First of all, I would like to thank everybody involved to openHAB and especially
those who made jsr223-scripting possible.
While there are good points for openHAB DSL, there are some tasks where
jsr223-scripting seems to be more appropriate.
I discovered this topic not long ago, so I consider myself a NewBie.
Here is my challenge:
Edited Files appear in the Log as if they are running more than once, see an example here .
openHAB is running on a Debian 8 VM, apt install. Hardware of the Host is an intel i7. The configuration is edited from Mac OS X via a samba share configured as below
[openhab_production_basic_conf]
path = /home/smarthomeadmin/src
read only = no
guest ok = no
force user = smarthomeadmin
force group = openhab
valid users = smarthomeadmin
the Logging configuration (/var/lib/openhab2/etc/org.ops4j.pax.logging.cfg) is
# Common pattern layout for appenders
#log4j2.pattern = %d{ISO8601} | %-5p | %-16t | %-32c{1} | %X{bundle.id} - %X{bundle.name} - %X{bundle.version} | %m%n
# Root logger
log4j2.rootLogger.level = WARN
log4j2.rootLogger.appenderRefs = out, osgi
log4j2.rootLogger.appenderRef.out.ref = LOGFILE
log4j2.rootLogger.appenderRef.osgi.ref = OSGI
# Karaf Shell logger
log4j2.logger.shell.name = org.apache.karaf.shell.support
log4j2.logger.shell.level = OFF
log4j2.logger.shell.appenderRefs = stdout
log4j2.logger.shell.appenderRef.stdout.ref = STDOUT
# Security audit logger
log4j2.logger.audit.name = org.apache.karaf.jaas.modules.audit
log4j2.logger.audit.level = INFO
log4j2.logger.audit.additivity = false
log4j2.logger.audit.appenderRefs = audit
log4j2.logger.audit.appenderRef.audit.ref = AUDIT
# openHAB specific logger configuration
log4j2.logger.openhab.name = org.openhab
log4j2.logger.openhab.level = INFO
log4j2.logger.smarthome.name = org.eclipse.smarthome
log4j2.logger.smarthome.level = INFO
log4j2.logger.smarthomeItemStateEvent.name = smarthome.event.ItemStateEvent
log4j2.logger.smarthomeItemStateEvent.level = ERROR
log4j2.logger.smarthomeItemAddedEvent.name = smarthome.event.ItemAddedEvent
log4j2.logger.smarthomeItemAddedEvent.level = ERROR
log4j2.logger.smarthomeItemRemovedEvent.name = smarthome.event.ItemRemovedEvent
log4j2.logger.smarthomeItemRemovedEvent.level = ERROR
log4j2.logger.smarthomeThingStatusInfoEvent.name = smarthome.event.ThingStatusInfoEvent
log4j2.logger.smarthomeThingStatusInfoEvent.level = ERROR
log4j2.logger.smarthomeThingAddedEvent.name = smarthome.event.ThingAddedEvent
log4j2.logger.smarthomeThingAddedEvent.level = ERROR
log4j2.logger.smarthomeThingRemovedEvent.name = smarthome.event.ThingRemovedEvent
log4j2.logger.smarthomeThingRemovedEvent.level = ERROR
log4j2.logger.smarthomeInboxUpdatedEvent.name = smarthome.event.InboxUpdatedEvent
log4j2.logger.smarthomeInboxUpdatedEvent.level = ERROR
# Changes for smarthomebbb.lan
log4j2.logger.smarthomeItemCommandEvent.name = smarthome.event.ItemCommandEvent
log4j2.logger.smarthomeItemCommandEvent.level = INFO
log4j2.logger.smarthomeItemCommandEvent.additivity = false
log4j2.logger.smarthomeItemCommandEvent.appenderRefs = console
log4j2.logger.smarthomeItemCommandEvent.appenderRef.console.ref = STDOUT
log4j2.logger.smarthomeItemStateChangedEvent.name = smarthome.event.ItemStateChangedEvent
log4j2.logger.smarthomeItemStateChangedEvent.level = INFO
log4j2.logger.smarthomeItemStateChangedEvent.additivity = false
log4j2.logger.smarthomeItemStateChangedEvent.appenderRefs = console
log4j2.logger.smarthomeItemStateChangedEvent.appenderRef.console.ref = STDOUT
# openHAB Scripts and Rules General
log4j2.logger.smarthomeScript.name = org.eclipse.smarthome.model.script
log4j2.logger.smarthomeScript.level = DEBUG
log4j2.logger.smarthomeScript.appenderRefs = console
log4j2.logger.smarthomeScript.appenderRef.console.ref = STDOUT
# This are line like "Scheduled code for execution at 2018-01-27T08:54:26.376+01:00"
log4j2.logger.smarthomeScriptActions.name = org.eclipse.smarthome.model.script.actions.ScriptExecution
log4j2.logger.smarthomeScriptActions.level = INFO
# This are line like "Executing timer 'DEFAULT.2018-01-27T08:53:24.822+01:00: Proxy for org.eclipse.xtext.xbase.lib.Procedures$Procedure0: [ | {
log4j2.logger.smarthomeScriptActionsTimer.name = org.eclipse.smarthome.model.script.internal.actions.TimerExecutionJob
log4j2.logger.smarthomeScriptActionsTimer.level = INFO
# openHAB Scripts and Rules on Subpackage Level
log4j2.logger.smarthomeScript_dev_wave.name = org.eclipse.smarthome.model.script.dev_wave
log4j2.logger.smarthomeScript_dev_wave.level = INFO
log4j2.logger.smarthomeScript_hlk_ww.name = org.eclipse.smarthome.model.script.hlk_ww
log4j2.logger.smarthomeScript_hlk_ww.level = INFO
# End changes for smarthomebbb.lan
log4j2.logger.events.name = smarthome.event
log4j2.logger.events.level = INFO
log4j2.logger.events.additivity = false
log4j2.logger.events.appenderRefs = event
log4j2.logger.events.appenderRef.event.ref = EVENT
log4j2.logger.events.appenderRef.osgi.ref = OSGI
log4j2.logger.jupnp.name = org.jupnp
log4j2.logger.jupnp.level = ERROR
log4j2.logger.jmdns.name = javax.jmdns
log4j2.logger.jmdns.level = ERROR
# This suppresses all Maven download issues from the log when doing feature installations
# as we are logging errors ourselves in a nicer way anyhow.
log4j2.logger.paxurl.name = org.ops4j.pax.url.mvn.internal.AetherBasedResolver
log4j2.logger.paxurl.level = ERROR
# Filters known issues of pax-web (issue link to be added here).
# Can be removed once the issues are resolved in an upcoming version.
log4j2.logger.paxweb.name = org.ops4j.pax.web.pax-web-runtime
log4j2.logger.paxweb.level = OFF
# Filters known issues of lsp4j, see
# https://github.com/eclipse/smarthome/issues/4639
# https://github.com/eclipse/smarthome/issues/4629
# https://github.com/eclipse/smarthome/issues/4643
log4j2.logger.lsp4j.name = org.eclipse.lsp4j
log4j2.logger.lsp4j.level = OFF
# Filters known issues of KarServiceImpl, see
# https://github.com/openhab/openhab-distro/issues/519#issuecomment-351944506
log4j2.logger.karservice.name = org.apache.karaf.kar.internal.KarServiceImpl
log4j2.logger.karservice.level = ERROR
# Appenders configuration
# Console appender not used by default (see log4j2.rootLogger.appenderRefs)
log4j2.appender.console.type = Console
log4j2.appender.console.name = STDOUT
log4j2.appender.console.layout.type = PatternLayout
log4j2.appender.console.layout.pattern = %d{HH:mm:ss.SSS} [%-5.5p] [%-36.36c] - %m%n
# Rolling file appender
log4j2.appender.out.type = RollingRandomAccessFile
log4j2.appender.out.name = LOGFILE
log4j2.appender.out.fileName = ${openhab.logdir}/openhab.log
log4j2.appender.out.filePattern = ${openhab.logdir}/openhab.log.%i
log4j2.appender.out.immediateFlush = true
log4j2.appender.out.append = true
log4j2.appender.out.layout.type = PatternLayout
log4j2.appender.out.layout.pattern = %d{yyyy-MM-dd HH:mm:ss.SSS} [%-5.5p] [%-36.36c] - %m%n
log4j2.appender.out.policies.type = Policies
log4j2.appender.out.policies.size.type = SizeBasedTriggeringPolicy
log4j2.appender.out.policies.size.size = 16MB
# Event log appender
log4j2.appender.event.type = RollingRandomAccessFile
log4j2.appender.event.name = EVENT
log4j2.appender.event.fileName = ${openhab.logdir}/events.log
log4j2.appender.event.filePattern = ${openhab.logdir}/events.log.%i
log4j2.appender.event.immediateFlush = true
log4j2.appender.event.append = true
log4j2.appender.event.layout.type = PatternLayout
log4j2.appender.event.layout.pattern = %d{yyyy-MM-dd HH:mm:ss.SSS} [%-26.26c] - %m%n
log4j2.appender.event.policies.type = Policies
log4j2.appender.event.policies.size.type = SizeBasedTriggeringPolicy
log4j2.appender.event.policies.size.size = 16MB
# Audit file appender
log4j2.appender.audit.type = RollingRandomAccessFile
log4j2.appender.audit.name = AUDIT
log4j2.appender.audit.fileName = ${openhab.logdir}/audit.log
log4j2.appender.audit.filePattern = ${openhab.logdir}/audit.log.%i
log4j2.appender.audit.append = true
log4j2.appender.audit.layout.type = PatternLayout
log4j2.appender.audit.layout.pattern = %d{yyyy-MM-dd HH:mm:ss.SSS} [%-5.5p] [%-36.36c] - %m%n
log4j2.appender.audit.policies.type = Policies
log4j2.appender.audit.policies.size.type = SizeBasedTriggeringPolicy
log4j2.appender.audit.policies.size.size = 8MB
# OSGi appender
log4j2.appender.osgi.type = PaxOsgi
log4j2.appender.osgi.name = OSGI
log4j2.appender.osgi.filter = *
Any hint is appreciated.
