Here the new marketplace link for the 5.x binding.
is there a way to deactivate the logs from ebus?
In your ebus Bridge Thing you have the option to enable or disable βadvanced loggingβ, which is basically logging all the ebus messages in separate csv files (unresolved.csv and resolved.csv).
The regular logging to your openhab.log of INFO or WARN or other messages can be done via the openhab-cli. See the openhab Logging page. It can be turned OFF as well via openhab-cli.
i still got this warnings
21:47:00.751 [WARN ] [sdev.ebus.core.EBusLowLevelController] - Received byte 0xAA is not equal to send byte 0x15! Stop send attempt β¦
21:47:14.163 [WARN ] [sdev.ebus.core.EBusLowLevelController] - Received byte 0x11 is not equal to send byte 0x15! Stop send attempt β¦
21:47:15.758 [WARN ] [sdev.ebus.core.EBusLowLevelController] - Received byte 0xD0 is not equal to send byte 0xB5! Stop send attempt β¦
21:47:16.856 [WARN ] [sdev.ebus.core.EBusLowLevelController] - Received byte 0xF5 is not equal to send byte 0x15! Stop send attempt β¦
21:47:17.913 [WARN ] [sdev.ebus.core.EBusLowLevelController] - Received byte 0x2A is not equal to send byte 0x15! Stop send attempt β¦
21:47:20.717 [WARN ] [sdev.ebus.core.EBusLowLevelController] - Received byte 0x00 is not equal to send byte 0x15! Stop send attempt β¦```
advanced logging is not active.
also in openhab-cli all ebus relevant addons are OFF
Logger β Level
ββββββββββββββββββββββββββββββββββββββββββββββββββββββββββΌββββββ
ESPHOMEDEVICE β WARN
ROOT β WARN
core.auth β TRACE
de.sdev.ebus.core.EBusLowLevelController β off
ebu β WARN
ebus β WARN
ebusd β OFF
org.openhab.binding.ebus β OFF
org.openhab.binding.ebus.internal.EBusLowLevelController β OFF
When using βlist -sβ in openhab-cli console, I see the package βde.cs-dev.ebus.ebus-coreβ.
I suppose that is the one you need to silence and not βde.sdev.ebus.core.EBusLowLevelControllerβ.
