I don’t know what to tell you. I just setup another one, on Linux, and Paper UI is there. Was everything downloaded and the build complete? I’m only seeing the one error, and it is in Paper UI, but that didn’t seem to effect it. When my wife wakes up, I’ll have her try it on Windows.
I cleared my m2, and Paper UI had issues (errors in the log). I manually reran the PaperUI Setup.launch, and all was good. Running the setup tasks again would probably take care of it too.
Ran the PaperUI Setup.launch file, after it finally completed, PaperUI is accessible again, although no proper Bindings are available to install in the Add-Ons section.
About 100 errors, all of the type Access restriction: The <constructor/field/method/type> of ‘’ is not API (restriction on required library…. Doesn’t seem related to the Paper UI issue.
I don’t see the PaperUI Setup.launch in the IDE…? Did I miss something at install time?
Found it…
From the testing I’ve done while trying to get Paper UI in Core Development, those errors sound like you need to run the setup tasks again. Did you select both Core Development and Addon Development selected in the installer?
FYI the ui’s have just been moved to their own repository: https://github.com/openhab/openhab-webui
If you would do a rebase of your branch to the main openhab2-addons they will be gone.
Thank you, @hilbrand. I saw the PR yesterday, so was expecting this. After your post, I see they are now gone from openhab-addons and the PR has been merged. Sounds like we’ll need to stop installing IDEs again, until the setup is updated.
There is one PR still pending on openhab-core that moves the dashboard to -webui. After that has happened, at least all files are where they belong to.
The best people to ask are the maintainers. Report your issues in Github, and if you can, help with a solution. Core, Addons and Webui all have active issues related to UIs, builds, or the IDE. There have been some major changes, so we’ll need to be patient as everything gets put back together again!
Hello @wborn,
These days I have seen several PR mergers for the operation of PaperUI, congratulations for the hard work you do.
What I can not understand if you can run a new installation running on Eclipse IDE, up to 2 days ago the UI did not work.
I need the installation to take the development and debug a binding.
What can you suggest?
