may I share the MQTT thing to manage the new weather station and door window from shelly?
UID: mqtt:topic:<REPLACE>:Shelly1MiniGen4_<REPLACE>
label: blu gateway
thingTypeUID: mqtt:topic
configuration:
payloadNotAvailable: "false"
availabilityTopic: shelly1minig4-<REPLACE>/online
payloadAvailable: "true"
bridgeUID: mqtt:broker:<REPLACE>
channels:
- id: shelly1mini_bthome_204_DOORWINDOW_LUX
channelTypeUID: mqtt:number
label: DOORWINDOW LUX
configuration:
stateTopic: shelly1minig4-<REPLACE>/status/bthomesensor:204
transformationPattern:
- JSONPATH:$.value
- id: shelly1mini_bthome_205_DOORWINDOW_CONTACT
channelTypeUID: mqtt:switch
label: DOORWINDOW Contact
configuration:
stateTopic: shelly1minig4-<REPLACE>/status/bthomesensor:205
- JSONPATH:$.value
- MAP:config:map:shellylettura
on: on
off: off
- id: shelly1mini_bthome_DOORWINDOW_BATTERY
label: DOORWINDOW Battery
configuration:
stateTopic: shelly1minig4-<REPLACE>/status/bthomedevice:201
- JSONPATH:$.battery
- id: shelly1mini_bthome_207_WEATHER_LIGHT
label: WEATHER Light
configuration:
stateTopic: shelly1minig4-<REPLACE>/status/bthomesensor:207
- JSONPATH:$.value
- id: shelly1mini_bthome_208_WEATHER_RAIN
label: WEATHER Rain
configuration:
stateTopic: shelly1minig4-<REPLACE>/status/bthomesensor:208
- JSONPATH:$.value
- id: shelly1mini_bthome_209_WEATHER_WIND_SPEED
label: WEATHER Wind Speed
configuration:
stateTopic: shelly1minig4-<REPLACE>/status/bthomesensor:209
- JSONPATH:$.value
- id: shelly1mini_bthome_210_WEATHER_GUST
label: WEATHER Wind Gust
configuration:
stateTopic: shelly1minig4-<REPLACE>/status/bthomesensor:210
- JSONPATH:$.value
- id: shelly1mini_bthome_211_WEATHER_UV
label: WEATHER UV Index
configuration:
stateTopic: shelly1minig4-<REPLACE>/status/bthomesensor:211
- JSONPATH:$.value
- id: shelly1mini_bthome_212_WEATHER_WIND_DIR
label: WEATHER Wind Direction
configuration:
stateTopic: shelly1minig4-<REPLACE>/status/bthomesensor:212
- JSONPATH:$.value
- id: shelly1mini_bthome_213_WEATHER_TEMPERATURE
label: WEATHER Temperature
configuration:
stateTopic: shelly1minig4-<REPLACE>/status/bthomesensor:213
- JSONPATH:$.value
- id: shelly1mini_bthome_214_WEATHER_HUMIDITY
label: WEATHER Humidity
configuration:
stateTopic: shelly1minig4-<REPLACE>/status/bthomesensor:214
- JSONPATH:$.value
- id: shelly1mini_bthome_215_WEATHER_DEWPOINT
label: WEATHER Dew Point
configuration:
stateTopic: shelly1minig4-<REPLACE>/status/bthomesensor:215
- JSONPATH:$.value
- id: shelly1mini_bthome_216_WEATHER_PRESSURE
label: WEATHER Pressure
configuration:
stateTopic: shelly1minig4-<REPLACE>/status/bthomesensor:216
- JSONPATH:$.value
- id: shelly1mini_bthome_218_WEATHER_PRECIPITATION
label: WEATHER Precipitation
configuration:
stateTopic: shelly1minig4-<REPLACE>/status/bthomesensor:218
- JSONPATH:$.value
- id: shelly1mini_bthome_202_WEATHER_BATTERY
label: WEATHER Battery
configuration:
stateTopic: shelly1minig4-<REPLACE>/status/bthomedevice:202
