i’m new for rules, someone know where is the problem on this easy rule on OH2?
the first item
LuceDivano.sendCommand(lucelettura)
doesn’t work here but work on other rules
rule "door_contact"
Item contatto_cucina changed
or Item contatto_sala changed
or Item contatto_bagno changed
or Item alarm_voice changed
or Item alarm_keypad changed
if ((contatto_cucina.state = ON or contatto_cucina.state = ON or contatto_cucina.state = ON )){
if (alarm_voice = ON or alarm_keypad = ON){
allarme_Fired.sendCommand(1)
}else{
allarme_Fired.sendCommand(0)
Thank you
rule "door_contact"
var HSBType lucerelax = new HSBType(new DecimalType(74),new PercentType(78),new PercentType(36))
LuceDivano.sendCommand(lucerelax)
}else{
You should make it a routine to always look at the error messages by the openHAB designer an into the log files to see potential error messages.
One obvious mistake is the comparison with a single equal sign. “Equals” comparison is done with if(a == 5). Correct all your ifs and then check the log for errors.
