I’ve figured out how to get the PIN authorization going for my Ecobee binding. I can see in my Ecobee UI that there is 1 install of my app and I can see in the OH2 logs that the authorization clearly succeeded. I’ve restarted OH2.
Using cut-and-paste configs from https://docs.openhab.org/addons/bindings/ecobee1/readme.html I’m still getting a ton of errors:
2018-07-10 22:30:29.050 [ERROR] [ui.internal.items.ItemUIRegistryImpl] - Cannot retrieve item 'actualTemperature' for widget org.eclipse.smarthome.model.sitemap.Text
2018-07-10 22:30:29.053 [ERROR] [ui.internal.items.ItemUIRegistryImpl] - Cannot retrieve item 'actualTemperature' for widget org.eclipse.smarthome.model.sitemap.Text
2018-07-10 22:30:29.057 [ERROR] [ui.internal.items.ItemUIRegistryImpl] - Cannot retrieve item for widget org.eclipse.smarthome.model.sitemap.Text
2018-07-10 22:30:29.061 [ERROR] [ui.internal.items.ItemUIRegistryImpl] - Cannot retrieve item 'actualHumidity' for widget org.eclipse.smarthome.model.sitemap.Text
2018-07-10 22:30:29.064 [ERROR] [ui.internal.items.ItemUIRegistryImpl] - Cannot retrieve item 'actualHumidity' for widget org.eclipse.smarthome.model.sitemap.Text
2018-07-10 22:30:29.068 [ERROR] [ui.internal.items.ItemUIRegistryImpl] - Cannot retrieve item for widget org.eclipse.smarthome.model.sitemap.Text
2018-07-10 22:30:29.072 [ERROR] [ui.internal.items.ItemUIRegistryImpl] - Cannot retrieve item 'hvacMode' for widget org.eclipse.smarthome.model.sitemap.Switch
2018-07-10 22:30:29.075 [ERROR] [ui.internal.items.ItemUIRegistryImpl] - Cannot retrieve item 'hvacMode' for widget org.eclipse.smarthome.model.sitemap.Switch
2018-07-10 22:30:29.078 [ERROR] [ui.internal.items.ItemUIRegistryImpl] - Cannot retrieve item for widget org.eclipse.smarthome.model.sitemap.Switch
2018-07-10 22:30:29.082 [ERROR] [ui.internal.items.ItemUIRegistryImpl] - Cannot retrieve item 'currentClimateRef' for widget org.eclipse.smarthome.model.sitemap.Text
2018-07-10 22:30:29.085 [ERROR] [ui.internal.items.ItemUIRegistryImpl] - Cannot retrieve item 'currentClimateRef' for widget org.eclipse.smarthome.model.sitemap.Text
2018-07-10 22:30:29.089 [ERROR] [ui.internal.items.ItemUIRegistryImpl] - Cannot retrieve item for widget org.eclipse.smarthome.model.sitemap.Text
2018-07-10 22:30:29.093 [ERROR] [ui.internal.items.ItemUIRegistryImpl] - Cannot retrieve item 'desiredComf' for widget org.eclipse.smarthome.model.sitemap.Switch
2018-07-10 22:30:29.097 [ERROR] [ui.internal.items.ItemUIRegistryImpl] - Cannot retrieve item 'desiredComf' for widget org.eclipse.smarthome.model.sitemap.Switch
2018-07-10 22:30:29.100 [ERROR] [ui.internal.items.ItemUIRegistryImpl] - Cannot retrieve item for widget org.eclipse.smarthome.model.sitemap.Switch
2018-07-10 22:30:29.103 [ERROR] [ui.internal.items.ItemUIRegistryImpl] - Cannot retrieve visibility item hvacMode for widget org.eclipse.smarthome.model.sitemap.Setpoint
2018-07-10 22:30:29.106 [ERROR] [ui.internal.items.ItemUIRegistryImpl] - Cannot retrieve item 'desiredTemp' for widget org.eclipse.smarthome.model.sitemap.Setpoint
2018-07-10 22:30:29.108 [ERROR] [ui.internal.items.ItemUIRegistryImpl] - Cannot retrieve item 'desiredTemp' for widget org.eclipse.smarthome.model.sitemap.Setpoint
2018-07-10 22:30:29.110 [ERROR] [ui.internal.items.ItemUIRegistryImpl] - Cannot retrieve item for widget org.eclipse.smarthome.model.sitemap.Setpoint
2018-07-10 22:30:29.112 [ERROR] [ui.internal.items.ItemUIRegistryImpl] - Cannot retrieve visibility item hvacMode for widget org.eclipse.smarthome.model.sitemap.Setpoint
2018-07-10 22:30:29.114 [ERROR] [ui.internal.items.ItemUIRegistryImpl] - Cannot retrieve item 'desiredHeat' for widget org.eclipse.smarthome.model.sitemap.Setpoint
2018-07-10 22:30:29.116 [ERROR] [ui.internal.items.ItemUIRegistryImpl] - Cannot retrieve item 'desiredHeat' for widget org.eclipse.smarthome.model.sitemap.Setpoint
2018-07-10 22:30:29.118 [ERROR] [ui.internal.items.ItemUIRegistryImpl] - Cannot retrieve item for widget org.eclipse.smarthome.model.sitemap.Setpoint
2018-07-10 22:30:29.120 [ERROR] [ui.internal.items.ItemUIRegistryImpl] - Cannot retrieve visibility item hvacMode for widget org.eclipse.smarthome.model.sitemap.Setpoint
2018-07-10 22:30:29.122 [ERROR] [ui.internal.items.ItemUIRegistryImpl] - Cannot retrieve item 'desiredCool' for widget org.eclipse.smarthome.model.sitemap.Setpoint
2018-07-10 22:30:29.124 [ERROR] [ui.internal.items.ItemUIRegistryImpl] - Cannot retrieve item 'desiredCool' for widget org.eclipse.smarthome.model.sitemap.Setpoint
2018-07-10 22:30:29.126 [ERROR] [ui.internal.items.ItemUIRegistryImpl] - Cannot retrieve item for widget org.eclipse.smarthome.model.sitemap.Setpoint
2018-07-10 22:30:29.129 [ERROR] [ui.internal.items.ItemUIRegistryImpl] - Cannot retrieve item 'desiredFan' for widget org.eclipse.smarthome.model.sitemap.Switch
2018-07-10 22:30:29.130 [ERROR] [ui.internal.items.ItemUIRegistryImpl] - Cannot retrieve item 'desiredFan' for widget org.eclipse.smarthome.model.sitemap.Switch
2018-07-10 22:30:29.132 [ERROR] [ui.internal.items.ItemUIRegistryImpl] - Cannot retrieve item for widget org.eclipse.smarthome.model.sitemap.Switch
2018-07-10 22:30:29.135 [ERROR] [ui.internal.items.ItemUIRegistryImpl] - Cannot retrieve item 'bedroomTemperature' for widget org.eclipse.smarthome.model.sitemap.Text
2018-07-10 22:30:29.137 [ERROR] [ui.internal.items.ItemUIRegistryImpl] - Cannot retrieve item 'bedroomTemperature' for widget org.eclipse.smarthome.model.sitemap.Text
2018-07-10 22:30:29.139 [ERROR] [ui.internal.items.ItemUIRegistryImpl] - Cannot retrieve item for widget org.eclipse.smarthome.model.sitemap.Text
2018-07-10 22:30:29.141 [ERROR] [ui.internal.items.ItemUIRegistryImpl] - Cannot retrieve item 'bedroomOccupancy' for widget org.eclipse.smarthome.model.sitemap.Text
2018-07-10 22:30:29.143 [ERROR] [ui.internal.items.ItemUIRegistryImpl] - Cannot retrieve item 'bedroomOccupancy' for widget org.eclipse.smarthome.model.sitemap.Text
2018-07-10 22:30:29.145 [ERROR] [ui.internal.items.ItemUIRegistryImpl] - Cannot retrieve item for widget org.eclipse.smarthome.model.sitemap.Text
Can anyone help me dig further into the errors? I’m not even sure where to look to change configs (Items, Sites, Something Else?).
