I can change the mode in my Ecobee by creating a Mode Item from the HVAC Mode channel, then sending a command like “away” and it changes the mode on the thermostat.
When I try to do the same thing with an “away” command after making an item from the Hold Action or Hold Climate Ref channels it doesn’t change on the thermostat.
Am I going about this the wrong way? All of those channels are read/write so it seems like they should work the same?
