You got an answer from @Wolfgang_S resolving the more obvious problem (counting the difference in time). I do “sense” that your question was intended more to the difference between states from now and some time ago. Please have a look into “historicState”.
i can google search and I indeed have javascripts which converts times already.
I was asking more about how folks out there are doing it in OH in some fashionable and convenient way. Just dont like to reinvent the wheel where not needed.
nope, i’m not reffering to that
I simply asked about how anybody (if someone) is doing something like “Motion in Workroom 2hours ago” instead of “Motion in Workroom 2021-05-05:21:23:213+2000”
My take would be to calculate diff from now and convert it via javascript, but if there is a better way in OH let’s share
I think it’s more like my Timestamp=blah, calculate how long ago that was in ‘friendly form’. That’s fairly trivial, but when to calculate is more of a challenge. In a UI for example, a more or less continuous update.
If you would have given that example in the first place…
I use a transformation script for displaying the uptime of my raspi running openHAB. The actual value shows something like: 54 day(s) 12 hours 41 minutes.
Can’t get a VPN to my home ATM (Bavaria seems to be on the outskirts of mobile connectivity ) in order to post the script, however the used math and code isn’t using any black magic.
Convert the timestamp to seconds, do now.toEpochSecond - timestamp to get the duration as a long int, then divide it by the appropriate factors to get days/hrs/min/sec
(function(i) {
if(isNaN(i)) return "NA";
var days = Math.floor(i/1440)
var hours = Math.floor((i-days*1440)/60);
var min = Math.floor((i-hours*60-days*1440)/1);
var pad = "00";
return days+ " Tag(e) " +hours+" Std "+min+" Min";
})(input)
Historic state gives you another timestamp, so that’s not the case in my opinion either.
I’m doing it as follows (let me know if that’s completely stupid way and there is better one )
rule "Helpers: Calculate moveme/contacts ago value"
Time cron "0/30 * * ? * * *"
val newnow = now.toInstant.toEpochMilli
// loop for all items in the group
gSecurity.members.forEach[ ItemName |
var Number diff = 0
var Number prev = 0
val orItem = ScriptServiceUtil.getItemRegistry.getItem(ItemName.name)
val myItem = ScriptServiceUtil.getItemRegistry.getItem(orItem.name + "_t") as GenericItem
if(myItem.state == NULL){
diff = newnow - now.withYear(2020).minusMinutes(10).toInstant.toEpochMilli
}else{
prev = (myItem.state as DateTimeType).zonedDateTime.toInstant.toEpochMilli
diff = newnow - prev
postUpdate(orItem.name+'_d',diff.toString)
and then I have map script
(function(i) {
if (i == 'NULL') { return i; }
if (i == '-') { return 'Unknown'; }
var msPerMinute = 60 * 1000;
var msPerHour = msPerMinute * 60;
var msPerDay = msPerHour * 24;
var msPerMonth = msPerDay * 30;
var msPerYear = msPerDay * 365;
var elapsed = i;
if (elapsed == 0){
return 'Now';
else if (elapsed < msPerMinute) {
return Math.round(elapsed/1000) + ' s ago';
else if (elapsed < msPerHour) {
return Math.round(elapsed/msPerMinute) + ' min ago';
else if (elapsed < msPerDay ) {
return Math.round(elapsed/msPerHour ) + ' h ago';
else if (elapsed < msPerMonth) {
return Math.round(elapsed/msPerDay) + ' days ago';
else if (elapsed < msPerYear) {
return Math.round(elapsed/msPerMonth) + ' months ago';
else {
return Math.round(elapsed/msPerYear ) + ' year ago';
})(input)
on the sitemap I’m displaying *_d item, which is being populated every 30s for each item in the group.
ok so i was not really happy to have another items and rules and stuff…
so i’ve reworked JS transformation so it’s now using original DateTime item which is updated by mqtt item automatically.
Only thing I needed to do is to convert OH timeformat to something JS can work with … not sure how to do it directly as 2021-05-13T11:47:26.209413+02:00 is not recognized in JS 2021-05-13T11:47:26Z+02:00 is
note: why we need to have miliseonds in datetime item?? (can i get rid of them?)
