I have been unsuccessful in getting the latest download of Eclipse setup. I am using Eclipse 2021-12 with jdk-11.0.17. My path variables are set for jdk-11.0.17. I have tried Maven 3.8.6 and 3.9.0 with the same results. Eclipse was installed with jdk-11.0.17 selected, but does reference jdk17, which is also installed, but not referenced in any environment variables.
Eclipse builds, resolves and runs without issue. maven clean install throws the following Warning…
[INFO] --- enforcer:3.0.0-M2:enforce (enforce-java) @ org.openhab.binding.elkm1 ---
[WARNING] Rule 0: org.apache.maven.plugins.enforcer.RequireJavaVersion failed with message:
Detected JDK Version: 11.0.17 is not in the allowed range [17.0,18.0).
[INFO] ------------------------------------------------------------------------
[INFO] BUILD FAILURE
[INFO] Total time: 3.875 s
[INFO] Finished at: 2023-02-08T14:22:27-05:00
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-enforcer-plugin:3.0.0-M2:enforce (enforce-java) on project org.openhab.binding.elkm1: Some Enforcer rules have failed. Look above for specific messages explaining why the rule failed. -> [Help 1]
Any help would be appreciated.
Thanks!
