Embedded MQTT Broker has stopped accepting connections
  • Platform information:
    • Hardware: HyperV VM
    • OS: Debian 9
    • Java Runtime Environment: openjdk version “1.8.0_232”
    • openHAB version: 2.4.0-1
  • Issue of the topic: Embedded mqtt broker has completely stopped accepting connections. I have tried uninstalling the binding and reinstalling. Rebooting. I have not made any changes, this seems to have occurred out of nowehere and since most of my stuff works off mqtt, most of my things are down. My log is below from openhab. An example of the output from one of my things (15:09:01 MQT: Connect failed to 192.168.0.180:1883, rc -2. Retry in 10 sec)
      MQTT connection has been lost, cause reported is:{}
      org.eclipse.paho.client.mqttv3.MqttException: Connection lost
              at org.eclipse.paho.client.mqttv3.internal.CommsReceiver.run(CommsReceiver.java:181) [231:org.eclipse.paho.client.mqttv3:1.2.0]
              at java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.access$201(ScheduledThreadPoolExecutor.java:180) [?:?]
              at java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.run(ScheduledThreadPoolExecutor.java:293) [?:?]
      Caused by: java.io.EOFException
              at java.io.DataInputStream.readByte(DataInputStream.java:267) ~[?:?]
              at org.eclipse.paho.client.mqttv3.internal.wire.MqttInputStream.readMqttWireMessage(MqttInputStream.java:92) ~[?:?]
              at org.eclipse.paho.client.mqttv3.internal.CommsReceiver.run(CommsReceiver.java:133) ~[?:?]
              ... 7 more
      2019-11-03 08:54:32.100 [INFO ] [b.handler.EspMilightHubBridgeHandler] - Sucessfully connected to the MQTT broker.
      2019-11-03 08:55:26.885 [INFO ] [ansport.mqtt.internal.ClientCallback] - MQTT connection to '127.0.0.1' was lost
              ... 7 more
      2019-11-03 08:55:26.887 [WARN ] [r.internal.EmbeddedBrokerServiceImpl] - Embedded broker offline
              ... 7 more
      2019-11-03 08:55:26.890 [ERROR] [b.handler.EspMilightHubBridgeHandler] - MQTT connection has been lost, cause reported is:{}
              ... 7 more
      2019-11-03 08:55:26.913 [WARN ] [.moquette.server.netty.NettyAcceptor] - An InterruptedException was caught while waiting for event loops to terminate...
      2019-11-03 08:55:26.914 [WARN ] [.moquette.server.netty.NettyAcceptor] - Forcing shutdown of worker event loop...
      2019-11-03 08:55:26.914 [WARN ] [.moquette.server.netty.NettyAcceptor] - Forcing shutdown of boss event loop...
      2019-11-03 08:55:26.914 [ERROR] [io.moquette.server.Server           ] - Moquette is not started, MQTT message interceptor cannot be removed. InterceptorId=collectmetrics
      2019-11-03 08:55:28.079 [ERROR] [b.handler.EspMilightHubBridgeHandler] - Error: Could not connect to MQTT broker.{}
      org.eclipse.paho.client.mqttv3.MqttException: Unable to connect to server
              at org.eclipse.paho.client.mqttv3.internal.TCPNetworkModule.start(TCPNetworkModule.java:94) ~[?:?]
              at org.eclipse.paho.client.mqttv3.internal.ClientComms$ConnectBG.run(ClientComms.java:701) ~[?:?]
      Caused by: java.net.ConnectException: Connection refused (Connection refused)
              at java.net.PlainSocketImpl.socketConnect(Native Method) ~[?:?]
              at java.net.AbstractPlainSocketImpl.doConnect(AbstractPlainSocketImpl.java:350) ~[?:?]
              at java.net.AbstractPlainSocketImpl.connectToAddress(AbstractPlainSocketImpl.java:206) ~[?:?]
              at java.net.AbstractPlainSocketImpl.connect(AbstractPlainSocketImpl.java:188) ~[?:?]
              at java.net.SocksSocketImpl.connect(SocksSocketImpl.java:392) ~[?:?]
              at java.net.Socket.connect(Socket.java:607) ~[?:?]
              at org.eclipse.paho.client.mqttv3.internal.TCPNetworkModule.start(TCPNetworkModule.java:84) ~[?:?]
              ... 8 more
      2019-11-03 08:55:38.094 [ERROR] [b.handler.EspMilightHubBridgeHandler] - Error: Could not connect to MQTT broker.{}
              ... 8 more
      2019-11-03 08:55:48.102 [ERROR] [b.handler.EspMilightHubBridgeHandler] - Error: Could not connect to MQTT broker.{}
              ... 8 more
      2019-11-03 08:55:58.114 [ERROR] [b.handler.EspMilightHubBridgeHandler] - Error: Could not connect to MQTT broker.{}
              ... 8 more
      2019-11-03 08:56:08.125 [ERROR] [b.handler.EspMilightHubBridgeHandler] - Error: Could not connect to MQTT broker.{}
              ... 8 more
      2019-11-03 08:56:18.135 [ERROR] [b.handler.EspMilightHubBridgeHandler] - Error: Could not connect to MQTT broker.{}
Also, after I removed and readded the binding I get this log
2019-11-03 09:18:37.884 [INFO ] [.reconnect.PeriodicReconnectStrategy] - Try to restore connection to '127.0.0.1'. Next attempt in 10000ms
2019-11-03 09:18:37.884 [WARN ] [r.internal.EmbeddedBrokerServiceImpl] - Embedded broker offline - Reason unknown
2019-11-03 09:18:37.889 [INFO ] [.transport.mqtt.MqttBrokerConnection] - Starting MQTT broker connection to '127.0.0.1' with clientid embedded-mqtt-broker and file store '/var/lib/openhab2/mqtt/127.0.0.1'
2019-11-03 09:18:37.893 [WARN ] [r.internal.EmbeddedBrokerServiceImpl] - Embedded broker offline
        at org.eclipse.paho.client.mqttv3.internal.TCPNetworkModule.start(TCPNetworkModule.java:94) ~[231:org.eclipse.paho.client.mqttv3:1.2.0]
        at org.eclipse.paho.client.mqttv3.internal.ClientComms$ConnectBG.run(ClientComms.java:701) [231:org.eclipse.paho.client.mqttv3:1.2.0]
        ... 8 more
2019-11-03 09:18:39.305 [ERROR] [b.handler.EspMilightHubBridgeHandler] - Error: Could not connect to MQTT broker.{}
Have you tried upgrading to a newer OH milestone version?
