Issue of the topic: it is difficult to write a script that works reliably for me.
I try to change the state (color) of a zigbee rgb-lamp via ConBee binding over time controlled by a script. I have JSScript installed and use ECMAScript (ECMAScript 262 Edition 11).
So I have the related color item var light = items.getItem("BadlichtSpiegelMLI_Farbe");
Sending a command like this appears to be working most of the time: light.sendCommand("25,50,50")
I tried to turn the light off with light.sendCommand("0,0,0") or light.sendCommand("1,1,0") from within a function that is called with setTimeout and a delay.
This succeeded several times, but at some point it just stopped working.
Debugging it with print statements, judging from log output, sendCommand call is the point where the script simply stops execution. Wrapping in tryâŠcatch does nothing, catch and finally blocks that do nothing but print statements are apparently not even executed. No line after and including the sendCommand line in the function is executed anymore (print statements do not get logged anmore).
This didnât just happen with sendCommand but also other things, for example I tried to do something with jodatime-js, and apparently as soon as I try to reference constants like ChronoField the script just fails without error output. Generally it seems that as soon as a line where there is a problem is about to be executed, the execution is just terminated silently, no stacktrace, no hint for me to know even where the failure might have happened.
It is really hard to tell if the source of a problem is with my script (and what/where), or the connection or the device.
Is there any way to get some useful debugging output for scripts when they fail?
is Debug mide (./start_debug.sh) for actual development on OpenHab itsself, or should I also use that to debug scripts?
Firstly, you can turn off a Color Item and a Dimmer Item with sendCommand('OFF'). Thatâs not relevant to your problem but wanted to mention it as being an option.
I canât find where setTimeout and cancelTimeout are implemented. It appears they are implemented in the add-on and not the helper library.
You might get more information if you put the JS Scripting add-on into debug or trace level logging. Iâve never had a rule not report errors to the log when they fail so I couldnât imagine how this is happening here.
Also, put the RuleStatusInfoEvent into INFO level logging and youâll see log entries added to events.log when a rule starts and stops running. Itâs possible, especially when working with Timers, that something is getting blocked and there hasnât been an error but a resource conflict where everything is waiting for a lock or something to be released that never will happen. Note that each rule gets its own thread, but it only gets the one thread. So even the timers created in that one rule need access to the one thread to run. If that thread gets blocked, nothing will run. Though that doesnât sound like what is happening here.
Thanks.
How do I put the JS Scripting add-on into debug mode? Settings give me only the options
Use Built-in Variables
Do Not Use Built-in Variables
How do I change the log level of Events such as the RuleStatusInfoEvent?
I suppose I should use the Console for that (hadenât used it before so far)?
Something like this?
log:set INFO RuleStatusInfoEvent
(I donât get any feedback when I enter that command)
with log:tail I see for example this output:
18:59:39.249 [INFO ] [openhab.event.ItemCommandEvent ] - Item âBadlichtSpiegelMLI_Farbeâ received command 25,50,100
18:59:39.249 [INFO ] [openhab.event.ItemStatePredictedEvent] - Item âBadlichtSpiegelMLI_Farbeâ predicted to become 25,50,100
18:59:59.250 [INFO ] [openhab.event.ItemCommandEvent ] - Item âBadlichtSpiegelMLI_Farbeâ received command 1,1,0
18:59:59.251 [INFO ] [openhab.event.ItemStatePredictedEvent] - Item âBadlichtSpiegelMLI_Farbeâ predicted to become 1,1,0
18:59:59.251 [INFO ] [openhab.event.ItemStateChangedEvent ] - Item âBadlichtSpiegelMLI_Farbeâ changed from 25,50,100 to 1,1,0
But the physical light does not actually change the color to â1,1,0â (i.e. off) at the moment.
The logging namespace will be org.openhab.automation.jsscripting.
Yes but you need the full namespace: openhab.event.RuleStatusInfoEvent, or edit the log4j2.xml file itself where there is already a line for it. Just change the "ERROR" to "INFO".
