Echo Control binding - nextAlarm stopped working
I use the echo control binding. It was configured with thing/item files in Openhab2. and running since 2 years.
I use nextAlarm and textToSpeech (and lastVoiceCommand for debugging).
NextAlarm stopped working on Oct. 14. textToSpeech is all ok. lastVoiceCommand is also not working.
I did rebuild the Items with Openhab3 interface. Same result - no nextAlarm and no lastVoiceCommand; textToSpeech working.
Regards, Felix
The openHAB version of amazonechocontrol is broken. Use the fixed one from the marketplace (if you use openHAB 3.1 or newer).
Thank you, found the suggestion right after posting. On my way to install the update.
