Can you post a screen snip of the part of your sitemap that shows the thermostat items?
That’s the sitemap source code. The sitemap is rendered by BasicUI.
When rendered in BasicUI, the setpoint widgets will look like this.
http://docs.openhab.org/configuration/sitemaps.html#element-type-setpoint
Read the section on UIs.
http://docs.openhab.org/addons/uis.html
There you go! The heating (Heat) and cooling (Cool) setpoints can be adjusted with the up/down arrows.
Is this the only UI I can use for the thermostat
Of course not. Other popular UIs are:
- Andoid app
- IOS app
- HABpanel.
Can you walk me through the openHAB setup for it?
I’d suggest you read through the documentation. It’s all in there.
Which one?
