hey guys,
i have just updated the source and the jar. I have testet it with the latest snapshot. And it works.
hey guys,
Hi Thomas,
thanks for your work on the binding. Maybe a stupid question, but where can I find the updated jar?
@Multani have a look at the first post. There is a dist link to github. There you can find it
Thanks for the immediate reply. I already had a look at the links in the first post, however, I could only find the updated source files, not the updated jar. I expected to find the updated jar file here: GitHub - tratho/org.openhab.binding.enigma2-dist - however, there I can only find the old version. Am I missing something?
I tested the binding with my gigablue receiver. It works but the receiver gets very slow in reacting for remote controll commands from the native physical remote control. If I stop the binding, all works fine.
Increasing of timeout/polling interval does not fix it.
Any idea?
I encountered the same problem. I didnĀ“t know that this could come from the binding.
I tested several images for my receiver, on every image after some time the receiver got very slow. I deinstalled the webinterfce of the image and it was fast again.
But now i know, that was not caused by the webinterface, it was the bindingā¦
The receiver was not usable anymore, it was very slow and laggy.
@HomeAutomation
i havenāt tried with an physical remote, i only use the binding for normal, but i will have a try with the physical remote.
One thing i dont really understand, is that increase interval dose not help to fix or reduce the problem
Hi, I started to use this good binding some days ago and I found some of the problems you describe here.
Anyway, thank you for the good work because this binding is really useful, I hope this problems will solved soon.
Bye.
I can confirm that the binding will slow down your STB or render it almost useless after a while. You will only see the spinner and the STB does almost not react to any input. (VU+ STB, Zero, Solo2 & Ultimo4K). Iāve debugged this a little bit & it seems that the thread at the receiver side is busy all the time & something seems not to be release again. Perhaps there happens too much polling from the binding? The CPU load of the Enigma2 process is very high in this case. After a reboot the box will work for a while. Itās quite hard to debug this at the receiver side because the debugging options of Enigma2 are quite limited. Any ideas to work this out? I really like this binding!
Best regards
Stephan
I use the Binding with VU+Uno4K ā¦ no problems like you describe.
What Image do you use? Iām working with the actual VTI 13.0.2. What kind of webinterface? Iāve OpenWebIf on all of my STB
OE-System: openvuplus 3.0
Firmware-Version: VTi 11.0.1. (2017-04-10-vti-master (1881f27))
Kernel / Treiber: 3.14.28 / 3.14.28-20170220.r0
Mh interesting. On my Solo2 Iāve got the VTI 11 Image too & the problem is existent there too
I have a XTrend ET9000, tested with OpenPli 2.x (very old), 4 and 6 (beta).
I used original DMM WebIf on 2.x and i also tested OpenWebIf on 4 and 6.
Same problem on every installation.
Have you test to set the Refresh Interval higher the Default ? Default is 5 seconds.
I have now upgraded to VTi 13.0.2ā¦ after I remove the Thing in OH and re-addā¦ it seems to work without problems ā¦ I use Power and Channel from the Binding.
12:21:38.211 [INFO ] [smarthome.event.ItemStateChangedEvent] - VUplus_WZ_Power changed from ON to OFF
12:21:38.267 [INFO ] [smarthome.event.ItemStateChangedEvent] - VUplus_WZ_Channel changed from WDR HD to
12:21:38.303 [INFO ] [smarthome.event.ItemStateChangedEvent] - VUplus_WZ_Channel changed from to
12:21:48.804 [INFO ] [smarthome.event.ItemStateChangedEvent] - VUplus_WZ_Power changed from OFF to ON
12:21:48.998 [INFO ] [smarthome.event.ItemStateChangedEvent] - VUplus_WZ_Channel changed from to WDR HD
12:22:03.668 [INFO ] [smarthome.event.ItemStateChangedEvent] - VUplus_WZ_Channel changed from WDR HD to RTLplus
12:22:20.808 [INFO ] [smarthome.event.ItemStateChangedEvent] - VUplus_WZ_Channel changed from RTLplus to Sky Bundesliga 1 HD
Did you change the refresh intervall? Iāve changed it to 300sec for testing purpose & will give a feedback.
No ā¦ my Interval is @ Default
Strange, I only use Power from the bindingā¦Testing with the new interval now. Will report back tomorrow if the problem is fixed.
If you only user Power ā¦ than you can get it to work with Curl Commands in a Easy BashScript ā¦ without the Bindingā¦
