19:29:47.938 [INFO ] [.internal.things.EBusTypeProviderImpl] - Load custom configuration file ‘file:///etc/openhab2/configurations/vaillant/vaillant_template.json’ …
19:29:48.018 [TRACE] [.ebus.cfg.std.EBusConfigurationReader] - Add template with global id vaillant.templ.cntstarts to registry …
19:29:48.033 [TRACE] [.ebus.cfg.std.EBusConfigurationReader] - Add template with global id vaillant.templ.cntminutes to registry …
19:29:48.051 [TRACE] [.ebus.cfg.std.EBusConfigurationReader] - Add template with global id vaillant.templ.cnthours to registry …
19:29:48.069 [TRACE] [.ebus.cfg.std.EBusConfigurationReader] - Add template with global id vaillant.templ.cntfuel to registry …
19:29:48.090 [TRACE] [.ebus.cfg.std.EBusConfigurationReader] - Add template with global id vaillant.templ.unit to registry …
19:29:48.108 [TRACE] [.ebus.cfg.std.EBusConfigurationReader] - Add template with global id vaillant.templ.fueltype to registry …
19:29:48.126 [TRACE] [.ebus.cfg.std.EBusConfigurationReader] - Add template with global id vaillant.templ.countertype to registry …
19:29:48.145 [TRACE] [.ebus.cfg.std.EBusConfigurationReader] - Add template with global id vaillant.templ.opdatacyclic to registry …
19:29:48.166 [TRACE] [.ebus.cfg.std.EBusConfigurationReader] - Add template with global id vaillant.templ.opdatatransfer to registry …
19:29:48.187 [TRACE] [.ebus.cfg.std.EBusConfigurationReader] - Add template with global id vaillant.templ.opdataheat to registry …
19:29:48.207 [TRACE] [.ebus.cfg.std.EBusConfigurationReader] - Add template with global id vaillant.templ.opdataaction to registry …
19:29:48.226 [TRACE] [.ebus.cfg.std.EBusConfigurationReader] - Add template with global id vaillant.templ.desiredtemp to registry …
19:29:48.245 [TRACE] [.ebus.cfg.std.EBusConfigurationReader] - Add template with global id vaillant.templ.outsidetemp to registry …
19:29:48.264 [TRACE] [.ebus.cfg.std.EBusConfigurationReader] - Add template with global id vaillant.templ.percent to registry …
19:29:48.282 [TRACE] [.ebus.cfg.std.EBusConfigurationReader] - Add template with global id vaillant.templ.percent0 to registry …
19:29:48.300 [TRACE] [.ebus.cfg.std.EBusConfigurationReader] - Add template with global id vaillant.templ.percent1 to registry …
19:29:48.325 [TRACE] [.ebus.cfg.std.EBusConfigurationReader] - Add template with global id vaillant.templ.percent2 to registry …
19:29:48.345 [TRACE] [.ebus.cfg.std.EBusConfigurationReader] - Add template with global id vaillant.templ.percents to registry …
19:29:48.365 [TRACE] [.ebus.cfg.std.EBusConfigurationReader] - Add template with global id vaillant.templ.temp to registry …
19:29:48.384 [TRACE] [.ebus.cfg.std.EBusConfigurationReader] - Add template with global id vaillant.templ.temp0 to registry …
19:29:48.403 [TRACE] [.ebus.cfg.std.EBusConfigurationReader] - Add template with global id vaillant.templ.temp1 to registry …
19:29:48.423 [TRACE] [.ebus.cfg.std.EBusConfigurationReader] - Add template with global id vaillant.templ.temp2 to registry …
19:29:48.439 [TRACE] [.ebus.cfg.std.EBusConfigurationReader] - Add template with global id vaillant.templ.press to registry …
19:29:48.454 [TRACE] [.ebus.cfg.std.EBusConfigurationReader] - Add template with global id vaillant.templ.btime to registry …
19:29:48.470 [TRACE] [.ebus.cfg.std.EBusConfigurationReader] - Add template with global id vaillant.templ.bdate to registry …
19:29:48.487 [TRACE] [.ebus.cfg.std.EBusConfigurationReader] - Add template with global id vaillant.templ.id to registry …
19:29:48.507 [TRACE] [.ebus.cfg.std.EBusConfigurationReader] - Add template with global id vaillant.templ.version to registry …
19:29:48.524 [TRACE] [.ebus.cfg.std.EBusConfigurationReader] - Add template with global id vaillant.templ.skip to registry …
19:29:48.546 [TRACE] [.ebus.cfg.std.EBusConfigurationReader] - Add template with global id vaillant.templ.temps to registry …
19:29:48.564 [TRACE] [.ebus.cfg.std.EBusConfigurationReader] - Add template with global id vaillant.templ.temps2 to registry …
19:29:48.595 [TRACE] [.ebus.cfg.std.EBusConfigurationReader] - Add template with global id vaillant.templ.tempv to registry …
19:29:48.618 [TRACE] [.ebus.cfg.std.EBusConfigurationReader] - Add template with global id vaillant.templ.press to registry …
19:29:48.636 [TRACE] [.ebus.cfg.std.EBusConfigurationReader] - Add template with global id vaillant.templ.pressv to registry …
19:29:48.653 [TRACE] [.ebus.cfg.std.EBusConfigurationReader] - Add template with global id vaillant.templ.date to registry …
19:29:48.670 [TRACE] [.ebus.cfg.std.EBusConfigurationReader] - Add template with global id vaillant.templ.daysel to registry …
19:29:48.688 [TRACE] [.ebus.cfg.std.EBusConfigurationReader] - Add template with global id vaillant.templ.days to registry …
19:29:48.716 [TRACE] [.ebus.cfg.std.EBusConfigurationReader] - Add template with global id vaillant.templ.time to registry …
19:29:48.736 [TRACE] [.ebus.cfg.std.EBusConfigurationReader] - Add template with global id vaillant.templ.time2 to registry …
19:29:48.763 [TRACE] [.ebus.cfg.std.EBusConfigurationReader] - Add template with global id vaillant.templ.minutes to registry …
19:29:48.782 [TRACE] [.ebus.cfg.std.EBusConfigurationReader] - Add template with global id vaillant.templ.minutes0 to registry …
19:29:48.804 [TRACE] [.ebus.cfg.std.EBusConfigurationReader] - Add template with global id vaillant.templ.minutes2 to registry …
19:29:48.825 [TRACE] [.ebus.cfg.std.EBusConfigurationReader] - Add template with global id vaillant.templ.hoursum to registry …
19:29:48.845 [TRACE] [.ebus.cfg.std.EBusConfigurationReader] - Add template with global id vaillant.templ.hoursum2 to registry …
19:29:48.862 [TRACE] [.ebus.cfg.std.EBusConfigurationReader] - Add template with global id vaillant.templ.hours to registry …
19:29:48.885 [TRACE] [.ebus.cfg.std.EBusConfigurationReader] - Add template with global id vaillant.templ.hours1 to registry …
19:29:48.910 [TRACE] [.ebus.cfg.std.EBusConfigurationReader] - Add template with global id vaillant.templ.hours12 to registry …
19:29:48.931 [TRACE] [.ebus.cfg.std.EBusConfigurationReader] - Add template with global id vaillant.templ.hour to registry …
19:29:48.953 [TRACE] [.ebus.cfg.std.EBusConfigurationReader] - Add template with global id vaillant.templ.seconds to registry …
19:29:48.972 [TRACE] [.ebus.cfg.std.EBusConfigurationReader] - Add template with global id vaillant.templ.seconds0 to registry …
19:29:48.990 [TRACE] [.ebus.cfg.std.EBusConfigurationReader] - Add template with global id vaillant.templ.seconds2 to registry …
19:29:49.006 [TRACE] [.ebus.cfg.std.EBusConfigurationReader] - Add template with global id vaillant.templ.seconds4 to registry …
19:29:49.024 [TRACE] [.ebus.cfg.std.EBusConfigurationReader] - Add template with global id vaillant.templ.calibration to registry …
19:29:49.039 [TRACE] [.ebus.cfg.std.EBusConfigurationReader] - Add template with global id vaillant.templ.calibration0 to registry …
19:29:49.055 [TRACE] [.ebus.cfg.std.EBusConfigurationReader] - Add template with global id vaillant.templ.calibration1 to registry …
19:29:49.072 [TRACE] [.ebus.cfg.std.EBusConfigurationReader] - Add template with global id vaillant.templ.calibrations to registry …
19:29:49.087 [TRACE] [.ebus.cfg.std.EBusConfigurationReader] - Add template with global id vaillant.templ.calibrationv to registry …
19:29:49.104 [TRACE] [.ebus.cfg.std.EBusConfigurationReader] - Add template with global id vaillant.templ.integral to registry …
19:29:49.121 [TRACE] [.ebus.cfg.std.EBusConfigurationReader] - Add template with global id vaillant.templ.hcmode to registry …
19:29:49.137 [TRACE] [.ebus.cfg.std.EBusConfigurationReader] - Add template with global id vaillant.templ.hcmode2 to registry …
19:29:49.154 [TRACE] [.ebus.cfg.std.EBusConfigurationReader] - Add template with global id vaillant.templ.mcmode to registry …
19:29:49.172 [TRACE] [.ebus.cfg.std.EBusConfigurationReader] - Add template with global id vaillant.templ.mctype to registry …
19:29:49.198 [TRACE] [.ebus.cfg.std.EBusConfigurationReader] - Add template with global id vaillant.templ.mctype7 to registry …
19:29:49.216 [TRACE] [.ebus.cfg.std.EBusConfigurationReader] - Add template with global id vaillant.templ.hwcmode to registry …
19:29:49.234 [TRACE] [.ebus.cfg.std.EBusConfigurationReader] - Add template with global id vaillant.templ.hwcmode2 to registry …
19:29:49.252 [TRACE] [.ebus.cfg.std.EBusConfigurationReader] - Add template with global id vaillant.templ.mixer to registry …
19:29:49.270 [TRACE] [.ebus.cfg.std.EBusConfigurationReader] - Add template with global id vaillant.templ.daynight to registry …
19:29:49.284 [TRACE] [.ebus.cfg.std.EBusConfigurationReader] - Add template with global id vaillant.templ.status to registry …
19:29:49.290 [INFO ] [smarthome.event.ItemStateChangedEvent] - LivingColors1Alert changed from SELECT to NONE
19:29:49.301 [TRACE] [.ebus.cfg.std.EBusConfigurationReader] - Add template with global id vaillant.templ.onoff to registry …
19:29:49.326 [TRACE] [.ebus.cfg.std.EBusConfigurationReader] - Add template with global id vaillant.templ.yesno to registry …
19:29:49.417 [TRACE] [.ebus.cfg.std.EBusConfigurationReader] - Add template with global id vaillant.templ.errorok to registry …
19:29:49.440 [TRACE] [.ebus.cfg.std.EBusConfigurationReader] - Add template with global id vaillant.templ.sensor to registry …
19:29:49.455 [TRACE] [.ebus.cfg.std.EBusConfigurationReader] - Add template with global id vaillant.templ.tempmirror to registry …
19:29:49.475 [TRACE] [.ebus.cfg.std.EBusConfigurationReader] - Add template with global id vaillant.templ.pressm to registry …
19:29:49.499 [TRACE] [.ebus.cfg.std.EBusConfigurationReader] - Add template with global id vaillant.templ.pressm2 to registry …
19:29:49.525 [TRACE] [.ebus.cfg.std.EBusConfigurationReader] - Add template with global id vaillant.templ.uin100 to registry …
19:29:49.545 [TRACE] [.ebus.cfg.std.EBusConfigurationReader] - Add template with global id vaillant.templ.curve to registry …
19:29:49.562 [TRACE] [.ebus.cfg.std.EBusConfigurationReader] - Add template with global id vaillant.templ.phase1 to registry …
19:29:49.582 [TRACE] [.ebus.cfg.std.EBusConfigurationReader] - Add template with global id vaillant.templ.phase2 to registry …
19:29:49.602 [TRACE] [.ebus.cfg.std.EBusConfigurationReader] - Add template with global id vaillant.templ.phase3 to registry …
19:29:49.619 [TRACE] [.ebus.cfg.std.EBusConfigurationReader] - Add template with global id vaillant.templ.code to registry …
19:29:49.636 [TRACE] [.ebus.cfg.std.EBusConfigurationReader] - Add template with global id vaillant.templ.error to registry …
19:29:49.651 [TRACE] [.ebus.cfg.std.EBusConfigurationReader] - Add template with global id vaillant.templ.from to registry …
19:29:49.668 [TRACE] [.ebus.cfg.std.EBusConfigurationReader] - Add template with global id vaillant.templ.to to registry …
19:29:49.688 [TRACE] [.ebus.cfg.std.EBusConfigurationReader] - Add template with global id vaillant.templ.backtype to registry …
19:29:49.706 [TRACE] [.ebus.cfg.std.EBusConfigurationReader] - Add template with global id vaillant.templ.backmode to registry …
19:29:49.723 [TRACE] [.ebus.cfg.std.EBusConfigurationReader] - Add template with global id vaillant.templ.power to registry …
19:29:49.741 [TRACE] [.ebus.cfg.std.EBusConfigurationReader] - Add template with global id vaillant.templ.energy to registry …
19:29:49.760 [TRACE] [.ebus.cfg.std.EBusConfigurationReader] - Add template with global id vaillant.templ.energyr to registry …
19:29:49.776 [TRACE] [.ebus.cfg.std.EBusConfigurationReader] - Add template with global id vaillant.templ.energy4 to registry …
19:29:49.795 [TRACE] [.ebus.cfg.std.EBusConfigurationReader] - Add template with global id vaillant.templ.cntstarts to registry …
19:29:49.813 [TRACE] [.ebus.cfg.std.EBusConfigurationReader] - Add template with global id vaillant.templ.cntstarts2 to registry …
19:29:49.829 [TRACE] [.ebus.cfg.std.EBusConfigurationReader] - Add template with global id vaillant.templ.pumppow to registry …
19:29:49.849 [TRACE] [.ebus.cfg.std.EBusConfigurationReader] - Add template with global id vaillant.templ.pumpstate to registry …
19:29:49.867 [TRACE] [.ebus.cfg.std.EBusConfigurationReader] - Add template with global id vaillant.templ.dcfstate to registry …
19:29:49.889 [TRACE] [.ebus.cfg.std.EBusConfigurationReader] - Add template with global id vaillant.templ.phaseok to registry …
19:29:49.904 [TRACE] [.ebus.cfg.std.EBusConfigurationReader] - Add template with global id vaillant.templ.switchvalve to registry …
19:29:49.921 [TRACE] [.ebus.cfg.std.EBusConfigurationReader] - Add template with global id vaillant.templ.switchvalve2 to registry …
19:29:49.939 [TRACE] [.ebus.cfg.std.EBusConfigurationReader] - Add template with global id vaillant.templ.hfrom to registry …
19:29:49.955 [TRACE] [.ebus.cfg.std.EBusConfigurationReader] - Add template with global id vaillant.templ.hto to registry …
19:29:49.973 [TRACE] [.ebus.cfg.std.EBusConfigurationReader] - Add template with global id vaillant.templ.hpstatus to registry …
19:29:49.988 [TRACE] [.ebus.cfg.std.EBusConfigurationReader] - Add template with global id vaillant.templ.frequency to registry …
19:29:50.005 [TRACE] [.ebus.cfg.std.EBusConfigurationReader] - Add template with global id vaillant.templ.zonesel to registry …
19:29:50.021 [TRACE] [.ebus.cfg.std.EBusConfigurationReader] - Add template with global id vaillant.templ.sfmode to registry …
19:29:50.036 [TRACE] [.ebus.cfg.std.EBusConfigurationReader] - Add template with global id vaillant.templ.opmode to registry …
19:29:50.054 [TRACE] [.ebus.cfg.std.EBusConfigurationReader] - Add template with global id vaillant.templ.zmapping to registry …
19:29:50.069 [TRACE] [.ebus.cfg.std.EBusConfigurationReader] - Add template with global id vaillant.templ.hcname to registry …
19:29:50.084 [TRACE] [.ebus.cfg.std.EBusConfigurationReader] - Add template with global id vaillant.templ.zname to registry …
19:29:50.099 [TRACE] [.ebus.cfg.std.EBusConfigurationReader] - Add template with global id vaillant.templ.shortname to registry …
19:29:50.116 [TRACE] [.ebus.cfg.std.EBusConfigurationReader] - Add template with global id vaillant.templ.phone to registry …
19:29:50.131 [TRACE] [.ebus.cfg.std.EBusConfigurationReader] - Add template with global id vaillant.templ.shortphone to registry …
19:29:50.151 [TRACE] [.ebus.cfg.std.EBusConfigurationReader] - Add template with global id vaillant.templ.mamode to registry …
19:29:50.168 [TRACE] [.ebus.cfg.std.EBusConfigurationReader] - Add template with global id vaillant.templ.offmode to registry …
19:29:50.188 [TRACE] [.ebus.cfg.std.EBusConfigurationReader] - Add template with global id vaillant.templ.rcmode to registry …
19:29:50.203 [TRACE] [.ebus.cfg.std.EBusConfigurationReader] - Add template block with global id vaillant.templ to registry …
19:29:50.220 [TRACE] [.ebus.cfg.std.EBusConfigurationReader] - Add template with global id vaillant.tempsensor.temp to registry …
19:29:50.233 [TRACE] [.ebus.cfg.std.EBusConfigurationReader] - Add template with global id vaillant.tempsensor.sensor to registry …
19:29:50.249 [TRACE] [.ebus.cfg.std.EBusConfigurationReader] - Add template block with global id vaillant.tempsensor to registry …
19:29:50.262 [TRACE] [.ebus.cfg.std.EBusConfigurationReader] - Add template with global id vaillant.tempmirrorsensor.temp to registry …
19:29:50.276 [TRACE] [.ebus.cfg.std.EBusConfigurationReader] - Add template with global id vaillant.tempmirrorsensor.tempmirror to registry …
19:29:50.290 [TRACE] [.ebus.cfg.std.EBusConfigurationReader] - Add template with global id vaillant.tempmirrorsensor.sensor to registry …
19:29:50.305 [TRACE] [.ebus.cfg.std.EBusConfigurationReader] - Add template block with global id vaillant.tempmirrorsensor to registry …
19:29:50.320 [TRACE] [.ebus.cfg.std.EBusConfigurationReader] - Add template with global id vaillant.presssensor.press to registry …
19:29:50.334 [TRACE] [.ebus.cfg.std.EBusConfigurationReader] - Add template with global id vaillant.presssensor.sensor to registry …
19:29:50.348 [TRACE] [.ebus.cfg.std.EBusConfigurationReader] - Add template block with global id vaillant.presssensor to registry …
19:29:50.364 [TRACE] [.ebus.cfg.std.EBusConfigurationReader] - Add template with global id vaillant.phase.phase1 to registry …
19:29:50.380 [TRACE] [.ebus.cfg.std.EBusConfigurationReader] - Add template with global id vaillant.phase.phase2 to registry …
19:29:50.393 [TRACE] [.ebus.cfg.std.EBusConfigurationReader] - Add template with global id vaillant.phase.phase3 to registry …
19:29:50.406 [TRACE] [.ebus.cfg.std.EBusConfigurationReader] - Add template block with global id vaillant.phase to registry …
19:29:50.428 [TRACE] [.ebus.cfg.std.EBusConfigurationReader] - Add template with global id vaillant.errors.error1 to registry …
19:29:50.442 [TRACE] [.ebus.cfg.std.EBusConfigurationReader] - Add template with global id vaillant.errors.error2 to registry …
19:29:50.457 [TRACE] [.ebus.cfg.std.EBusConfigurationReader] - Add template with global id vaillant.errors.error3 to registry …
19:29:50.471 [TRACE] [.ebus.cfg.std.EBusConfigurationReader] - Add template with global id vaillant.errors.error4 to registry …
19:29:50.485 [TRACE] [.ebus.cfg.std.EBusConfigurationReader] - Add template with global id vaillant.errors.error5 to registry …
19:29:50.501 [TRACE] [.ebus.cfg.std.EBusConfigurationReader] - Add template block with global id vaillant.errors to registry …
19:29:50.515 [TRACE] [.ebus.cfg.std.EBusConfigurationReader] - Add template with global id vaillant.errorhistory.status to registry …
19:29:50.530 [TRACE] [.ebus.cfg.std.EBusConfigurationReader] - Add template with global id vaillant.errorhistory.time2 to registry …
19:29:50.544 [TRACE] [.ebus.cfg.std.EBusConfigurationReader] - Add template with global id vaillant.errorhistory.date to registry …
19:29:50.558 [TRACE] [.ebus.cfg.std.EBusConfigurationReader] - Add template with global id vaillant.errorhistory.error to registry …
19:29:50.574 [TRACE] [.ebus.cfg.std.EBusConfigurationReader] - Add template block with global id vaillant.errorhistory to registry …
19:29:50.581 [TRACE] [.ebus.cfg.std.EBusConfigurationReader] - Add template with global id vaillant.slot1.from to registry …
19:29:50.589 [TRACE] [.ebus.cfg.std.EBusConfigurationReader] - Add template with global id vaillant.slot1.to to registry …
19:29:50.597 [TRACE] [.ebus.cfg.std.EBusConfigurationReader] - Add template block with global id vaillant.slot1 to registry …
19:29:50.604 [TRACE] [.ebus.cfg.std.EBusConfigurationReader] - Add template with global id vaillant.slot2.from to registry …
19:29:50.612 [TRACE] [.ebus.cfg.std.EBusConfigurationReader] - Add template with global id vaillant.slot2.to to registry …
19:29:50.621 [TRACE] [.ebus.cfg.std.EBusConfigurationReader] - Add template block with global id vaillant.slot2 to registry …
19:29:50.628 [TRACE] [.ebus.cfg.std.EBusConfigurationReader] - Add template with global id vaillant.slot3.from to registry …
19:29:50.636 [TRACE] [.ebus.cfg.std.EBusConfigurationReader] - Add template with global id vaillant.slot3.to to registry …
19:29:50.644 [TRACE] [.ebus.cfg.std.EBusConfigurationReader] - Add template block with global id vaillant.slot3 to registry …
19:29:50.652 [ERROR] [sdev.ebus.command.EBusCommandRegistry] - error!
de.csdev.ebus.cfg.EBusConfigurationReaderException: Unable to find a template for id vaillant.slot1!
at de.csdev.ebus.cfg.std.EBusConfigurationReader.parseValueConfiguration(EBusConfigurationReader.java:380) ~[bundleFile:?]
at de.csdev.ebus.cfg.std.EBusConfigurationReader.parseTemplateConfiguration(EBusConfigurationReader.java:160) ~[bundleFile:?]
at de.csdev.ebus.cfg.std.EBusConfigurationReader.loadConfigurationCollection(EBusConfigurationReader.java:134) ~[bundleFile:?]
at de.csdev.ebus.cfg.std.EBusConfigurationReader.loadConfigurationCollection(EBusConfigurationReader.java:114) ~[bundleFile:?]
at de.csdev.ebus.command.EBusCommandRegistry.loadCommandCollection(EBusCommandRegistry.java:99) [bundleFile:?]
at org.openhab.binding.ebus.internal.things.EBusTypeProviderImpl.loadConfigurationByUrl(EBusTypeProviderImpl.java:331) [bundleFile:?]
at org.openhab.binding.ebus.internal.things.EBusTypeProviderImpl.updateConfiguration(EBusTypeProviderImpl.java:487) [bundleFile:?]
at org.openhab.binding.ebus.internal.things.EBusTypeProviderImpl.activate(EBusTypeProviderImpl.java:108) [bundleFile:?]
at sun.reflect.GeneratedMethodAccessor152.invoke(Unknown Source) ~[?:?]
at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43) ~[?:1.8.0_232]
at java.lang.reflect.Method.invoke(Method.java:498) ~[?:1.8.0_232]
at org.apache.felix.scr.impl.inject.methods.BaseMethod.invokeMethod(BaseMethod.java:228) [bundleFile:?]
at org.apache.felix.scr.impl.inject.methods.BaseMethod.access$500(BaseMethod.java:41) [bundleFile:?]
at org.apache.felix.scr.impl.inject.methods.BaseMethod$Resolved.invoke(BaseMethod.java:664) [bundleFile:?]
at org.apache.felix.scr.impl.inject.methods.BaseMethod.invoke(BaseMethod.java:510) [bundleFile:?]
at org.apache.felix.scr.impl.inject.methods.ActivateMethod.invoke(ActivateMethod.java:317) [bundleFile:?]
at org.apache.felix.scr.impl.inject.methods.ActivateMethod.invoke(ActivateMethod.java:307) [bundleFile:?]
at org.apache.felix.scr.impl.manager.SingleComponentManager.createImplementationObject(SingleComponentManager.java:340) [bundleFile:?]
at org.apache.felix.scr.impl.manager.SingleComponentManager.createComponent(SingleComponentManager.java:114) [bundleFile:?]
at org.apache.felix.scr.impl.manager.SingleComponentManager.getService(SingleComponentManager.java:982) [bundleFile:?]
at org.apache.felix.scr.impl.manager.SingleComponentManager.getServiceInternal(SingleComponentManager.java:955) [bundleFile:?]
at org.apache.felix.scr.impl.manager.SingleComponentManager.getService(SingleComponentManager.java:900) [bundleFile:?]
at org.eclipse.osgi.internal.serviceregistry.ServiceFactoryUse$1.run(ServiceFactoryUse.java:212) [org.eclipse.osgi-3.12.100.jar:?]
at java.security.AccessController.doPrivileged(Native Method) [?:1.8.0_232]
at org.eclipse.osgi.internal.serviceregistry.ServiceFactoryUse.factoryGetService(ServiceFactoryUse.java:210) [org.eclipse.osgi-3.12.100.jar:?]
at org.eclipse.osgi.internal.serviceregistry.ServiceFactoryUse.getService(ServiceFactoryUse.java:111) [org.eclipse.osgi-3.12.100.jar:?]
at org.eclipse.osgi.internal.serviceregistry.ServiceConsumer$2.getService(ServiceConsumer.java:45) [org.eclipse.osgi-3.12.100.jar:?]
at org.eclipse.osgi.internal.serviceregistry.ServiceRegistrationImpl.getService(ServiceRegistrationImpl.java:508) [org.eclipse.osgi-3.12.100.jar:?]
at org.eclipse.osgi.internal.serviceregistry.ServiceRegistry.getService(ServiceRegistry.java:461) [org.eclipse.osgi-3.12.100.jar:?]
at org.eclipse.osgi.internal.framework.BundleContextImpl.getService(BundleContextImpl.java:624) [org.eclipse.osgi-3.12.100.jar:?]
at org.apache.felix.scr.impl.manager.SingleRefPair.getServiceObject(SingleRefPair.java:86) [bundleFile:?]
at org.apache.felix.scr.impl.inject.BindParameters.getServiceObject(BindParameters.java:47) [bundleFile:?]
at org.apache.felix.scr.impl.inject.field.FieldHandler$ReferenceMethodImpl.getServiceObject(FieldHandler.java:519) [bundleFile:?]
at org.apache.felix.scr.impl.manager.DependencyManager.getServiceObject(DependencyManager.java:2308) [bundleFile:?]
at org.apache.felix.scr.impl.manager.DependencyManager$SingleDynamicCustomizer.prebind(DependencyManager.java:954) [bundleFile:?]
at org.apache.felix.scr.impl.manager.DependencyManager.prebind(DependencyManager.java:1568) [bundleFile:?]
at org.apache.felix.scr.impl.manager.AbstractComponentManager.collectDependencies(AbstractComponentManager.java:1029) [bundleFile:?]
at org.apache.felix.scr.impl.manager.SingleComponentManager.getServiceInternal(SingleComponentManager.java:935) [bundleFile:?]
at org.apache.felix.scr.impl.inject.methods.BindMethod.getServiceObject(BindMethod.java:664) [bundleFile:?]
at org.apache.felix.scr.impl.manager.DependencyManager.doInvokeBindMethod(DependencyManager.java:1805) [bundleFile:?]
at org.apache.felix.scr.impl.manager.DependencyManager.invokeBindMethod(DependencyManager.java:1788) [bundleFile:?]
at org.apache.felix.scr.impl.manager.SingleComponentManager.invokeBindMethod(SingleComponentManager.java:435) [bundleFile:?]
at org.apache.felix.scr.impl.manager.DependencyManager$MultipleDynamicCustomizer.addedService(DependencyManager.java:325) [bundleFile:?]
at org.apache.felix.scr.impl.manager.DependencyManager$MultipleDynamicCustomizer.addedService(DependencyManager.java:294) [bundleFile:?]
at org.apache.felix.scr.impl.manager.ServiceTracker$Tracked.customizerAdded(ServiceTracker.java:1216) [bundleFile:?]
at org.apache.felix.scr.impl.manager.ServiceTracker$Tracked.customizerAdded(ServiceTracker.java:1137) [bundleFile:?]
at org.apache.felix.scr.impl.manager.ServiceTracker$AbstractTracked.trackAdding(ServiceTracker.java:944) [bundleFile:?]
at org.apache.felix.scr.impl.manager.ServiceTracker$AbstractTracked.track(ServiceTracker.java:880) [bundleFile:?]
at org.apache.felix.scr.impl.manager.ServiceTracker$Tracked.serviceChanged(ServiceTracker.java:1168) [bundleFile:?]
at org.apache.felix.scr.impl.BundleComponentActivator$ListenerInfo.serviceChanged(BundleComponentActivator.java:125) [bundleFile:?]
at org.eclipse.osgi.internal.serviceregistry.FilteredServiceListener.serviceChanged(FilteredServiceListener.java:109) [org.eclipse.osgi-3.12.100.jar:?]
at org.eclipse.osgi.internal.framework.BundleContextImpl.dispatchEvent(BundleContextImpl.java:920) [org.eclipse.osgi-3.12.100.jar:?]
at org.eclipse.osgi.framework.eventmgr.EventManager.dispatchEvent(EventManager.java:230) [org.eclipse.osgi-3.12.100.jar:?]
at org.eclipse.osgi.framework.eventmgr.ListenerQueue.dispatchEventSynchronous(ListenerQueue.java:148) [org.eclipse.osgi-3.12.100.jar:?]
at org.eclipse.osgi.internal.serviceregistry.ServiceRegistry.publishServiceEventPrivileged(ServiceRegistry.java:862) [org.eclipse.osgi-3.12.100.jar:?]
at org.eclipse.osgi.internal.serviceregistry.ServiceRegistry.publishServiceEvent(ServiceRegistry.java:801) [org.eclipse.osgi-3.12.100.jar:?]
at org.eclipse.osgi.internal.serviceregistry.ServiceRegistrationImpl.register(ServiceRegistrationImpl.java:127) [org.eclipse.osgi-3.12.100.jar:?]
at org.eclipse.osgi.internal.serviceregistry.ServiceRegistry.registerService(ServiceRegistry.java:225) [org.eclipse.osgi-3.12.100.jar:?]
at org.eclipse.osgi.internal.framework.BundleContextImpl.registerService(BundleContextImpl.java:469) [org.eclipse.osgi-3.12.100.jar:?]
at org.apache.felix.scr.impl.manager.AbstractComponentManager$3.register(AbstractComponentManager.java:906) [bundleFile:?]
at org.apache.felix.scr.impl.manager.AbstractComponentManager$3.register(AbstractComponentManager.java:892) [bundleFile:?]
at org.apache.felix.scr.impl.manager.RegistrationManager.changeRegistration(RegistrationManager.java:128) [bundleFile:?]
at org.apache.felix.scr.impl.manager.AbstractComponentManager.registerService(AbstractComponentManager.java:959) [bundleFile:?]
at org.apache.felix.scr.impl.manager.AbstractComponentManager.activateInternal(AbstractComponentManager.java:732) [bundleFile:?]
at org.apache.felix.scr.impl.manager.DependencyManager$SingleDynamicCustomizer.addedService(DependencyManager.java:825) [bundleFile:?]
at org.apache.felix.scr.impl.manager.DependencyManager$SingleDynamicCustomizer.addedService(DependencyManager.java:767) [bundleFile:?]
at org.apache.felix.scr.impl.manager.SingleComponentManager.reconfigure(SingleComponentManager.java:734) [bundleFile:?]
at org.apache.felix.scr.impl.manager.SingleComponentManager.reconfigure(SingleComponentManager.java:673) [bundleFile:?]
at org.apache.felix.scr.impl.manager.ConfigurableComponentHolder.configurationUpdated(ConfigurableComponentHolder.java:435) [bundleFile:?]
at org.apache.felix.scr.impl.manager.RegionConfigurationSupport.configurationEvent(RegionConfigurationSupport.java:316) [bundleFile:?]
at org.apache.felix.scr.impl.manager.RegionConfigurationSupport$2.configurationEvent(RegionConfigurationSupport.java:118) [bundleFile:?]
at org.apache.felix.cm.impl.ConfigurationManager$FireConfigurationEvent.sendEvent(ConfigurationManager.java:1709) [bundleFile:?]
at org.apache.felix.cm.impl.ConfigurationManager$FireConfigurationEvent.run(ConfigurationManager.java:1651) [bundleFile:?]
at org.apache.felix.cm.impl.UpdateThread.run0(UpdateThread.java:138) [bundleFile:?]
at org.apache.felix.cm.impl.UpdateThread.run(UpdateThread.java:105) [bundleFile:?]
at java.lang.Thread.run(Thread.java:748) [?:1.8.0_232]
19:29:50.740 [INFO ] [.internal.things.EBusTypeProviderImpl] - Load custom configuration file ‘file:///etc/openhab2/configurations/vaillant/39200.15.392_configuration.json’ …
19:29:51.768 [INFO ] [ome.event.ThingStatusInfoChangedEvent] - ‘ebus:bridge:fdcdc515’ changed from UNINITIALIZED (HANDLER_MISSING_ERROR) to INITIALIZING
19:29:51.810 [WARN ] [us.internal.handler.EBusBridgeHandler] - Enable advanced logging for eBUS commands!
