Hello All
I have created new items file for ebus 1.8RC6 bindigs
Number e_Temp_Zew “Outside temperature [%.1f °C]” { ebus=“id:controller.temp_outside.temp_outside, cmd:controller.temp_outside, dst:15, refresh:300” }
Number e_Temp_Room "Room temperature [%.1f °C] { ebus=“id:controller.temp_room_disp.temp_room_disp, cmd:controller.temp_room_disp, dst:15, refresh:300” }
Number e_Temp_Room_Dis “Dis Room temperature [%.1f °C]” { ebus=“id:controller.temp_room.temp_room, cmd:controller.temp_room, dst:15, refresh300” }
Number e_HC1_Program"HC1prog[%s]”{ ebus="id:heating.program_heating_circuit,cmd:heating.program_heating_circuit,refresh120,set:heating.set_program_heating_circuit.program_heating_circuit,dst:15”}
Number e_DHW_Program “DHW Operation mode[%s]” { ebus=“id:dhw.program_dhw_circuit, cmd:dhw.program_dhw_circuit, refresh:120, set:dhw.set_program_dhw_circuit.program_dhw_circuit, dst:15” }
Number e_DHW_Temp_Act “DHW Actual temp [%.1f °C]” { ebus=“id:dhw.temp_d_actual_dhw, cmd:dhw.temp_d_actual_dhw, dst:15, refresh:300” }
Number e_DHW_Temp_Set “DHW Setpoin temperature [%.1f °C]” { ebus=“id:dhw.temp_d_dhw, cmd:dhw.temp_d_dhw, dst:15, refresh:300, set:dhw.set_temp_d_dhw.temp_d_dhw” }
Number e_HC1_Temp_Napis “HC1 Manual over spoint [%.1f °C]” {ebus=“id:heating.temp_d_room_override, cmd:heating.temp_d_room_override, dst:15, refresh:300” }
Number e_HC1_Temp_Set_Night “HC1 Night Setpoint [%.1f °C]” {ebus=“id:heating.temp_d_night, cmd:heating.temp_d_night, dst:15, refresh:300, set:heating.set_temp_d_night.temp_d_night”}
Number e_HC1_curve “HC1 Heating curve[%.1f]” (Vaillant) {ebus=“id:heating.temp_hcurve, cmd:heating.temp_hcurve , dst:15, refresh:300”}
Number e_HC1_Day_Temp “HC1 day temp [%.f°C]” (Vaillant) {ebus=“id:heating.temp_d_man, cmd:heating.temp_d_man, refresh:300, dst:15, set:heating.set_temp_d_man.temp_d_man”}
Items are corresponding to vaillant-vrc430-configuration.json
I also add
ebus:parserUrl=platform:/base/…/configurations/ebus-config.json
ebus:parsers=custom
(ebus-config.json is renamed vaillant-vrc430-configuration.json file from nikoraes post)
generally I can read data from listed items but can’t set any value…
Any idea how to solve problem ?
Maybe I do something wrong.
The strange is that in old version of ebus binding
some item works only with “program” at the end of set command but another need full entry. For examples
Number e_HC1_Program “Heating program HC1[%s]” (Vaillant){ ebus=“id:heating.heating_circuit_program, cmd:heating.heating_circuit_program, dst:15, refresh:300, set:heating.set_hea
ting_circuit_program.program” }
Number e_HC1_Temp_Set_Night “HC1 Night Setpoint [%.1f °C]” (Vaillant) {ebus=“id:heating.temp_d_night, cmd:heating.temp_d_night, dst:15, refresh:300, set:heating.set_temp_d_night.temp_d_night”}
I can’t explain this …
Reards
Tomek
