Eclipse SmartHome shows tons of errors in rules
I am fairly new to OpenHAB. I am using eclipse smarthome as suggested however rules show tons of errors like undefined methods, “Timer cannot resolved to a t3ype” etc. Is there anything I missed in the configuration? The rules themselves work fine so I am quite certain that the syntax is correct.
Regards,
JP
You should try version 0.8 instead of 0.9. I had the same problem.
Thomas
