thanks for the binding, it helps me very for the first steps, I’m a very newby in openhab2.
I try to program a button with examble the “exit” key from enigma, but i don’t get it run.
Can you simple show me the way to create new button functions?
I’m new to openhab, but i successfully added my Fritzbox, CometDect an Samsung TV.
Now i’m trying to add my AX51-Enigma2 receiver.
I installed the precompiled binding from this topic.
I can change volume and turn it on/off. but i can’t send keys (channel number, ok, menu, …)
i created an butten in habpannel --> send fixed value to item (to Ax51_RemoteKey), and added a number as value - without success.
has someone an idea what’s going wrong?
i´ve also the problem that the addon does not start.
i am on openHAB 2.3.0~20180120102227-1 (Build #1191)
[10:52:55] openhabian@openHABianPi:/usr/share/openhab2/addons$ ls -la
total 104
drwxrwxr-x+ 2 openhab openhabian 4096 Feb 22 08:17 .
drwxr-xr-x 4 openhab openhab 4096 Jan 20 16:40 ..
-rw-rw-r-- 1 openhab openhab 59304 Jan 27 14:24 org.openhab.binding.denonmarantz-2.3.0-SNAPSHOT.jar
-rw-rw-r-- 1 openhab openhab 32172 Feb 22 08:17 org.openhab.binding.enigma2_2.3.0.SNAPSHOT.jar
-rw-rw-r-- 1 openhab openhab 70 Jan 20 10:22 README
[10:53:00] openhabian@openHABianPi:/usr/share/openhab2/addons$
for me it looks like the denon binding and the enigma binding have the same rigths, the denon binding runs, enigma not.
i am not so firm in linux and dont know if the enigma needs other rigths
When i tested the binding the last time, my enigma-receiver got very slow - nearly unusable, when connected with the binding. Is this problem fixed already?
I did this as sudo : cd /usr/share/openhab2/addons
systemctl stop openhab2
wget “https://github.com/tbraune42/compiled-addons/raw/master/org.openhab.binding.enigma2-2.4.0-SNAPSHOT.jar”
chown openhab:openhab org.openhab.binding.enigma2-2.4.0-SNAPSHOT.jar
systemctl start openhab2
ls -l
total 32
-rw-rw-r-- 1 openhab openhab 28448 Feb 11 12:06 org.openhab.binding.enigma2-2.4.0-SNAPSHOT.jar
-rw-rw-r-- 1 openhab openhabian 70 Dec 17 08:01 README
Is that correct ?
There is a binding, but it cannot find my Dreambox as a thing.
I have a VU+ Uno 4K SE box with the VTI-Image (VTi 13.0.9 (2018-03-16-vti-master (6bd4516bc))
Would this binding work here also, or how can I integrate the box in OH 2.4 ?
Is it safe to assume that this binding has been abandoned?
I’ve been using it for a while, and although it does generate some errors in the log it seems to do the basic stuff just fine. I haven’t tested “more advanced” stuff though, I’m mostly using it to control sound volume/mute. Even just for my basic use, I find it very useful and would hate to see it die.
Hi, thank you for this binding. No automatic detection of my Dreambox One and no sync of the switch respective to the real power status of the device. But I am very happy to be able to turn on my Dreambox with OpenHAB. However, beginners like me should be suggested to make the webinterface accessible with no authorization and token anti anti-hijacking mechanisms turned off.
