after restoring a backup, my openHAB 3.2 in a docker container on a Synology DS218+ ( 6.2.4-25556 Update 6) is stuck in an endless loop when trying to start. No openhab.log is generated. The docker console shows:
2022-06-25 21:49:03 stderr Error occurred shutting down framework: java.lang.NumberFormatException: null
2022-06-25 21:49:03 stderr null
2022-06-25 21:49:02 stdout Launching the openHAB runtime...
2022-06-25 21:49:02 stderr + exec gosu openhab tini -s ./start.sh server
2022-06-25 21:49:02 stderr + command=($@ server)
2022-06-25 21:49:02 stderr + '[' 'gosu openhab tini -s ./start.sh' == 'gosu openhab tini -s ./start.sh' ']'
2022-06-25 21:49:02 stderr ++ echo gosu openhab tini -s ./start.sh
2022-06-25 21:49:02 stderr ++ IFS=' '
2022-06-25 21:49:02 stderr + '[' false == false ']'
2022-06-25 21:49:02 stderr + sync
2022-06-25 21:49:02 stderr + '[' -d /etc/cont-init.d ']'
2022-06-25 21:49:02 stderr + chown -R openhab:openhab /openhab
2022-06-25 21:49:02 stderr + '[' '!' -z ']'
2022-06-25 21:49:02 stderr cmp: /openhab/userdata/etc/version.properties: No such file or directory
2022-06-25 21:49:02 stderr ++ cmp /openhab/userdata/etc/version.properties /openhab/dist/userdata/etc/version.properties
2022-06-25 21:49:02 stderr tmp' ']'
2022-06-25 21:49:02 stderr secrets
2022-06-25 21:49:02 stderr persistence
2022-06-25 21:49:02 stderr logs
2022-06-25 21:49:02 stderr kar
2022-06-25 21:49:02 stderr jsondb
2022-06-25 21:49:02 stderr icalendar_calendar_a107c42237.ical
2022-06-25 21:49:02 stderr etc
2022-06-25 21:49:02 stderr config
2022-06-25 21:49:02 stderr + '[' -z 'cache
2022-06-25 21:49:02 stderr ++ ls -A /openhab/userdata
2022-06-25 21:49:02 stderr + source=/openhab/dist/userdata
2022-06-25 21:49:02 stderr + volume=/openhab/userdata
2022-06-25 21:49:02 stderr + initialize_volume /openhab/userdata /openhab/dist/userdata
2022-06-25 21:49:02 stderr transform' ']'
2022-06-25 21:49:02 stderr things
2022-06-25 21:49:02 stderr sounds
2022-06-25 21:49:02 stderr sitemaps
2022-06-25 21:49:02 stderr services
2022-06-25 21:49:02 stderr scripts
2022-06-25 21:49:02 stderr rules
2022-06-25 21:49:02 stderr items
2022-06-25 21:49:02 stderr icons
2022-06-25 21:49:02 stderr html
2022-06-25 21:49:02 stderr + '[' -z 'automation
2022-06-25 21:49:02 stderr ++ ls -A /openhab/conf
2022-06-25 21:49:02 stderr + source=/openhab/dist/conf
2022-06-25 21:49:02 stderr + volume=/openhab/conf
2022-06-25 21:49:02 stderr + initialize_volume /openhab/conf /openhab/dist/conf
2022-06-25 21:49:02 stderr + id -u openhab
2022-06-25 21:49:02 stdout Starting with openhab user id: 9001 and group id: 9001
2022-06-25 21:49:02 stderr + echo 'Starting with openhab user id: 9001 and group id: 9001'
2022-06-25 21:49:02 stderr + NEW_GROUP_ID=9001
2022-06-25 21:49:02 stderr + NEW_USER_ID=9001
2022-06-25 21:49:02 stderr + rm -f /openhab/userdata/tmp/instances/instance.properties
2022-06-25 21:49:02 stderr + rm -f /openhab/runtime/instances/instance.properties
2022-06-25 21:49:02 stderr + '[' limited = unlimited ']'
2022-06-25 21:49:02 stderr '
2022-06-25 21:49:02 stderr + IFS='
2022-06-25 21:48:00 stderr at org.apache.karaf.main.Main.main(Main.java:197)
2022-06-25 21:48:00 stderr at org.apache.karaf.main.Main.updateInstancePidAfterShutdown(Main.java:232)
2022-06-25 21:48:00 stderr at org.apache.karaf.main.ConfigProperties.<init>(ConfigProperties.java:251)
2022-06-25 21:48:00 stderr at java.base/java.lang.Integer.parseInt(Integer.java:770)
2022-06-25 21:48:00 stderr at java.base/java.lang.Integer.parseInt(Integer.java:614)
2022-06-25 21:48:00 stderr java.lang.NumberFormatException: null
2022-06-25 21:48:00 stderr Error occurred shutting down framework: java.lang.NumberFormatException: null
2022-06-25 21:48:00 stderr null
2022-06-25 21:47:59 stdout Launching the openHAB runtime...
Before the restore it worked very stable. I would appreciate any idea how to resolve it. Cache and tmp folders are empty.
Thank you
