finally I managed to get the ebus 2 binding into my openHAB but I do not understand how to get any data from my heating system.
Can someone please explain me how to set it up properly. I have a lot of ebus devices now in my things but no data is showing up. I want to configure everything with Visual studio code but Im not sure if it is right what I’m doing!
This is an example of one item.
Number HU_Aussentemperatur “Aussentemperatur [%.1f °C]” (HeatingUnit) { ebus=“ebus:vrc700_general:esera:15:vrc700_general_gen_bc-temp-outside#temp-outside” }
Never used the binding but try using channel= in place of ebus= in items file and please use code fences. It’s the paper icon to the left of the gear icon.
Example (using code fences):
Number HU_Aussentemperatur "Aussentemperatur [%.1f °C]" (HeatingUnit) { channel="ebus:vrc700_general:esera:15:vrc700_general_gen_bc-temp-outside#temp-outside" }
Only create items in either PaperUI or files…never in both and make sure you do not have “simple mode” turned on in PaperUI. You may have a situation where duplicate links/items exist thus the reason some not working.
Look in: /var/lib/openhab2/jsondb/org.eclipse.smarthome.core.thing.link.ItemChannelLink.json and make sure there isn’t a Link hanging around.
For items check: /var/lib/openhab2/jsondb/org.eclipse.smarthome.core.items.Item.json
If you have duplicate stop OH first and edit the file to remove them then clean the cache and restart.
EDIT:@xxx_turbo_xxx
Just checked the doc’s and no channel needed so try with ebus and leave the extra stuff off the end like below.
Number HU_Aussentemperatur "Aussentemperatur [%.1f °C]" (HeatingUnit) { ebus="ebus:vrc700_general:esera:15" }
EDIT 2:
The extra stuff on the end, if needed or wanted, should be separated using a . not a - so you may want to try that as well.
Best guess example:
Number HU_Aussentemperatur "Aussentemperatur [%.1f °C]" (HeatingUnit) { ebus="ebus:vrc700_general:esera:15:vrc700_general_gen_bc.temp_outside" }
I made a fresh installation today so I can rule out that there is a problem caused by mixing paper Ui and files. I made everything in files and I tried the Paper Ui in my previous installation. I’ll try the different syntax.
What I also recognise is the increased CPU load resulting in high CPU temp after adding all the ebus stuff…
sure… I ment I made the things in the paper ui and linked them to items created in the files…
Works pretty well with all my other stuff… But not with this eBus. It is driving me crazy. This Binding is actually the reaso why I’ve spent weeks now to get into this Raspberry stuff as my heating costs are by far too high and my plan was to reduce costs by optimising the system settings. But firstly I need to log data an understand what is going on there…
Did not manage to get it run with different syntax. I think the general problem is that there is nowhere a proper description or manual of what the binding is doing and in wich way it works. If you understand a system it is much easier to find problems…
Concerning the CPU load / temp… With the eBus binding and things added the teno goes up from 55°C to 65°C constantly…
