-SNAPSHOT/org.openhab.binding.easee-3.4.0-SNAPSHOT.jar
@AlexF great work and thanks for sharing, binding works fine for me.
Just one issue, not sure if it is related to my system, but after setting Circuit_Dynamic_Phases to any new value, it takes minutes before Circuit_Phase1,2,3 getting updated with new currents (while the wallbox updates within seconds).
Do you see same behaviour?
Maybe you are using an outdated version of the binding where polling interval is configured in minutes. If you set polling interval to 20 it means it is updated once in 20 minutes.
At least for me I can see values are updated in a few seconds (I have set the interval to 30 seconds).
I’m using OH 3.3 along with your 3.3.0 binding version: org.openhab.binding.easee-3.3.0-SNAPSHOT.jar from 2022-07-08 17:04.
Do I need to update OH & binding to 3.4 to have the polling interval in seconds? as this is how it look today (with polling interval 1), about 15min delay:
2022-08-24 10:24:33.019 [INFO ] [openhab.event.ItemCommandEvent ] - Item ‘Easee_Circuit_Dynamic_Phases’ received command 9;9;9
2022-08-24 10:24:33.030 [INFO ] [penhab.event.ItemStatePredictedEvent] - Item ‘Easee_Circuit_Dynamic_Phases’ predicted to become 9;9;9
2022-08-24 10:24:33.035 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item ‘Easee_Circuit_Dynamic_Phases’ changed from 10;10;10 to 9;9;9
2022-08-24 10:39:36.049 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item ‘Easee_Circuit_Phase1’ changed from 10 A to 9 A
2022-08-24 10:39:36.051 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item ‘Easee_Circuit_Phase2’ changed from 10 A to 9 A
2022-08-24 10:39:36.056 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item ‘Easee_Circuit_Phase3’ changed from 10 A to 9 A
This is weird. One minute should be more or less one minute.
The 3.4.0-SNAPSHOT version is built against openhab 3.3.0 and works fine for me.
I would suggest to try the latest binding version. If there are still huge delays you should set the logging to debug this will give a lot more details.
Alright, 3.4.0-SNAPSHOT works much better and polling interval is in seconds now.
Evenso it still takes up to 2 minutes to feedback the current (maybe it’s an issue with my system load or so…). I leave it like this for the moment.
Then just one other points, whats the difference between these channels?
state#dynamicCircuitCurrentP1 and
dynamic_current#phase1
I use both to see if any of it reacts faster but it’s about same..
This channel is readonly and available for all chargers.
This channel is read-write but only available for type mastercharger. In fact both channels will have the same value (assuming you are on the same circuit).
I’m about to change my method for pause and resumeing my charging session. I try to use the sendcommand channrl but get an error back when sending pause_charging or resume_charging. I hav a string item holding the link to thr channel anf my rules sets the state to it. In the log output I can see the url endpoint and it looks right. I read above that it was an issue about this function but that it should work frome somewhere in june, is there sny builf number to look for or is there still a issue?
It seems like bindning sends command seversl times or until respns is 200, is that right?
This should work in general but the channel was renamed. It is now “commands#genericCommand”. I am using the “commands#startStop” which uses the same API endpoint and it works very well for me.
In case you receive any error please provide some more details otherwise I will not be able to help.
The binding will repeat the API call if the response is not HTTP 200 or HTTP 202. There will be at max 5 retries send.
Since mid of July I have made only a few changes mainly code style which does not affect functionality at all. A few channels were added that will also ot break anything.
The last breaking change was changing the polling interval from minutes to seconds. If you already have this in place you are ready for the official version. If not you coul update to the latest 3.4.0 SNAPSHOT version (which is in fact built against the 3.3.0 openhab version). This has the same functionality as the official version.
@AlexF
for me the channel commands#startStop seems to be not “Writable”.
Even if I try to change it. The status just changed back to the orginal state.
can you add timeToLive to the dynamicCurrent as an failsafe option if binding fails, so that if phases is set to 0 amps, it resets to max amps after a period you can set via a number item
I get the exact same exception. I have value ‘4.0’, but rest is same. There seems to be some issue with the parsing of something, the question is what?
