I did download and install the old Java that was a dependancy. I haven’t restarted (and honestly won’t be able to for a while)
Any bit of help would be great (@Kai I think you’re maintainer right?) Thanks!!
!SESSION 2016-08-25 12:37:34.308 -----------------------------------------------
eclipse.buildId=unknown
java.version=1.6.0_65
java.vendor=Apple Inc.
BootLoader constants: OS=macosx, ARCH=x86_64, WS=cocoa, NL=en_US
Command-line arguments: -os macosx -ws cocoa -arch x86_64
!ENTRY org.eclipse.smarthome.designer.core 4 0 2016-08-25 12:37:35.577
!MESSAGE FrameworkEvent ERROR
!STACK 0
org.osgi.framework.BundleException: Could not resolve module: org.eclipse.smarthome.designer.core [225]
Unresolved requirement: Import-Package: org.eclipse.smarthome.config.core
-> Export-Package: org.eclipse.smarthome.config.core; bundle-version="0.9.0.201608240508"; bundle-symbolic-name="org.eclipse.smarthome.config.core"; version="0.0.0"
org.eclipse.smarthome.config.core [217]
Unresolved requirement: Import-Package: org.eclipse.smarthome.core.common
-> Export-Package: org.eclipse.smarthome.core.common; bundle-version="0.9.0.201608240508"; bundle-symbolic-name="org.eclipse.smarthome.core"; version="0.0.0"
org.eclipse.smarthome.core [218]
Unresolved requirement: Require-Capability: osgi.ee; filter:="(&(osgi.ee=JavaSE)(version=1.7))"
at org.eclipse.osgi.container.Module.start(Module.java:434)
at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.incStartLevel(ModuleContainer.java:1582)
at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.incStartLevel(ModuleContainer.java:1562)
at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.doContainerStartLevel(ModuleContainer.java:1533)
at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.dispatchEvent(ModuleContainer.java:1476)
at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.dispatchEvent(ModuleContainer.java:1)
at org.eclipse.osgi.framework.eventmgr.EventManager.dispatchEvent(EventManager.java:230)
at org.eclipse.osgi.framework.eventmgr.EventManager$EventThread.run(EventManager.java:340)
!ENTRY org.eclipse.smarthome.designer.ui 4 0 2016-08-25 12:37:35.580
!STACK 0
org.osgi.framework.BundleException: Could not resolve module: org.eclipse.smarthome.designer.ui [226]
!ENTRY org.eclipse.smarthome.config.core 4 0 2016-08-25 12:37:35.626
!STACK 0
org.osgi.framework.BundleException: Could not resolve module: org.eclipse.smarthome.config.core [217]
!ENTRY org.eclipse.smarthome.model.item 4 0 2016-08-25 12:37:35.630
!STACK 0
org.osgi.framework.BundleException: Could not resolve module: org.eclipse.smarthome.model.item [230]
Unresolved requirement: Import-Package: org.eclipse.smarthome.core.autoupdate
-> Export-Package: org.eclipse.smarthome.core.autoupdate; bundle-version="0.9.0.201608240508"; bundle-symbolic-name="org.eclipse.smarthome.core.autoupdate"; version="0.0.0"
org.eclipse.smarthome.core.autoupdate [219]
Unresolved requirement: Import-Package: org.eclipse.smarthome.core.events
-> Export-Package: org.eclipse.smarthome.core.events; bundle-version="0.9.0.201608240508"; bundle-symbolic-name="org.eclipse.smarthome.core"; version="0.0.0"; uses:="org.eclipse.smarthome.core.items,org.osgi.service.event,org.eclipse.smarthome.core.types"
!ENTRY org.eclipse.smarthome.core.persistence 4 0 2016-08-25 12:37:39.280
!STACK 0
org.osgi.framework.BundleException: Could not resolve module: org.eclipse.smarthome.core.persistence [220]
at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.incStartLevel(ModuleContainer.java:1561)
!ENTRY org.eclipse.smarthome.core.voice 4 0 2016-08-25 12:37:39.283
!STACK 0
org.osgi.framework.BundleException: Could not resolve module: org.eclipse.smarthome.core.voice [224]
Unresolved requirement: Import-Package: org.eclipse.smarthome.core.audio
-> Export-Package: org.eclipse.smarthome.core.audio; bundle-version="0.9.0.201608240508"; bundle-symbolic-name="org.eclipse.smarthome.core"; version="0.0.0"
Snippit from the bottom
!ENTRY org.eclipse.jdt.annotation 2 0 2016-08-25 12:37:40.349
!MESSAGE Could not resolve module: org.eclipse.jdt.annotation [171]
Unresolved requirement: Require-Capability: osgi.ee; filter:="(&(osgi.ee=JavaSE)(version=1.8))"
!ENTRY org.eclipse.smarthome.core.voice 2 0 2016-08-25 12:37:40.349
!MESSAGE Could not resolve module: org.eclipse.smarthome.core.voice [224]
-> Export-Package: org.eclipse.smarthome.core.audio; bundle-version=“0.9.0.201608240508”; bundle-symbolic-name=“org.eclipse.smarthome.core”; version=“0.0.0"
Unresolved requirement: Require-Capability: osgi.ee; filter:=”(&(osgi.ee=JavaSE)(version=1.7))"
!ENTRY org.eclipse.smarthome.model.core 2 0 2016-08-25 12:37:40.349
!MESSAGE Could not resolve module: org.eclipse.smarthome.model.core [229]
-> Export-Package: org.eclipse.smarthome.config.core; bundle-version=“0.9.0.201608240508”; bundle-symbolic-name=“org.eclipse.smarthome.config.core”; version=“0.0.0"
-> Export-Package: org.eclipse.smarthome.core.common; bundle-version=“0.9.0.201608240508”; bundle-symbolic-name=“org.eclipse.smarthome.core”; version=“0.0.0"
Unresolved requirement: Require-Capability: osgi.ee; filter:=”(&(osgi.ee=JavaSE)(version=1.7))”
!ENTRY org.eclipse.osgi 4 0 2016-08-25 12:37:40.351
!MESSAGE Application error
!STACK 1
java.lang.RuntimeException: Application “org.eclipse.smarthome.designer.ui.application” could not be found in the registry. The applications available are: org.eclipse.ant.core.antRunner, org.eclipse.ant.ui.antRunner, org.eclipse.e4.ui.workbench.swt.E4Application, org.eclipse.e4.ui.workbench.swt.GenTopic, org.eclipse.emf.codegen.CodeGen, org.eclipse.emf.codegen.JMerger, org.eclipse.emf.codegen.ecore.Generator, org.eclipse.emf.mwe.core.WorkflowRunner, org.eclipse.equinox.app.error, org.eclipse.equinox.p2.director, org.eclipse.equinox.p2.garbagecollector.application, org.eclipse.equinox.p2.publisher.InstallPublisher, org.eclipse.equinox.p2.publisher.EclipseGenerator, org.eclipse.equinox.p2.publisher.ProductPublisher, org.eclipse.equinox.p2.publisher.FeaturesAndBundlesPublisher, org.eclipse.equinox.p2.reconciler.application, org.eclipse.equinox.p2.repository.repo2runnable, org.eclipse.equinox.p2.repository.metadataverifier, org.eclipse.equinox.p2.artifact.repository.mirrorApplication, org.eclipse.equinox.p2.metadata.repository.mirrorApplication, org.eclipse.equinox.p2.updatesite.UpdateSitePublisher, org.eclipse.equinox.p2.publisher.UpdateSitePublisher, org.eclipse.equinox.p2.publisher.CategoryPublisher, org.eclipse.help.base.infocenterApplication, org.eclipse.help.base.helpApplication, org.eclipse.help.base.indexTool, org.eclipse.jdt.apt.core.aptBuild, org.eclipse.jdt.core.JavaCodeFormatter, org.eclipse.jdt.core.JavaIndexer, org.eclipse.pde.build.Build, org.eclipse.ui.ide.workbench.
at org.eclipse.equinox.internal.app.EclipseAppContainer.startDefaultApp(EclipseAppContainer.java:248)
at org.eclipse.equinox.internal.app.MainApplicationLauncher.run(MainApplicationLauncher.java:29)
at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.runApplication(EclipseAppLauncher.java:134)
at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.start(EclipseAppLauncher.java:104)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:382)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:236)
at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:39)
at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:25)
at java.lang.reflect.Method.invoke(Method.java:597)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:648)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:603)
at org.eclipse.equinox.launcher.Main.run(Main.java:1465)
