I have openHAB 3.0 with Hue Emulation up and running and I configured also sudo iptables -t nat -A PREROUTING -p tcp -m tcp --dport 80 -j REDIRECT --to-ports 8080.
I’m not able to configure at the Echo (4. Gen) the Hue Skill, because the Echo is not able to find a Hue Bridge, Echo tells me: there are no Hue Bridges on your network and I used the Device Pairing at the Hue emulation.
I want to configure the Echo to use the Hue skill so that over the Hue Emulation I’m able to control some of my items and I will use this configuration with the Echo offline option, so that I do not need the Amazon connection for the voice recognition.
in the open hab log I get
2021-01-24 16:39:10.055 [WARN ] [ache.cxf.phase.PhaseInterceptorChain] - Interceptor for {http://192.168.yy.xx:80/description.xml}WebClient has thrown exception, unwinding now
org.apache.cxf.interceptor.Fault: Could not send Message.
If you are unable to pair and discovery devices with your echo then you will need to install nginx. The troubleshooting section in the hue emulation documentation has details about this.
when I try to open http://192.168.19.29:8080/api/testuser/lights) I get
[{“error”:{“address”:“testuser/lights”,“description”:“Not Authorized”,“type”:1}}]
and this in the openhab.log
Interceptor for {http://[fe80:0:0:0:2061:68ef:d117:d004]/description.xml
and I m not able to install the Hue Skill because my Echo doesn’t find a Hue Bridge: There are no Hue Bridges on your network.
