I tried to install openhab-development, eclipse-smart-home-runtime by using the eclipse installer on my windows machine. All compiled and I got a successful built. I tried to launch the system and got this:
!SESSION SLF4J: Failed to load class “org.slf4j.impl.StaticLoggerBinder”.
SLF4J: Defaulting to no-operation (NOP) logger implementation
SLF4J: See http://www.slf4j.org/codes.html#StaticLoggerBinder for further details.
2019-01-29 14:33:23.467 -----------------------------------------------
eclipse.buildId=unknown
java.version=1.8.0_201
java.vendor=Oracle Corporation
BootLoader constants: OS=win32, ARCH=x86_64, WS=win32, NL=de_DE
Framework arguments: -application org.eclipse.ui.ide.workbench
Command-line arguments: -application org.eclipse.ui.ide.workbench -data C:\Users\jobauer\joba\workspaceopenhab\openhab2-master\ws/…/runtime-org.openhab.runtime.product.product -dev file:C:/Users/jobauer/joba/workspaceopenhab/openhab2-master/ws/.metadata/.plugins/org.eclipse.pde.core/openHAB_Runtime/dev.properties -os win32 -ws win32 -arch x86_64 -consoleLog -console
!ENTRY org.eclipse.jetty.osgi.boot 4 0 2019-01-29 14:33:24.811
!MESSAGE FrameworkEvent ERROR
!STACK 0
org.osgi.framework.BundleException: Could not resolve module: org.eclipse.jetty.osgi.boot [54]
** Unresolved requirement: Import-Package: org.eclipse.jetty.annotations; version="[9.3.0,10.0.0)"; resolution:=“optional”**
** Unresolved requirement: Import-Package: org.eclipse.jetty.deploy.bindings; version="[9.3.0,10.0.0)"**
** -> Export-Package: org.eclipse.jetty.deploy.bindings; bundle-symbolic-name=“org.eclipse.jetty.deploy”; bundle-version=“9.3.15.v20161220”; version=“9.3.15”; uses:=“org.eclipse.jetty.deploy,org.eclipse.jetty.deploy.graph,org.eclipse.jetty.server”**
** org.eclipse.jetty.deploy [50]**
** Unresolved requirement: Import-Package: org.eclipse.jetty.jmx; version="[9.3.15,9.3.16)"; resolution:=“optional”**
** Unresolved requirement: Import-Package: org.eclipse.jetty.server; version="[9.3.15,9.3.16)"**
** Unresolved requirement: Import-Package: org.eclipse.jetty.deploy; version="[9.3.0,10.0.0)"**
** -> Export-Package: org.eclipse.jetty.deploy; bundle-symbolic-name=“org.eclipse.jetty.deploy”; bundle-version=“9.3.15.v20161220”; version=“9.3.15”; uses:=“org.eclipse.jetty.deploy.graph,org.eclipse.jetty.server,org.eclipse.jetty.server.handler,org.eclipse.jetty.util,org.eclipse.jetty.util.annotation,org.eclipse.jetty.util.component”**
** at org.eclipse.osgi.container.Module.start(Module.java:444)**
** at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.incStartLevel(ModuleContainer.java:1628)**
** at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.incStartLevel(ModuleContainer.java:1608)**
** at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.doContainerStartLevel(ModuleContainer.java:1579)**
** at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.dispatchEvent(ModuleContainer.java:1522)**
** at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.dispatchEvent(ModuleContainer.java:1)**
** at org.eclipse.osgi.framework.eventmgr.EventManager.dispatchEvent(EventManager.java:230)**
** at org.eclipse.osgi.framework.eventmgr.EventManager$EventThread.run(EventManager.java:340)**
osgi> **
!ENTRY org.eclipse.jetty.client 4 0 2019-01-29 14:33:24.998
!STACK 0
org.osgi.framework.BundleException: Could not resolve module: org.eclipse.jetty.client [49]
** Unresolved requirement: Import-Package: org.eclipse.jetty.http; version="[9.3.15,9.3.16)"
!ENTRY org.eclipse.jetty.deploy 4 0 2019-01-29 14:33:25.000
!STACK 0
org.osgi.framework.BundleException: Could not resolve module: org.eclipse.jetty.deploy [50]
!ENTRY org.eclipse.jetty.osgi.httpservice 4 0 2019-01-29 14:33:25.001
!STACK 0
org.osgi.framework.BundleException: Could not resolve module: org.eclipse.jetty.osgi.httpservice [55]
** Unresolved requirement: Import-Package: org.eclipse.jetty.servlet; version="[9.1.0,10.0.0)"**
** -> Export-Package: org.eclipse.jetty.servlet; bundle-symbolic-name=“org.eclipse.jetty.servlet”; bundle-version=“9.4.5.v20170502”; version=“9.4.5”; uses:=“javax.servlet,javax.servlet.descriptor,javax.servlet.http,org.eclipse.jetty.http.pathmap,org.eclipse.jetty.security,org.eclipse.jetty.server,org.eclipse.jetty.server.handler,org.eclipse.jetty.server.handler.gzip,org.eclipse.jetty.server.session,org.eclipse.jetty.util,org.eclipse.jetty.util.annotation,org.eclipse.jetty.util.component,org.eclipse.jetty.util.resource”**
** org.eclipse.jetty.servlet [59]**
** Unresolved requirement: Import-Package: org.eclipse.jetty.jmx; version="[9.4.5,9.4.6)"; resolution:=“optional”**
** Unresolved requirement: Import-Package: org.eclipse.jetty.security; version="[9.4.5,9.4.6)"**
!ENTRY org.eclipse.jetty.proxy 4 0 2019-01-29 14:33:25.003
!STACK 0
org.osgi.framework.BundleException: Could not resolve module: org.eclipse.jetty.proxy [56]
** Unresolved requirement: Import-Package: org.eclipse.jetty.client; version="[9.3.15,9.3.16)"**
** -> Export-Package: org.eclipse.jetty.client; bundle-symbolic-name=“org.eclipse.jetty.client”; bundle-version=“9.3.15.v20161220”; version=“9.3.15”; uses:=“org.eclipse.jetty.client.api,org.eclipse.jetty.client.util,org.eclipse.jetty.http,org.eclipse.jetty.io,org.eclipse.jetty.util,org.eclipse.jetty.util.annotation,org.eclipse.jetty.util.component,org.eclipse.jetty.util.log,org.eclipse.jetty.util.ssl,org.eclipse.jetty.util.thread”**
** org.eclipse.jetty.client [49]**
** Unresolved requirement: Import-Package: org.eclipse.jetty.http; version="[9.3.15,9.3.16)"**
** Unresolved requirement: Import-Package: org.eclipse.jetty.client.api; version="[9.3.15,9.3.16)"**
** -> Export-Package: org.eclipse.jetty.client.api; bundle-symbolic-name=“org.eclipse.jetty.client”; bundle-version=“9.3.15.v20161220”; version=“9.3.15”; uses:=“org.eclipse.jetty.http,org.eclipse.jetty.util”**
!ENTRY org.eclipse.jetty.security 4 0 2019-01-29 14:33:25.004
!STACK 0
org.osgi.framework.BundleException: Could not resolve module: org.eclipse.jetty.security [57]
!ENTRY org.eclipse.jetty.servlet 4 0 2019-01-29 14:33:25.005
!STACK 0
org.osgi.framework.BundleException: Could not resolve module: org.eclipse.jetty.servlet [59]
!ENTRY org.eclipse.jetty.webapp 4 0 2019-01-29 14:33:25.006
!STACK 0
org.osgi.framework.BundleException: Could not resolve module: org.eclipse.jetty.webapp [61]
!ENTRY org.eclipse.jetty.websocket.client 4 0 2019-01-29 14:33:25.008
!STACK 0
org.osgi.framework.BundleException: Could not resolve module: org.eclipse.jetty.websocket.client [63]
** Unresolved requirement: Import-Package: org.eclipse.jetty.io; version="[9.3.15,9.3.16)"**
!ENTRY org.eclipse.jetty.websocket.common 4 0 2019-01-29 14:33:25.009
!STACK 0
org.osgi.framework.BundleException: Could not resolve module: org.eclipse.jetty.websocket.common [64]
!ENTRY org.eclipse.jetty.xml 4 0 2019-01-29 14:33:25.010
!STACK 0
org.osgi.framework.BundleException: Could not resolve module: org.eclipse.jetty.xml [65]
** Unresolved requirement: Import-Package: org.eclipse.jetty.util; version="[9.3.15,9.3.16)"**
!ENTRY org.jupnp 4 0 2019-01-29 14:33:25.040
!STACK 0
org.osgi.framework.BundleException: Could not resolve module: org.jupnp [76]
** Unresolved requirement: Import-Package: org.eclipse.jetty.client; version="[9.3.14,10.0.0)"**
** Unresolved requirement: Import-Package: org.eclipse.jetty.client.api; version="[9.3.14,10.0.0)"**
!ENTRY org.eclipse.osgi 4 0 2019-01-29 14:33:25.042
!MESSAGE Bundle initial@reference:file:plugins/org.eclipse.jetty.client_9.3.15.v20161220.jar was not resolved.
!ENTRY org.eclipse.osgi 4 0 2019-01-29 14:33:25.043
!MESSAGE Bundle initial@reference:file:plugins/org.eclipse.jetty.deploy_9.3.15.v20161220.jar was not resolved.
!ENTRY org.eclipse.osgi 4 0 2019-01-29 14:33:25.044
!MESSAGE Bundle initial@reference:file:plugins/org.eclipse.jetty.osgi.boot_9.3.15.v20161220.jar was not resolved.
!ENTRY org.eclipse.osgi 4 0 2019-01-29 14:33:25.045
!MESSAGE Bundle initial@reference:file:plugins/org.eclipse.jetty.osgi.httpservice_9.3.15.v20161220.jar was not resolved.
!ENTRY org.eclipse.osgi 4 0 2019-01-29 14:33:25.046
!MESSAGE Bundle initial@reference:file:plugins/org.eclipse.jetty.proxy_9.3.15.v20161220.jar was not resolved.
!ENTRY org.eclipse.osgi 4 0 2019-01-29 14:33:25.047
!MESSAGE Bundle initial@reference:file:plugins/org.eclipse.jetty.security_9.3.15.v20161220.jar was not resolved.
!ENTRY org.eclipse.osgi 4 0 2019-01-29 14:33:25.048
!MESSAGE Bundle initial@reference:file:plugins/org.eclipse.jetty.servlet_9.4.5.v20170502.jar was not resolved.
!ENTRY org.eclipse.osgi 4 0 2019-01-29 14:33:25.049
!ENTRY org.eclipse.osgi 4 0 2019-01-29 14:33:25.050
!MESSAGE Bundle initial@reference:file:plugins/org.eclipse.jetty.webapp_9.3.15.v20161220.jar was not resolved.
!MESSAGE Bundle initial@reference:file:plugins/org.eclipse.jetty.websocket.client_9.3.15.v20161220.jar was not resolved.
!ENTRY org.eclipse.osgi 4 0 2019-01-29 14:33:25.051
!MESSAGE Bundle initial@reference:file:plugins/org.eclipse.jetty.websocket.common_9.3.15.v20161220.jar was not resolved.
!ENTRY org.eclipse.osgi 4 0 2019-01-29 14:33:25.052
!MESSAGE Bundle initial@reference:file:plugins/org.eclipse.jetty.xml_9.3.15.v20161220.jar was not resolved.
!ENTRY org.eclipse.osgi 4 0 2019-01-29 14:33:25.053
!MESSAGE Bundle initial@reference:file:plugins/org.jupnp_2.5.1.jar was not resolved.
