Hallo,
I try to integratemy Edimax Power-Plug into Openhab2 following this great Blog-Post
https://mysmarthomeweb.wordpress.com/tag/edimax/.
After performing all steps it didn’t work, after a quick investigation in my logfile it seems there is an error where I define my item in my items file.
//Line of my items file ...
Switch EdimaxSimple {edimax="74:AA:38:22:EE:F9:1234"}
21:54:55.199 [ERROR] [el.item.internal.GenericItemProvider] - Binding configuration of type 'edimax' of item 'EdimaxSimple' could not be parsed correctly.
java.lang.IllegalArgumentException: No enum constant org.openhab.binding.edimax.internal.EdimaxBindingConfiguration.Type.38
at java.lang.Enum.valueOf(Enum.java:238)[:1.8.0_121]
at org.openhab.binding.edimax.internal.EdimaxBindingConfiguration$Type.valueOf(EdimaxBindingConfiguration.java:1)[217:org.openhab.binding.edimax:1.9.0.201607291201]
at org.openhab.binding.edimax.internal.EdimaxBindingConfiguration.parse(EdimaxBindingConfiguration.java:83)[217:org.openhab.binding.edimax:1.9.0.201607291201]
at org.openhab.binding.edimax.internal.EdimaxGenericBindingProvider.validateItemType(EdimaxGenericBindingProvider.java:37)[217:org.openhab.binding.edimax:1.9.0.201607291201]
at org.openhab.core.binding.internal.BindingConfigReaderDelegate.validateItemType(BindingConfigReaderDelegate.java:37)[219:org.openhab.core.compat1x:2.0.0]
at org.eclipse.smarthome.model.item.internal.GenericItemProvider.internalDispatchBindings(GenericItemProvider.java:311)[123:org.eclipse.smarthome.model.item:0.9.0.b4]
at org.eclipse.smarthome.model.item.internal.GenericItemProvider.internalDispatchBindings(GenericItemProvider.java:284)[123:org.eclipse.smarthome.model.item:0.9.0.b4]
at org.eclipse.smarthome.model.item.internal.GenericItemProvider.processBindingConfigsFromModel(GenericItemProvider.java:167)[123:org.eclipse.smarthome.model.item:0.9.0.b4]
at org.eclipse.smarthome.model.item.internal.GenericItemProvider.modelChanged(GenericItemProvider.java:347)[123:org.eclipse.smarthome.model.item:0.9.0.b4]
at org.eclipse.smarthome.model.core.internal.ModelRepositoryImpl.notifyListeners(ModelRepositoryImpl.java:207)[122:org.eclipse.smarthome.model.core:0.9.0.b4]
at org.eclipse.smarthome.model.core.internal.ModelRepositoryImpl.addOrRefreshModel(ModelRepositoryImpl.java:120)[122:org.eclipse.smarthome.model.core:0.9.0.b4]
at org.eclipse.smarthome.model.core.internal.folder.FolderObserver.checkFile(FolderObserver.java:272)[122:org.eclipse.smarthome.model.core:0.9.0.b4]
at org.eclipse.smarthome.model.core.internal.folder.FolderObserver.access$1(FolderObserver.java:265)[122:org.eclipse.smarthome.model.core:0.9.0.b4]
at org.eclipse.smarthome.model.core.internal.folder.FolderObserver$WatchQueueReader.processWatchEvent(FolderObserver.java:146)[122:org.eclipse.smarthome.model.core:0.9.0.b4]
at org.eclipse.smarthome.core.service.AbstractWatchQueueReader.run(AbstractWatchQueueReader.java:122)[98:org.eclipse.smarthome.core:0.9.0.b4]
at java.lang.Thread.run(Thread.java:745)[:1.8.0_121]
My first idea was that I’m missing a depedency or the “Compatibility Layer” but it seems everything is here
217 | Active | 80 | 1.9.0.201607291201 | openHAB Edimax Binding
218 | Active | 80 | 1.9.0 | openHAB HTTP Binding
219 | Active | 80 | 2.0.0 | openHAB 1.x Compatibility Layer
So may be someone can give me a poke into the right direction?
Thank you
