Has anybody had any luck getting the Enerwave ZWN-BPC-PLUS PIR motion sensor to properly work with OpenHAB2? I’m running 2.1.0.008 on a Synology with DSM6.
I’ve tried removing the device and re adding it, I was eventually able to see the device receiving commands through the Karaf Console, and an .XML file was generated, however it wasn’t sending commands when it received motion. After removing it and re installing it’s now stuck on device not in database/initializing not complete. This forum post from 2015 shows the device was added to the database, but i’m wondering if the newer Z-Wave Plus model wont work with the previous model that’s in the database.
Attached is the .XML file. Thanks in advance for any help!
node7.xml (8.2 KB)
