OH 3.1.0M4 on a CentOS8 system.
I’m trying to add an action to send a couple telegram messages in an ECMA Script. I’m copying this from a working rule and making some minor changes. After putting in the code and clicking on Save everything seems fine. I click on the “Run Now” at the bottom and the messages get sent. Then I click on Back to get to the main rule and it’s showing me:
Status:
UNINITIALIZED
HANDLER_INITIALIZING_ERROR
Getting handler 'script.ScriptAction' for module '1' failed: Config parameter
'script' is missing in the configuration of module '1'.
Looking at the Code tab all the commands I put in are now gone.
The commands:
var telegramActionMe = actions.get("telegram", "telegram:telegramBot:bot")
telegramActionMe.sendTelegram("Something happened. Image to follow...")
telegramActionMe.sendTelegramPhoto("http://camera03/snapshot/view0.jpg","camera")
Can’t see any difference between this and a similar rule that is working. When it fails I don’t see anything pop up in the logs beyond:
Failed to execute rule ‘Example_Rule' with status 'UNINITIALIZED'
