sound
Group BR_Zero "Zero ložnice" <zero> (BR_Zero) ["TV"]
String e2_br_Channel "Program [%s]" <zero> (BR_Zero) { http="<[http://192.168.0.33:80/web/getcurrent:3000:REGEX(.*?<e2servicename>(.*?)</e2servicename>.*)]" }
String e2_br_Actual_Streaming "Pořad [%s]" <zero> (BR_Zero) { http="<[http://192.168.0.33:80/web/getcurrent:3000:REGEX(.*?<e2eventname>(.*?)</e2eventname>.*)]" }
String e2_br_Actual_StreamingED "Popis [%s]" <zero> (BR_Zero) { http="<[http://192.168.0.33:80/web/getcurrent:3000:REGEX(.*?<e2eventdescription>(.*?)</e2eventdescription>.*)]" }
String e2_br_Actual_StreamingEDE "Popis [%s]" <zero> (BR_Zero) { http="<[http://192.168.0.33:80/web/getcurrent:3000:REGEX(.*?<e2eventdescriptionextended>(.*?)</e2eventdescriptionextended>.*)]" }
Number e2_br_number_channel //GH
Number e2_br_number_key
Dimmer e2_br_vol_out
Number e2_br_vol_in "Volume [%s]" <zero> (BR_Zero) { http="<[http://192.168.0.33:80/web/vol:3000:REGEX(.*?<e2current>(.*?)</e2current>.*)]" }
String e2_br_HD_Free "HD Free [%s]" <zero> (BR_Zero) { http="<[http://192.168.0.33:80/web/deviceinfo:3000:REGEX(.*?<e2free>(.*?)</e2free>.*)]" }
Switch e2_br_onoff "Power Zero" (BR_Zero) [ "Switchable" ]
Switch e2_br_ct1 "CT1" <tv_ct1> (BR_Zero) [ "Switchable" ]
Switch e2_br_ct24 "CT 24" <tv_ct24> (BR_Zero) [ "Switchable" ]
Switch e2_br_nova "Nova" <tv_nova> (BR_Zero) [ "Switchable" ]
Switch e2_br_prima "Prima" <tv_prima> (BR_Zero) [ "Switchable" ]
Switch e2_br_barrandov "Barrandov" <tv_barrandov>(BR_Zero) [ "Switchable" ]
Switch e2_br_rebel "Rebel" <tv_rebel> (BR_Zero) [ "Switchable" ]
sitemap zero label="zero" icon="zero" {
Frame label="Enigma2 BR" {
Switch item=e2_br_onoff
Slider item=e2_br_vol_out label="Zvuk Zero [%s]" icon="soundvolume"
Text item=e2_br_vol_in
Switch item=e2_br_number_key label="Zvuk Zero [%s]" icon="soundvolume" mappings=[113="mute", 114="\u25BC", 115="\u25B2"]
Switch item=e2_br_number_key label="\u2B1B\u2B1B\u2B1B\u2B1B [%s]" icon="zero" mappings=[398="red", 399="green", 400="yelow", 401="blue"] labelcolor=[398="red", 399="green", 400="yellow", 401="blue"]
Switch item=e2_br_number_key label="Command [%s]" icon="zero" mappings=[352="OK", 1="EXIT", 105="\u25C4", 106="\u25BA"]
Text item=e2_br_Channel
Text item=e2_br_Actual_Streaming
Text item=e2_br_HD_Free
Selection item=e2_br_number_channel label="TV program" icon="zero" mappings=[1="CT 1", 2="CT 24", 3="Nova", 4="Prima", 5="Barrandov", 6="Rebel"]
Switch item=e2_br_number_channel label="TV program" icon="zero" mappings=[1="CT 1", 2="CT 24", 3="Nova"]
Switch item=e2_br_number_channel label="TV program" icon="zero" mappings=[4="Prima", 5="Barrandov", 6="Rebel"]
Text item=e2_br_Google label="Google Home" icon="google" {
Switch item=e2_br_ct1
Switch item=e2_br_ct24
Switch item=e2_br_nova
Switch item=e2_br_prima
Switch item=e2_br_barrandov
Switch item=e2_br_rebel
Text item=e2_br_Actual_StreamingED
Text item=e2_br_Actual_StreamingEDE
var String e2_br_ip = "192.168.0.33"
rule "e2_br_number_key"
Item e2_br_number_key received command
sendHttpGetRequest("http://" + e2_br_ip + "/web/remotecontrol?command=" + (e2_br_number_key.state as Number))
rule "e2_vol_out"
Item e2_br_vol_out received command
sendHttpGetRequest("http://" + e2_br_ip + "/web/vol?set=set" + (e2_br_vol_out.state as Number))
rule "e2_vol_in"
Item e2_br_vol_in changed
e2_br_vol_out.postUpdate(e2_br_vol_in.state as Number)
rule "Selection item=e2_br_number_channel"
Item e2_br_number_channel received command
switch(receivedCommand) {
case 1 : sendHttpGetRequest("http://" + e2_br_ip + "/web/zap?sRef=1:0:1:1F41:CA1:3:EB0000:0:0:0") //ct1
case 2 : sendHttpGetRequest("http://" + e2_br_ip + "/web/zap?sRef=1:0:1:1F43:CA1:3:EB0000:0:0:0") //ct24
case 3 : sendHttpGetRequest("http://" + e2_br_ip + "/web/zap?sRef=1:0:1:3391:C89:3:EB0000:0:0:0") //nova
case 4 : sendHttpGetRequest("http://" + e2_br_ip + "/web/zap?sRef=1:0:1:3392:C89:3:EB0000:0:0:0") //prima
case 5 : sendHttpGetRequest("http://" + e2_br_ip + "/web/zap?sRef=1:0:1:132B:CA2:3:EB0000:0:0:0") //barrandov
case 6 : sendHttpGetRequest("http://" + e2_br_ip + "/web/zap?sRef=1:0:1:5248:C99:3:EB0000:0:0:0") //rebel
e2_br_number_channel.postUpdate(OFF)
rule "ct1"
Item e2_br_ct1 received command
case ON : sendHttpGetRequest("http://" + e2_br_ip + "/web/zap?sRef=1:0:1:1F41:CA1:3:EB0000:0:0:0")
e2_br_ct1.postUpdate(OFF)
rule "ct24"
Item e2_br_ct24 received command
case ON : sendHttpGetRequest("http://" + e2_br_ip + "/web/zap?sRef=1:0:1:1F43:CA1:3:EB0000:0:0:0")
e2_br_ct24.postUpdate(OFF)
rule "nova"
Item e2_br_nova received command
case ON : sendHttpGetRequest("http://" + e2_br_ip + "/web/zap?sRef=1:0:1:3391:C89:3:EB0000:0:0:0")
e2_br_nova.postUpdate(OFF)
rule "prima"
Item e2_br_prima received command
case ON : sendHttpGetRequest("http://" + e2_br_ip + "/web/zap?sRef=1:0:1:3392:C89:3:EB0000:0:0:0")
e2_br_prima.postUpdate(OFF)
rule "barrandov"
Item e2_br_barrandov received command
case ON : sendHttpGetRequest("http://" + e2_br_ip + "/web/zap?sRef=1:0:1:132B:CA2:3:EB0000:0:0:0")
e2_br_barrandov.postUpdate(OFF)
rule "rebel"
Item e2_br_rebel received command
case ON : sendHttpGetRequest("http://" + e2_br_ip + "/web/zap?sRef=1:0:1:5248:C99:3:EB0000:0:0:0")
e2_br_rebel.postUpdate(OFF)
rule "OnOff"
Item e2_br_onoff received command
case ON : sendHttpGetRequest("http://" + e2_br_ip + "/web/powerstate?newstate=4")
case OFF : sendHttpGetRequest("http://" + e2_br_ip + "/web/powerstate?newstate=5")
