OH 2.5.8
OpenHabian
Project:
Because I’m currently not using the Hue Bridge and three Things (Lampe1, Lampe2, PlugIn1) and I power off the bridge, some error messages are logged. To reduce this to a one-time event, I thought about the “module Hue Bridge”. It works, but is a bit of “spaghetti code”. Is there a better solution?
With this modul switch it is possible to disconnect the Hue Bridge from power or disable LAN. If the Hue Bridge is manually removed from the power or the bridge is not accessible for other reasons, OpenHAB sets the IsModulHueActiv item to “OFF”. If the IsModulHueActiv switch item is set to “ON”, OpenHAB will attempt to reconnect the bridge. If this does not work, IsModulHueActiv is set to “OFF” again
classic/Icon for Hue Bridge
Hue - Bridge - Things
Overview Hue Bridge
// Die Hue Bridge. Benötigt hue binding
Bridge hue:bridge:ecb5fa2f2064 [ ipAddress="192.168.x.xxx", userName="<api-id>" ] {
0100 bulb1 "Lampe I (0100)" @ "Studio" [ lightId="1" ]
0210 bulb2 "Lampe II (0210)" @ "Studio" [ lightId="2" ]
0010 plug1 "Strom PlugIn 1 (0010)" @ "Studio" [ lightId="3" ]
// Ping zur Hue Bridge (Verfügbarkeit) prüfen. Benötigt netzwerk binding
network:pingdevice:huebridge [ hostname="192.168.x.xxx", retry=1, timeout=5000, refreshInterval=60000 ]
.sitemap - Hue Lamps use
Group item=C_Studio visibility=[IsModulHueActiv=="ON"] {
Frame label="Hue Lampen Status s/w" icon="none" visibility=[IsModulHueActiv=="ON"] {
Switch item=dimmerStudioLight1 label="Lampe 1 - Schalter"
Slider item=dimmerStudioLight1 label="Lampe 1 - Dimmer"
Frame label="Hue Lampen Status farbe" icon="none" visibility=[IsModulHueActiv=="ON"]{
Switch item=switchStudioLight2 label="Lampe 2 -Schalter"
Slider item=dimmerColorStudioLight2 label="Lampe 2 - Dimmer"
Colorpicker item=dimmerColorTempStudioLight2 label="Lampe 2 - Dimmer-Colortemp."
Frame label="Hue Stromstecker 1" icon="none" visibility=[IsModulHueActiv=="ON"] {
Switch item=switchStudioPlugIn1
.sitemap - Modul Settings
Frame label="Hue-Bridge" icon="none" {
Switch item=IsModulHueActiv
Text item=HueBridgeOnline icon="philipshuebridge"
Text item=Light1StateReachable valuecolor=[=="false"="red",=="true"="green",!=dummy="orange"] icon="wallswitch"
Text item=Light2StateReachable valuecolor=[=="false"="red",=="true"="green",!=dummy="orange"] icon="wallswitch"
Text item=PlugIn1StateReachable valuecolor=[=="false"="red",=="true"="green",!=dummy="orange"] icon="poweroutlet"
Rules
hue-bridge-changed.rules
rule "Hue Bridge Status changed (hue-bridge-changed.rules)"
Thing "hue:bridge:ecb5fa2f2064" changed from ONLINE to OFFLINE // Verbindung zur Hue Bridge unterbrochen.
logError("hue:bridge:", "Power off or lost connection ? Hue Brigde Offline")
IsModulHueActiv.postUpdate(OFF)
rule "Hue Bridge rule: Check state.on and state.reachable every minute (hue-bridge-changed.rules)"
Time cron "0 */1 * ? * *" // every minute. Source: https://crontab.guru/examples.html
if (IsModulHueActiv.state == ON ) {
// val headers = newHashMap("Cache-control" -> "no-cache")
// https://community.openhab.org/t/solved-any-hint-how-to-disable-http-items-when-http-fails-or-catch-the-error-without-any-log-entry/104289/7
// get from Hue Bridge: Light 1 state.on (return is String)
val Light1JSON = sendHttpGetRequest("http://192.168.x.xxx/api/<api-id>/lights/1", 60000)
if ( Light1JSON === null ) {
logInfo("Light1JSON:", "return is null - Hue Brigde Offline")
// Disable Hue Bridge
// Disable all Hue Things Items - force update sitemap
Light1StateOn.postUpdate("false")
Light1StateReachable.postUpdate("false")
Light2StateOn.postUpdate("false")
Light2StateReachable.postUpdate("false")
PlugIn1StateReachable.postUpdate("false")
} else {
// logInfo("Light1JSON:","return is not null")
if ( transform("JSONPATH", "$.state.on", Light1JSON) == "true") {
Light1StateOn.postUpdate("true")
} else {
// get from Hue Brige: Light 1 state.reachable
if ( transform("JSONPATH", "state.reachable", Light1JSON) == "true") {
Light1StateReachable.postUpdate("true")
} else {
// get from Hue Bridge: Light 2 state.on (return is String)
val Light2JSON = sendHttpGetRequest("http://192.168.x.xxx/api/<api-id>/lights/2", 60000)
if ( Light2JSON === null ) {
logInfo("Light2JSON:", "return is null - Hue Brigde Offline")
} else {
// logInfo("Light2JSON:","return is not null")
if ( transform("JSONPATH", "$.state.on", Light2JSON) == "true") {
Light2StateOn.postUpdate("true")
} else {
// get from Hue Brige: Light 2 state.reachable
if ( transform("JSONPATH", "state.reachable", Light2JSON) == "true") {
Light2StateReachable.postUpdate("true")
} else {
// get from Hue Bridge: Light 3 = PlugIn1 state.on (return is String)
val PlugIn1JSON = sendHttpGetRequest("http://192.168.x.xxx/api/<api-id>/lights/3", 60000)
if ( PlugIn1JSON === null ) {
logInfo("PlugIn1JSON:", "return is null - Hue Brigde Offline")
} else {
// logInfo("PlugIn1JSON:","return is not null")
// get from Hue Brige: Light 3 state.reachable
if ( transform("JSONPATH", "state.reachable", PlugIn1JSON) == "true") {
PlugIn1StateReachable.postUpdate("true")
} else {
modul.rules
* Modul Konfiguration "ON" / "OFF" (siehe modul.items)
rule "Modul Konfigiguration Init (modul.rules)"
System started
createTimer(now.plusMinutes(2), [ | //Give the system time to load up
if (IsModulHueActiv.state == NULL || IsModulHueActiv.state == UNDEF) {
* Disable Hue Things using REST API
rule "Modul Konfigiguration changed to OFF (modul.rules)"
Item IsModulHueActiv changed to OFF
if (IsModulHueActiv.state == OFF) {
sendHttpPutRequest("http://192.168.x.xxx:8080/rest/things/hue:bridge:ecb5fa2f2064/enable", "application/json", 'false')
* Enable Hue Things using REST API
rule "Modul Konfigiguration changed to ON (modul.rules)"
Item IsModulHueActiv changed to ON
if (IsModulHueActiv.state == ON) {
sendHttpPutRequest("http://192.168.x.xxx:8080/rest/things/hue:bridge:ecb5fa2f2064/enable", "application/json", 'true')
Items
hue.items
// Hue Bridge Service
Switch HueBridgeOnline "Bridge Status [%s]" { channel="network:pingdevice:huebridge:online" }
// Lampe I (0100) @ "Studio"
Dimmer dimmerStudioLight1 { channel="hue:0100:1:bulb1:brightness" }
String Light1StateOn "Lampe 1 - OH Schalter [MAP(huebridge.map):%s]"
String Light1StateReachable "Lampe 1 - Strom Aus/Einschalter [MAP(huebridge.map):%s]"
String Light2StateOn "Lampe 2 - OH Schalter [MAP(huebridge.map):%s]"
String Light2StateReachable "Lampe 2 - Strom Aus/Einschalter [MAP(huebridge.map):%s]"
// Lampe II (0210) @ "Studio"
// https://community.openhab.org/t/hue-hsb-how-to-find-correct-color-warm-cold-white/82964/8
Switch switchStudioLight2 "Colorlampe Schalter" [ "Lighting" ] { channel="hue:0210:ecb5fa2f2064:bulb2:color" }
Dimmer dimmerColorStudioLight2 "Colorlampe Dimmer" [ "Lighting" ] { channel="hue:0210:ecb5fa2f2064:bulb2:color" }
Color colorStudioLight2 "Colorlampe Farbe" [ "Lighting" ] { channel="hue:0210:ecb5fa2f2064:bulb2:color" }
Dimmer dimmerColorTempStudioLight2 "Colorlampe Farbentempersatur" [ "Lighting" ] { channel="hue:0210:ecb5fa2f2064:bulb2:color_temperature" }
// Strom PlugIn I (0010) @ "Studio"
Switch switchStudioPlugIn1 "Strom PlugIn 1" [ "poweroutlet" ] { channel="hue:0010:ecb5fa2f2064:plug1:switch" }
String PlugIn1StateReachable "Strom PlugIn 1 - Erreichbar [MAP(huebridgeplug.map):%s]"
modul.items
* Modul Konfiguration "ON" / "OFF" (siehe modul.rules)
Switch IsModulHueActiv "Modul Hue Bridge ist: [%s]" <switch>
.transform
huebridge.map
false=AUS
true=AN
'false'=AUS
'true'=AN
-=OFFLINE
NULL=OFFLINE
Regards,
Thomas
