One other thing to make note of… Doubtful that it’s relevant here, but thought I would mention it anyway.
Up until late November last year, there wasn’t a separate database entry for the DWZWAVE version 2.5 device. Prior to November, the DWZWAVE 2.5 device was lumped in with the DWZWAVE 2 device. In late November, I created a separate database entry for the 2.5 device because it had some additional feature/channels from the version 2 device.
The sensor_binary items are showing up in the log. This isn’t being reflected on the site map in basic UI, or in paper UI under control. The sensor_door channels are not showing up in the log.
Also, I’m at a complete loss as to why one of these is reporting Open/Closed and the other On/Off. Both are defined as sensor_binary.
2019-04-29 16:46:05.650 [thome.event.ItemStateEvent] - Garage_Door_Binary updated to OPEN
2019-04-29 16:46:06.598 [thome.event.ItemStateEvent] - Garage_Door_Binary updated to CLOSED
2019-04-29 16:46:09.185 [thome.event.ItemStateEvent] - GDBS updated to ON
2019-04-29 16:46:09.189 [vent.ItemStateChangedEvent] - GDBS changed from OFF to ON
2019-04-29 16:46:09.841 [thome.event.ItemStateEvent] - GDBS updated to OFF
2019-04-29 16:46:09.843 [vent.ItemStateChangedEvent] - GDBS changed from ON to OFF
I understand that there are multiple channels per sensor. What is baffling is the sensor_binary channel of node 36 (GDBS) is reporting ON/OFF rather than OPEN/CLOSED in the logs.
Sorry, I have that backwards. The other sensor GARAGE_DOOR_BINARY should also be reporting ON/OFF, but is reporting OPEN/CLOSED. Coffee hasn’t kicked in yet.
Ok. Here’s a snippet. I turned some debug flags on and opened and closed the garage doors, node 35 and node 36, before reading your last message. Node 36 isn’t showing up at all.
The only message that isn’t being decoded is the BASIC message. It looks like it is probably mimicking the SENSOR_BINARY class, so this is probably an issue with the database configuration, although as you should use the sensor_door class, this shouldn’t matter.
In this log, the garage_door_binary is linked to sensor_binary, and this IS reporting OnOffType - ie ON/OFF and not OPEN/CLOSED.
My problem is that none of the (ZW) sensor_binary or sensor_door item status changes are reflected in the site map or the control section of paperUI or Habmin and my rules are no longer responding to those item status changes. I describe the history at the bottom.
Node 36 missing from logs this morning is unique. It was showing up yesterday. Item ‘GDBS’ shown in log from yesterday is node 36. This isn’t my primary focus though.
See the log snippet just above. Both of those channels GDBS (node 36) and Garage_Door_Binary (node 35) are defined as sensor_binary. The item file snippet is above. One is reporting correctly, one isn’t.
History:
All had been working fine for many months. I hadn’t even logged into that computer in months. Last week, the laptop running OH fell asleep for mysterious reasons. It has never happened before. When it restarted, the zwave controller was offline. I rebooted and it was still offline. After a few restarts I gave up and deleted then recreated the the controller thing (AEON Z-Stick) and in the process named it the same as before so I wouldn’t have to change the names of all of my channels in the items file. At that point, all of my ZW things were still offline. I rebooted or restarted OH, I don’t recall. Still offline. So I deleted all of them, scanned and recreated all of them. All of the ZW things (about 20) worked after that, except the door sensors and PIR sensors, one Aeon on mains and one Eco on battery.
At this point, the only reason I have not wiped the whole thing clean and re-installed is in case there is some benefit to the OH community in learning why this happened. Please let me know if you would like me to keep chasing this, otherwise I will just reinstall.
I’m not sure what snippet you refer to here. If I look just above I don’t just see sensor_binary - I also see sensor_door.
In any case, from a binding perspective, it looks fine. The channels are being updated, so I’m not sure why it’s not flowing through the rest of the system.
From a binding perspective, there is nothing wrong as far as I can see here. The channels are being decoded correctly, and updating the system. If it were me with this problem, I’d reinstall
