Hi all,
Is there a way to view the log of when a Rfxcom device is switches on or off?
I know I can view it in the logtail but as it’s filled up with astrobinding messages it doesnt make it easy to search it back.
I read some forum messages about logging but they are all very complicated. I just want to log when a devices is switched. Not more.
Either you can modified the configuration to rotate logs that often or you have way more logging than is typical. Most OH instances, even quite large ones, rotate logs at most once a day.
But to look through all your rotated logs as well use openhab.log* instead of just openhab.log in the commands. That will search through all the rotated log files. You can’t do it through Frontail.
