Those values are passed verbatim as they are sent from the device. They are not interpreted (e.g. converted to float) at any point, I keep them as string.
I would be great, because I have to clean some of my room disabling āTrue Detect 3Dā, otherwise Deebot do not go into that room, due a small step and a long hair carpet. Disabiling āTrue Detect 3Dā Deebot clean that room, but cause some issue in the kitchen and my cave, where there always is omething on the floor.
Hi, in my app there is not Rooms Letter on the map, I have name of the room. Can you publish a screenshoot explaining where in Ecovacs App can I get the letters?
I saw command in readme but I mean some Example of usage as all binding available. Some code of item and rule, showing how to use Bindings
Well, I linked the ācommandā channel to an item via UI (no code needed/available there), and then am sending commands to that as per usual. Example rule (executed whenever I press the respective button on a button panel):
var currentState = itemRegistry.getItem("VacuumRobotGroundFloorState").getState().toString();
if (currentState == "charging" || currentState == "idle") {
events.sendCommand("VacuumRobotGroundFloorCommand", "clean");
} else if (currentState == "cleaning") {
events.sendCommand("VacuumRobotGroundFloorCommand", "pause");
} else if (currentState == "pause") {
events.sendCommand("VacuumRobotGroundFloorCommand", "resume");
You should be able to tap on the room/name and remove the room label ā¦ at least I have an option 'Standard (A, B, C, ā¦)ā. Alternatively, just try one after another, starting at A.
Iām using your binding since a month and it is doing great.
Thanks!
Iām using a Deebot T9+ and in the app i have a setting for cleaning 1 time or 2 times.
It then cleans every room once or twice.
Any possibility to add a channel for that?
if I know exactly how, i could provide API endpoints data for that. Unfortunately Iām not a Java programmer. Therefore i would not think of a Github PR ^^
I use a T9 AIVI, the API Account works, but device discovered and manual adding with the serialnumber (from QR Code label) is also not working.
Log Say āDevice not found in device list, setting offlineā.
Please provide the full discovery log. If your device is not in the bindingās device list, there should be a log line āFound unsupported deviceā¦ā ā¦ if there is, I need the precise log message text.
Edit: I just looked at my deviceās QR code and the serial number there is incomplete. You need to use the serial number printed on the bar code under the dust bin.
