to your first issue. You configurated the ebus.cfg like this: ?
parserUrl=platform:/base/../configurations/ebus-config.json OR
parserUrl=file:///opt/openhab2/ebus-config.json
parsers=common,custom
It is important to add custom to the parsers list.
To your second question, it looks like you send to many telegrams to the bus. Please reduce the interval etc.
Another reason could be that you are not able to send your telegram at the first time because of collisions.
2017-04-05 17:08:02.480 [ERROR] [rnal.connection.EBusCommandProcessor] - Error while running runnable …
java.lang.NullPointerException
at org.openhab.binding.ebus.internal.connection.EBusCommandProcessor.composeSendData(EBusCommandProcessor.java:307)[207:org.openhab.binding.ebus:1.9.0]
at org.openhab.binding.ebus.internal.connection.EBusCommandProcessor$1.run(EBusCommandProcessor.java:106)[207:org.openhab.binding.ebus:1.9.0]
at java.util.concurrent.Executors$RunnableAdapter.call(Executors.java:511)[:1.8.0_121]
at java.util.concurrent.FutureTask.runAndReset(FutureTask.java:308)[:1.8.0_121]
at java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.access$301(ScheduledThreadPoolExecutor.java:180)[:1.8.0_121]
at java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.run(ScheduledThreadPoolExecutor.java:294)[:1.8.0_121]
at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1142)[:1.8.0_121]
at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:617)[:1.8.0_121]
at java.lang.Thread.run(Thread.java:745)[:1.8.0_121]
i aloo found some error when custom is off(is this connected with issue no 2?):
2017-04-05 17:16:50.835 [ERROR] [onnection.AbstractEBusWriteConnector] - Skip telegram FF 08 B5 09 03 0D 83 00 AA after 10 attempts …
