- Platform information:
- Hardware: QNAP Nas w. Docker OH3 image
- openHAB version: 3.01
Dear all,
Easy task (it seems), but I’m stuck again
I want to visualize values I retreive from mqtt.
So I set up a broker connection Thing (mqtt:broker:xxxxx) and defined a trigger channel (which seems to be the only way to subscribe to an mqtt topic?)
The event trigger fires, which is good; log:
[INFO ] [openhab.event.ChannelTriggeredEvent ] - mqtt:broker:xxxxxxxx:CO2 triggered 565
Now I want to have the value (565) somehow visualized.
First try was to define an Item following this value, which seems not possible.
Second option would be to use a rule to transfer the mqtt value into a dummy item
And here I don’t get a clue on how to do that, even reading loads of documentation and forums. Can anybody give me the right hint here?
Thanks a lot!
Peter
